3 owners under 50k miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pvanzee82, Jan 16, 2025.
  1. Jan 16, 2025 at 4:59 AM
    pvanzee82
    pvanzee82 [OP] Well-Known Member
    Pete
    Iowa
    2022 TRD Sport 4WD BCM
    I'm looking at buying a 2021 Limited Nightshade DC 48k miles with 3 previous owners.
    Carfax:
    1st owner - 15k; routine maintenance
    2nd owner - 23k; oil change only
    3 in RC lift installed (I will swap out for a better one)
    3rd owner: 10k; oil changes
    I borrowed it for a few days and it runs fine. One concern is the coolant reservoir was empty so I filled it and it never leaked. Not sure how well they inspected it.
    Currently have them down to $35.5k from 38. 12 mo/12k dealer warranty.
    Any opinions welcome!
  2. Jan 16, 2025 at 5:02 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    If it's an RC DB lift the crossmember has been removed and replaced so reversing that lift will not be easy or straightforward.
    Check the coolant crossover pipe for evidence of leakage. It's a common failure on 3rd gens and one reason the coolant may have been low.
    While you're checking that out also look for evidence of a leak around the timing chain cover which is also known to leak (oil).
    AvalonTaco, Chew, Ngneer and 2 others like this.
  3. Jan 16, 2025 at 5:09 AM
    4x4spiegel
    4x4spiegel Well-Known Member
    certainly is odd there were 3 previous owners , something ain't right . probably more than the potential coolant pipe leak too ! just saying
    AvalonTaco, Ngneer and pvanzee82[OP] like this.
  4. Jan 16, 2025 at 5:42 AM
    pvanzee82
    Pete
    Iowa
    It has a thick steel TRD skid plate which I didn't remove.
    Could that have been installed as a way to replace the crossmember?
    There was oil on the skid plate furthest from the front of the truck. I assumed it came from changing the oil filter.
  5. Jan 16, 2025 at 5:46 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    This. Check for rust, and maybe check the steering rack as well. Those are the common issues.
    I always have a mechanic I trust look over anything I'm going to buy, to make sure I'm not missing anything.
    Lots of people buy a vehicle drive it for a year and sell it, so 3 owners isn't necessarily bad in my mind.
  6. Jan 16, 2025 at 6:56 AM
    BabyBilly
    Billy
    2020 TRD
    If you can show us a picture of the truck down low from the front it'll be pretty obvious. You can tell just by looking at how high it's lifted vs CV angles. A DB lift lets you get like a 6" lift with nice, flat CV angles. The downside is that it permanently changes some stuff on the truck that you may not want, and if you move to a state with vehicle inspections it may not pass safety.
    That oil could be from anything. I'd investigate further before even considering buying that truck. Do you have a local independent Toyota mechanic near you? Best thing would be to pay them a few bucks to look everything over, especially the stuff mentioned so far in this thread.
    Ngneer likes this.
  7. Jan 16, 2025 at 7:02 AM
    tacotoospicy
    tacotoospicy Well-Known Member
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    Is it 4x4??
    Also, rough country isn't the absolute worst if you do end up deciding to keep it. Take it for a test drive and see how it handles/rides, could end up liking it
    Big tall dave likes this.
  8. Jan 16, 2025 at 7:29 AM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    When you(4th owner) go to sell it, many will pass with it having had 4 owners. The price would have to be great to make up for that possible loss on the backside
  9. Jan 16, 2025 at 7:30 AM
    eurowner
    eurowner Duke Sky
    Scoty
    @pvanzee82 post a link to the truck so we can better help
    pvanzee82[OP] likes this.
  10. Jan 16, 2025 at 7:40 AM
    pvanzee82
    Pete
    Iowa
    I returned the truck yesterday so no photos available.
    It's likely 3-4" lift kit. CV angle aren't flat, but the wheel are surprisingly aligned despite the OEM UCAs.
    Overall, I like the truck but hate the mods and questionable history.....and maintenance. Appreciate the insight!
  11. Jan 16, 2025 at 7:45 AM
    pvanzee82
    Pete
    Iowa
  12. Jan 16, 2025 at 7:48 AM
    pvanzee82
    Pete
    Iowa
    Yes, it 4x4. I posted a link to the listing. I drove it for two days and it seems normal.
  13. Jan 16, 2025 at 7:50 AM
    pvanzee82
    Pete
    Iowa
    That's a very valid point. Even if i keep it for another 100k miles, it's still 4 owners.
  14. Jan 16, 2025 at 8:10 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Would be nice if you could contact the previous owners and get their take on it.
    For a few dollars more could you find a 2023 out there, preferably with no mods on it?
    pvanzee82[OP] and BabyBilly like this.
  15. Jan 16, 2025 at 8:51 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Definitely check these! Especially the coolant crossover pipe, since it was low on coolant. Since it was low on something so obvious,, I am already skeptical of the seller/dealer.
    Also it is missing a center cap,, not a big deal, just shows the seller/dealer's lack of attention, and makes me think they're hacks.
  16. Jan 16, 2025 at 9:31 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    The biggest issue I have run across being in the business, is people not getting a full vehicle pre purchase inspection, and finding out later the vehicle had been wrecked or damaged in other ways, that means putting on a rack and lifting and pulling all the wheels and looking at everything including junk yard parts, now they probably will not check the ATF due to time, but they should check the levels of any and all other fluid levels, this includes a test drive and checking for pending and or history codes, looking for frame damage/repair, newer welds etc etc etc, you will have to pay for the inspection, but better to inspect no rather than find out later.... A Carfax report ONLY shows what has been reported by the dealer, my cars have all been serviced properly by the business that I just retired from, but no Carfax report on any of them... I bought a vehicle a few years ago that had been wrecked but the Carfax was clean, I bought it from Toyota used, I showed them where the repaired damage was and they couldn't believe it (it was what I was looking for lol)... So get any used vehicle checked out by YOUR mechanic of choice not theirs...
    wayne0, BillF1564 and BabyBilly like this.
  17. Jan 16, 2025 at 10:02 AM
    pvanzee82
    Pete
    Iowa
    100% agree. Carfax is far from the whole story as they like to emphasize "reported".
    DavesSR5[QUOTED] likes this.
  18. Jan 16, 2025 at 10:16 AM
    pvanzee82
    Pete
    Iowa
    I couldn't agree more. They're knock-off TRD rims because they're 18" and that style only comes in 17". Also says "Not OEM" on the inside. I located the mfg and they don't sell caps separately.
    This dealer has mixed reviews, but the bad reviews seem legit.
    WAY too many red flags on this truck.
  19. Jan 16, 2025 at 10:18 AM
    pvanzee82
    Pete
    Iowa
    Appreciate the feedback, everyone! I need to trust my gut. Didn't feel right from the beginning. Onto the next one!
  20. Jan 16, 2025 at 10:24 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    If they can’t even do an oil change without cleaning up the mess what’s that say about the rest of the truck. I’d wanna know what’s up with the oil on the skid. My truck just turned 49k and you can eat off the skid
