3 plugs on transfer case?
Discussion in '1st Gen. Tacomas (1995-2004)' started by matthew5olson, Mar 17, 2010.
  1. Mar 17, 2010 at 11:57 AM
    matthew5olson
    matthew5olson [OP] Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I was under the truck just now and saw what looks to be a fill plug on the transfer case. It is right underneath the shift lever on the top of the transfer case.. I thought the 2 plugs on the back side were the drain and fill plug. what is this? thanks
  2. Mar 17, 2010 at 1:29 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Don't touch it! It could be the Jesus bolt!
    Uh, I think it may be the "restrict pin"? see attached FSM page. I can't quite tell what it would be restricting.
    Oh crap, you said transfer, my bad...try this one instead. Looks like optional ports for AT neutral and one-touch 4WD sensors?
  3. Mar 17, 2010 at 5:22 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Hey, man, I gave you tranny info, not transfer info :frusty:...my bad, please see edited post...
  4. Mar 17, 2010 at 6:16 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    Ok whats the problem. the transmission and the transfer case each have their own fill and drain plugs.
    maybe im just reading this wrong or somethin. The fill for the transfer case is on the driverside of the truck,the drain is at back of the transfer case at the bottom.
    thats how it is on the 2002s anyway,doubt they changed it
