3." Pro Comp 4WD suspension lift kits
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXPROMAN, Feb 24, 2013.
  1. Feb 24, 2013 at 7:44 AM
    TXPROMAN
    TXPROMAN [OP] Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    If I go with 3." Pro Comp 4WD suspension lift kits. Do I need to install a differential drop kit & skid plate leveling kit for 2012 tacoma ?
  2. Feb 24, 2013 at 9:18 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  3. Feb 24, 2013 at 9:21 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Op go with either 5100 or old man emu I would stay away from procomp my opinion
  4. Feb 24, 2013 at 9:24 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I wasn't gonna say anything... but I agree. I actually just made the switch from my pro comp 3" kit to my OME setup a couple weeks ago and its like night and day. 400 bucks more and you gets a much better ride, longevity, and performance. In running OME shocks, 885's, and the icon 3 leaf progressive pack.
  5. Feb 24, 2013 at 9:26 AM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    I have a 6" procomp lift. absolutly love it.
    If I could go back though I would get an OME for sure. The OME lift gets you more clearance under the crossmember. And its less expensive.
  6. Feb 24, 2013 at 9:40 AM
    BAMFTACO
    Juan
    Kings bruh
    I had thepro comp 3 inch lift also and barely had it for a year the rear shocks started leaking and the front the bottom bushing that bolts up to the lower control arm started to come off. If your only street go for it but offroad wise don't get it.
    If i had a Drop braket lift id put some Icon/king coilovers up front the procomp coil overs don't ride that nice.
  7. Feb 24, 2013 at 9:41 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Thats exactly what happened to Moose with the lower bushing failure
  8. Feb 24, 2013 at 9:45 AM
    BAMFTACO
    Juan
    Kings bruh
    I got lucky because I found a great deal on my sway aways when I was removing my old procomp shocks I notice that.
  9. Feb 24, 2013 at 10:11 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yup. Heres what they looked like after a few years of use.
  10. Feb 24, 2013 at 10:17 AM
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    I bought a pro comp kit around a year ago for my 06 it's a decent kit for the look. Not to bad of a ride and fairly easy to install. Honestly tho I'm already looking around for upgrades on front and rear shocks. I'm thinking 5100 billies on the front and 5160s on the back.
  11. Feb 24, 2013 at 10:23 AM
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    WOW!!!:eek:
    Thanks for the advice guys ! I hate to throw money away. I will look into 5100's and ome !
  12. Feb 24, 2013 at 10:30 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    For sure. Honestly id go OME over Billy's any day.
  13. Feb 24, 2013 at 10:41 AM
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    Thank's I will look up OME.
  14. Feb 24, 2013 at 3:07 PM
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    Do I need to install a differential drop kit for the ome 2.75 with 886's I have a winch and bumper to install.
  15. Feb 24, 2013 at 3:13 PM
    PLC721
    Patrick
    Chandler, Az
    No! Diff drop = BAD!!!
  16. Feb 24, 2013 at 3:25 PM
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    Thank's Man !
  17. Feb 24, 2013 at 4:56 PM
    ImplicitlyAlberta
    David
    edmonton
    Thats the route that I will be going in the next year.
    Explain. I dropped down the diff and got the drive shaft with the extra union for added articulation. Ive had no issues.
  18. Feb 24, 2013 at 5:08 PM
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    Do you have to drop the carrier bearing with a 3." lift ?
  19. Feb 24, 2013 at 5:46 PM
    BAMFTACO
    Juan
    Kings bruh
    It makes the mounts lower there's a thread bout it. A member hit a rock with it and totally fucked up the mounts
  20. Feb 24, 2013 at 7:58 PM
    ImplicitlyAlberta
    David
    edmonton
    Oh yeah. Skid plates are definitely necessary.
