3" Pro Comp coil spring replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco_Ted, May 31, 2017.
  1. May 31, 2017 at 3:36 PM
    Taco_Ted
    Taco_Ted [OP] Member
    Ted
    06' Tacoma 4x4
    16'' AMR wheels 3" Pro Comp Lift Custom PNW Bedside Decals
    I'm one of those guys that made the mistake of buying the 3'' Pro Comp lift kit without doing proper research first. The spring rate, as many of you know is WAY too heavy/aggressive.
    I wanted to know if anyone out there has kept the struts and put a different coil spring on? Like an OME or Eibach coil spring? what will fit?
    Obviously what I need to do is buy some billy 5100s and some OME springs... But I wanted to buy the springs now and then buy different struts down the road when I have the money.
    I've searched all TW threads high and low and couldn't find an answer to this. even emailed Pro comp and couldn't get an answer out of them.
    Thanks guys.
  2. May 31, 2017 at 10:03 PM
    Humblesojah
    Humblesojah New Member
    Marc
    808 --> 702
    06 dbl cap
    Interested too. I have es9000. Thinking of just going with maxtrac spindle lift
  3. May 31, 2017 at 10:53 PM
    1largemouth
    1largemouth Well-Known Member
    Martinez CA
    06 Tacoma
    Sorry to hear that, I have been down that road as well... Whats the spring rate on those 700lbs? Talk to the guys at wheelers offroad, they are pretty helpful.
    Steel bumper&winch would help:yes:
  4. Jun 1, 2017 at 3:59 AM
    Taco1999
    Taco1999 Well-Known Member
    Jeremy
    Slidell, Louisiana
    2014 Tacoma Double cab 4x4 trd
    Can't wait to get rid of my procomps......Ride is stiff as concrete. Swaped my rear to OME,just have to do the front.
  5. Jun 3, 2017 at 5:30 PM
    Taco_Ted
    Ted
    06' Tacoma 4x4
    Did you swap out the rear with the Dakkar? I was thinking of replacing the front first, then the rear. Any particular reason you replaced the rear first?
