3 questions on 285's......
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bdunna, Nov 16, 2015.
  1. Nov 16, 2015 at 2:22 PM
    bdunna
    bdunna [OP] Well-Known Member
    2005 tundra access cab
    Does it require new wheels?
    Do I need a lift?
    Do you need to regear? If so, I'm out.
  2. Nov 16, 2015 at 2:25 PM
    GuitarGuy91
    GuitarGuy91 Well-Known Member
    Stephen
    Glenville, NY
    16 TRD OffRoad Acc Cab (ordered)
    New wheels is preferred with a better offset, or spacers, which I think is bad for the axle or something.
    I would say 3" lift would make it look better and wayy less rubbing.
    You don't need to regear, but if you don't your truck will feel like it's lost a lot of power.
  3. Nov 16, 2015 at 2:26 PM
    SanClementeTac01
    SanClementeTac01 Well-Known Member
    Dylan
    San Clemente, CA
    2001 Tacoma 4cyl manual 4x4 275k miles
    Fox 2.0 TRD Rear Diff Locker KM2's Snugtop Shell
    285 is the height of the wheel. You probably need a lift to fit those. New wheels are not required. You may need to regear depending on your truck, but probably not. I don't know too much about regearing but i'm sure someone with more knowledge will respond with better answers than me. Also, Look it up in the Search box in the upper right hand corner of this webpage.
    Cohutta likes this.
  4. Nov 16, 2015 at 2:27 PM
    bdunna
    So the thread can be deleted. It's 265 70 17 for me.
  5. Nov 16, 2015 at 2:31 PM
    ridez
    ridez Well-Known Member
    vancouver bc
    2016 white DCLB TRD sport with upgrade package
    OME 887s, 5100s, deaver AAL, light racing UCAs
    285 is not the height, it is the width
    ToyFXR88, Tomass321, Doggman and 4 others like this.
  6. Nov 16, 2015 at 2:31 PM
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    Don't assumptions: you mean 285/70R17.
    I don't think you need new wheels.
    I did anyway. Pretty sure the 17 inch stocks will work. Yes you need a lift. I have 2.5 front and 2 rear and I had to remove the front flaps. No you do not need to regear. I am assuming you have a 4.0. Note it will feel different, first thing I noticed was the feel of the acceleration, seemed like it works a bit harder with 285s. No big deal just want you to know it will feel different.
    blens likes this.
  7. Nov 16, 2015 at 2:32 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Maybe post the actual size of the tires, just a thought.
  8. Nov 16, 2015 at 2:33 PM
    SanClementeTac01
    Dylan
    San Clemente, CA
    I screwed up, again! Damn... I'm pretty new to this and trying to figure it all out...
  9. Nov 16, 2015 at 2:34 PM
    ridez
    vancouver bc
    no worries, this is my first tacoma and I've been scouring the forums here for hours at a time
    SanClementeTac01 likes this.
  10. Nov 16, 2015 at 2:35 PM
    Nighthawk
    Levi
    Casper Wyoming
    There is no 2016 4.0
  11. Nov 16, 2015 at 2:41 PM
    josh843
    josh843 Well-Known Member
    Josh
    moncks corner, sc
    2001 reg cab prerunner
    285/70/17s with bilstein 5100 set to max. like 2.5" i think and nothing in the rear
    no rubbing/ no spacers
    2.7L and i could catch 2nd if i wanted to...
    biggest thing youre going to notcie is gas milage suffering.
    and theyre right. 285=285mm its called thr aspect ratio or something. second number is a % of first number and second number and that determines sidewall height. third is of course wheel diameter.
    PapaRee likes this.
  12. Nov 16, 2015 at 2:46 PM
    bdunna
    I was under the impression the sidewall height was the first # in regards to the second (width) and lastly the wheel size.......
    So 285 taller, 265 shorter....
  13. Nov 16, 2015 at 2:52 PM
    bdunna
    So I see from the chart. That clears up a few things. Was hoping to lift front an inch and do 2 up size tire. I up for me. Looks like 265 70 17.
  14. Nov 16, 2015 at 3:02 PM
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Does anyone know for sure if the '16 sport rims are 7" or 8"? The owners manual says a casting # on the wheel determines the width. J=7" JJ=8". So far I havent found the casting without taking a wheel off. I want to go with TRD SEMA black wheels, but need to verify the sizes before I get something I will be forced to lift the truck, which I am not willing to do.
  15. Nov 16, 2015 at 3:49 PM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Stomper Toyota on 285s. Foam tires in the rear FTW!
    proven21 likes this.
  16. Nov 16, 2015 at 5:34 PM
    bdunna
    I remember these. You must be at least 40. They did crawl up about anything or tip over on their backs. Nice foamy tires too....
    Dean724[QUOTED] likes this.
  17. Nov 16, 2015 at 8:17 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    What's important to you OP? Having tires that are 285mm wide or 33" tall tires? You could always go with a 255/85R-16 or 255/80R-17 tire. The BFGoodrich KM2 and Cooper S/T MAXX are manufactured in such sizes. Depending upon the terrain you intend to traverse, a narrow tire may be beneficial.
  18. Nov 16, 2015 at 9:03 PM
    808tacodude
    808tacodude Well-Known Member
    2016 MGM Tacoma TRD Sport 4x4
    First of all, this is not my truck. I saw it at the dealership and had to take a closer look.
    This is a Revtek 3' spacer lift with a block in the rear but he is running 285/55/20 (about the same size as 285/70/17). And there isn't any rubbing.
  19. Nov 16, 2015 at 9:07 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Too much grille action :stirthepot:
  20. Nov 16, 2015 at 9:57 PM
    Markc1024
    Markc1024 Well-Known Member
    TRD Sport has 17x7.5" rims.
