3" Rear Lift setup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aubi1414, Jul 31, 2015.
  1. Aug 4, 2015 at 12:21 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    I have run both the ap stds and the expos and didn't find either one that stiff. I ran the longer bilsteins in the rear on both sets. BE5-B110-T5.
  2. Aug 4, 2015 at 12:25 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Which set of AP's did you prefer? I am thinking about getting some. Haven't done too much research yet just have heard good things. Do they both provide the same amount of lift/ how much lift?
  3. Aug 4, 2015 at 12:27 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Standard - 3"
    Expos - 4"
  4. Aug 4, 2015 at 12:30 PM
    Nighthawk
    Levi
    Casper Wyoming
    Thanks for the info, I guess the 3" may be the way to go since I only have 3" in the front.
  5. Aug 4, 2015 at 12:33 PM
    BORNWILDGUY
    Rich
    Florida
    If I had to do again would go with the expos.
  6. Aug 4, 2015 at 12:34 PM
    geekhouse23
    If I went AP, I would have gone this route too
  7. Aug 4, 2015 at 12:43 PM
    Nighthawk
    Levi
    Casper Wyoming
    I have 5100 Billies cranked up to 3" in the front, with 2" aal in the rear and it sits about level now. Wouldn't the expos bring the ass up way too far? Also what kind of shims would I need to look in to with the AP's? Sorry for all the questions, didn't mean to highjack this thread.
  8. Aug 4, 2015 at 12:46 PM
    aubi1414
    aubi1414 [OP] War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    I don't need expos in the rear with 4" of lift. Need more in the front as it is lol
  9. Aug 4, 2015 at 12:47 PM
    aubi1414
    Justin
    Pensacola, FL
    Just depends what you like that would be pretty big rake in the rear 1.5" - 2" depending on what all you have in the back of the truck if anything.
  10. Aug 4, 2015 at 12:50 PM
    Nighthawk
    Levi
    Casper Wyoming
    Will be a pack rack w/ RTT and high clearance rear w/ swing out tire carrier eventually. But until then she would sit ass up really bad I would think haha
  11. Aug 4, 2015 at 1:02 PM
    aubi1414
    Justin
    Pensacola, FL
    Yeah that'll probably decrease it close to an inch. I never have had that much on mine so just guessing
  12. Aug 4, 2015 at 1:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Just be careful with the B110's their collapsed length is pretty long and will likely bottom before hitting bumpstop. Simple measurements would let you know if you needed to extend your bumpstop or not.
  13. Aug 4, 2015 at 7:11 PM
    LikeABoss4x4
    LikeABoss4x4 Well-Known Member Vendor
    Sarah
    So Cal
    I ran the Fox click adjuster version on my Tacoma, so I was able to dial in the ride, but I currently run a similar shock as those 2.0s you mentioned on my lifted '10 Tundra along with Fox front coil-overs and no complaints about the ride both on and off road. If you're unhappy with Icons digressive valving, then the Fox might provide a more preferable ride. I'm showing those Fox shocks provide 9.6" of travel, which should work out perfect with the AP springs. We are still adding Fox products to our site, but we do have a forum discount. Also worth mentioning are the Bilstein 5160s, which we also run on our own leaf sprung trucks. We like them because of the amount of travel you get with the short body design.
    Yota64 likes this.
  14. Aug 5, 2015 at 10:49 AM
    aubi1414
    Justin
    Pensacola, FL
    Awesome!!! Thanks for that reply. I was needing to know if those would fit my lift so great :) Do you know if that one I listed above comes with the CD adjuster 8 clicks?
  15. Aug 5, 2015 at 2:33 PM
    #35
    LikeABoss4x4
    Sarah
    So Cal
    No, those don't have the click adjuster... I believe AP sells those exclusively. However, since they are vehicle specific, they will be valved for Tacomas riding on rear leafs versus a universal application or one adapted from another vehicle like an FJ Cruiser or 4Runner that is coil sprung.
  16. Aug 5, 2015 at 2:44 PM
    #36
    Wgh0805
    Wgh0805 Member
    Willis, TX
    2019 TRD OR DCLB
    2019: Front: +2 TC Expedition Long Travel Kit with Fox 2.5 CO's - Install In-Process Rear: Stage 2 Deaver Leafs, Accutune 2.5 Fox Race Series, BAMF HD Shackles RETIRED: '13 4x4 Fox Remote Resi-Coilovers, Fabtech UCA's, Fox Resi-Rear Shocks, AllPro Standard Leafs. 33-12.50-18 TOYO RT's - LOTS of Rubbing AFE CAI
    I have the Tacoma specific fox rears from AP. They are nice and I have them on the lowest setting.
  17. Aug 6, 2015 at 7:52 AM
    #37
    aubi1414
    Justin
    Pensacola, FL
    Would I need a 26" rear shock extended length with my 3" lift?
  18. Aug 6, 2015 at 8:01 AM
    #38
    Yota64
    Yota64 Professional Threadjacker
    I don't know this for sure so someone feel free to correct me but I have read on TW that the CV axles are actually not hurt by increasing angles, but that the boots tear more which there is a fix for.
    If that is false I would love to know why
    What makes you say that? Aren't they stiffer?
    I do it all the time. By the way, 5100s have 4 settings, 0.0", 0.85", 1.75" and 2.5". If you don't have a spacer maybe either you are actually at 2.5" of lift, or your truck is lighter than most, which is possible if you are either a 4cyl or 2WD.
  19. Aug 6, 2015 at 8:14 AM
    #39
    Nighthawk
    Levi
    Casper Wyoming
    Nope, 4WD V6. They are set at 2.5" but the coilovers come from Toytec w/ a 0.5" spacer on top. At least w/ the kit I bought (wish I wouldn't have went with a kit). I have a tendency to do things the wrong way the first time, and learn the hard way every time lol.
  20. Aug 6, 2015 at 8:17 AM
    #40
    geekhouse23
    Simply weight capacity. I hail quite often and when I do, it is a lot of weight. I have the Dakars now with the D29XL AAL.
