3'' spacer lift. who has em'??
Discussion in 'Suspension' started by prerunner05, Nov 14, 2009.
  1. Nov 14, 2009 at 2:06 PM
    prerunner05
    prerunner05 [OP] Well-Known Member
    David
    middlesex,va
    05 prerunnerSR5 5spd
    265/65/r17 . fog lights. secondary air filter removal,AFE Pro S dry drop in. double din navigation HU 6.5" componet speakers in the back
    So who on here has a 3'' front spacer lift on there truck? Have you noticed any changes/bad vibes etc...?? or are you satisfied with the decision you made with the spacer lift? lets see pics and hear the in and outs of this lift kit!!
  2. Nov 14, 2009 at 2:12 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Spacer kits are known for their horrible ride quality... I'd say completely skip the spacers at all costs... :)
  3. Nov 14, 2009 at 2:13 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i had a 2.5" spacer lift on my 07 prerunner and a 3" at one time on my 09 4x4. less to worry about being 2wd. and mine werent that bad of rides
  4. Nov 14, 2009 at 2:15 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    I'm running the 3" toytec spacer lift. It definitely stiffens up the ride! They're actually gonna be coming off VERY soon, as i just purchased some coil overs.. I'd say skip the spacers and get coilovers
  5. Nov 14, 2009 at 2:16 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I would just go with the 5100's and start from there but spacers arent to bad of a ride from what I have experienced on the road in my buddies taco.
  6. Nov 14, 2009 at 2:22 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I have a 3" spacer and it is not a good ride by any means. It is very stiff. I regret putting the kit on, which will be coming off soon :yay:
  7. Nov 14, 2009 at 2:26 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I have a 2.5 inch spacer kit, and I like it, rides not to bad
  8. Nov 14, 2009 at 3:58 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    had it.dont reccomend it.save up and get the good stuff.
  9. Nov 14, 2009 at 4:06 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I'm rockin a 3" lift and I have no ride issues...I mean don't get me wrong its different than stock but nothing crazy...Plan on getting rid of the spacers soon though anyhow and rollin with the Billy 5100s and OME 885 Coils :)
    Edit: The reason I went with the Spacer kit is because i'm not gonna be wheelin hard since my truck is only a TRD OR PR :cool:
  10. Nov 14, 2009 at 5:52 PM
    prerunner05
    David
    middlesex,va
    thats the thing i do some mild offroading but not very often. not many places to go anyway plus only prerunner. just a daily driver to and from work and out to wherever. also i talked to my local auto performance shop and he told me to go with the 5100 adjustables with a 1/2 inch spacer on top with aal in the rear. what do you guys think of that??
  11. Nov 14, 2009 at 6:40 PM
    The_Hodge
    SC
    that would work as well and also should ride better
  12. Nov 14, 2009 at 7:17 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I originally wanted the truck level, and had a 3" spacer up front with a 2" aal in back. After deciding a like the look of a bit of a rack, I switched out the front spacer to a 1.5". The truck seemed to be floating before, and the cv boot ribs were rubbing...even with the differential drop. Now it actually rides pretty good, and no more worries about the boots tearing. I plan on upgrading to a better set up when it's time to get new tires and shocks...
