3" Spacer lift!
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigcountry, Jan 29, 2010.
  1. Jan 29, 2010 at 6:19 PM
    bigcountry
    bigcountry [OP] Member
    Eric
    Mid.Ga.
    95.5 Taco 4x4
    Hi guys new here on the forum.. I bought a set of tires from a guy and he threw in a set of these spacers for my 95.5. Well finally after compressing the springs and alot of help and cussing I got the upper ball joint back on. But I dont think something is right... Should my upper A arm be down that far, and it looks like the spindle arm at the upper ball joint is going to hit the coil spring. What do you guys think? This is the right side.. I put the tire back on and put the weight of the truck back on it and it didnt move very much. I havent finished with the drivers side and didnt want to attemp to get it back together until I got some opinions on the right. What do you think?
  2. Jan 29, 2010 at 6:35 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    it looks like a top mount spacer and not a pre load spacer... if thats the case, yes, the upper control arm will sit at that angle with the truck up on jacks...
    the spacer adds a few extra inches to the overall length of the strut assembly... it increases the distance between the upper and lower control arms...
    to be sure, did you need to take the strut assembly apart to put these spacers on top of the coils or did they attach on top of the coil and strut assembly?
    its been a while since i seen a spacer lift up close...
  3. Jan 29, 2010 at 7:16 PM
    bigcountry
    Eric
    Mid.Ga.
    95.5 Taco 4x4
    Well from what I was told I didnt have to compress the coils to mount these, but i dang sure had too to get the upper ball joint to mount.. The spacers went on easy, used the factory nuts to mount spacer to the top plate and just turned the shock 180 and it bolted back in place.
  4. Jan 29, 2010 at 7:31 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    then yes, thats a top mount spacers...
    they aren't exactly the most effective lifts for 1st gens...
    search "top mount spacers" on the various tacoma boards and you will find a number of threads about it...
    due to the size of those spacers, your upper control arms will pretty much be maxed out like that, and if you wheel the truck, you risk the same overextension of the lower control arms...
    if not careful, you may damage both the upper and lower joints...
  5. Jan 29, 2010 at 10:35 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah! I hear those type of lifts at that hight are the worst for your U/Lower joints.
  6. Jan 31, 2010 at 7:34 AM
    bigcountry
    Eric
    Mid.Ga.
    95.5 Taco 4x4
    ok i already have the aals from toytec. What should I put on the front to run 33x10.50x15s. I cant afford the Ultimate lift right now. Will the OME882 front coil give me enough lift..and do I have to change front shocks with these?
  7. Feb 1, 2010 at 10:02 PM
    nicoolasm
    nicoolasm Mob it
    Nick
    Orange County, California
    09 Tacoma TRD Sport Magnetic Grey
    would the total chaos uca's work well with the 3in spacer...?
  8. Feb 1, 2010 at 10:11 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    UCA won't soften the ride of the spacer...
    if spending all that money on an aftermarket UCA, then do the suspension right from the start...
    you can also get away without the UCA on a 1st gen...
  9. Feb 3, 2010 at 5:28 PM
    bigcountry
    Eric
    Mid.Ga.
    95.5 Taco 4x4
    yea definately gonna scrap these spacers on go with thee 882 coils
  10. Feb 4, 2010 at 10:34 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Go with the 882's w/ OME Nitro front shocks.
  11. Feb 5, 2010 at 9:56 AM
    nicoolasm
    nicoolasm Mob it
    Nick
    ok cool thanks guys
  12. Feb 5, 2010 at 10:05 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    hey Nick... i replied to you earlier thinking you were the OP with the 1st gen... noticed you have a 2nd gen...
    aftermarket UCAs would benefit you, but with the money for them, consider getting into a full coilover with it to get the most out of your suspension...
  13. Feb 5, 2010 at 11:47 AM
    nicoolasm
    nicoolasm Mob it
    Nick
    yea im saving money for the fox 2.5's and tc uca's...just a matter of time
  14. Feb 6, 2010 at 6:14 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    that looks big time fucked up
