3" Suspension Lift With 1.5 Body Lift Tire Size?
Discussion in 'Suspension' started by 05Wheeler, Dec 11, 2011.
  1. Dec 11, 2011 at 12:42 PM
    05Wheeler
    05Wheeler [OP] New Member
    Devon
    Coquitlam
    05 Toyota Tacoma
    Cold Air Intake System, HID Headlights, Flowmaster Dual Exhaust System
    I am wanting to do a 3" suspension lift on my 05 toyota tacoma. The recommended tire size is 31". So my question is if i put an 1.5 body lift in will i be able to fit 33's or 35's?
  2. Dec 11, 2011 at 12:43 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    5 or 6 lug? with a 6 lug and 3" 285's fit with trimming
  3. Dec 11, 2011 at 12:45 PM
    05Wheeler
    Devon
    Coquitlam
    05 Toyota Tacoma
  4. Dec 11, 2011 at 12:47 PM
    08pretaco
    Oliver
    az
    you should be fine running a 285/75/16 with a 6 lug 3" lift. You will have to do some trimming and possibly a cab mount chop if you wheel the truck.
    which company says a 31" will fit on their 3" suspension lift btw?
    oh and mind you if wanting to run a full 3" lift you will more than likely have to get new upper control arms to allow for caster change. you will also need to either get wheels spacers for stock wheels or get proper backspaced aftermarket wheels to prevent rubbing and allow proper fitment.
  5. Dec 11, 2011 at 12:53 PM
    05Wheeler
    Devon
    Coquitlam
    05 Toyota Tacoma
    ok sweet thankyou....rough country is saying that for the recommended tire size. If i want to go with 20's will the same apply?
  6. Dec 11, 2011 at 1:00 PM
    08pretaco
    Oliver
    az
    may I ask why you are looking at rough country? 1st kit you came across/price?? there are a lot better quality lift out there.
    Instand being you want to stay away from spacers. I would recommend going with 5100 bilsteins all the way around. Set the front shocks to 2.5" and get the toytec top plate spacers to get you to the 3". You will be a lot happier with that is my guess. Wheelers sells rear add a leaf kits.
    Front and rear shocks ~275
    top plate spacer ~ 42-52
    AAl 1.5 or 2" ~ 75
    Upper control arms ~420-600
  7. Dec 11, 2011 at 1:05 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I agree, you should be really happy with this set up.
  8. May 1, 2012 at 12:36 PM
    jockfro
    jockfro New Member
    Scott
    Andover, VT
    07 4x4 LB TRD Sport
    I would like to do the same thing here. I posted this on the 1" BL thread. I am currently running 285/70/17s on my 07 DC Long Bed 4x4 with Dick Cepek DC1s 4.5" backspacing with 3" of lift. The reason I want to do this is because I want to run a true 33/12.50 or possibly a 33.5. I have VERY minimal rubbing on plastic now after trimming, so it seems to me if I go up 1.5" and go with a 33/12.50 or even a 33.5 I should be ok. I read somewhere to watch the rubbing on the frame. Can anyone speak about this? Don't want to go full 6" lift. I personally think 33s look a little small on a 6" lift. By the way, I'm looking to go with Mickey Thompson MTZs or possibly Toyo open country MT. There is one that measures 33.5, not sure of the actual measurements. Thanks for any help...
