3" suspension lift
Discussion in 'Suspension' started by jwp164, Jun 8, 2008.
  1. Jun 8, 2008 at 7:11 PM
    jwp164
    jwp164 [OP] Member
    I am getting a 2008 Tacoma here shortly and already have on order a 3" lift kit that has add-a-leafs for the back and a 3" strut spacer for the front, the truck stock I think has 265/70R17 tires/wheels, will I be able to fit a 285/75R16 with any problems after the lift? I think that conversion comes out to like a 33"X11" right? I do not wish to do any trimming since the truck will be brand new, and with the add-a-leaf in the back, will the stock Bilstein shocks in the rear be sufficient or will I need to upgrade to a longer shock? The kit also comes with a differential drop so I will not change the angle of the front axles.
  2. Jun 8, 2008 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Even with the diff drop, it will change the angle of the axel. The OEM Bilstiens are not made for a lift, and you may have an issue with the shocks "topping out". A simple switch to some 5100's should fix the problem. AS for the tire size, you will have some rubbing, but to what degree depends on the wheel back space, and such. :)
  3. Jun 8, 2008 at 7:20 PM
    jwp164
    jwp164 [OP] Member
    Thank you, the wheels I think I am going to get are moto metal 16X8 that have a 4.5" inch backspacing, the 5100's are those made by Bilstein?
  4. Jun 8, 2008 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. And they are a VERY good shock. :)
  5. Jun 8, 2008 at 10:23 PM
    skierpunk
    skierpunk Well-Known Member
    Oregon
    08 DC Off Road.
    TRD mats and seat covers, smoked tail lights, smoked turn signal corners, Revtek lift, Access LE tonnaeu, HIDs, grillcraft mesh grill, TRD CAI, custom bike racks, Alpine system.
    I'm also about to get a lift on my o8. Are most people swithing out for the 5100 or remaining stock?
  6. Jun 9, 2008 at 4:14 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    You will rub with a 285/75 no matter what wheels you are. Trimming is going to be necessary. Its not that much. You could go untrimmed and see where you have a problem area and then just trim there. That way you don't do anything that you don't have to.
