$3 Tacoma voltmeter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowrx, Mar 25, 2013.
  1. Mar 25, 2013 at 1:04 PM
    snowrx
    snowrx [OP] Active Member
    Priest Lake
    '13 Blue Off Road V6 6Spd
    H4 H9 bulbs,Hidden Warn M8000, Bed & hood lights, clock panel voltmeter,
    Annoyed with Toyota for all the widgets that my '91 had that they could not manage to install on the much more expensive 2013, I put one in my clock panel. I found a little .36” voltmeter module on Buyincoins.com for $2.94. Item (P011851). My detailed install doc is too big to attach, so I'll summarize with a few pics.
    Pull stereo panel, pop clock panel out of back.
    Pull hazard switch out of front (pops out)
    Pull rear cover screw, release tabs and pop out rear PCB
    Unscrew clock to get it out of the way
    Carefully pry off front panel with a putty knife. (Held with double stick tape)
    Cut opening to fit voltmeter module behind silly car icon
    Mask and strip black paint from rear of front panel to make clear opening for the display. I used brake cleaner and electrical tape.
    Pick up power and ground from existing pins on PCB and solder voltmeter leads.
    Reassemble. Very clean, no new wires or connections.
  2. Mar 25, 2013 at 1:08 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    That's a new one.. Nice job
  3. Mar 25, 2013 at 1:13 PM
    Large
    Large Red
    That's pretty sick
  4. Mar 25, 2013 at 1:16 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  5. Mar 25, 2013 at 1:18 PM
    snowrx
    Priest Lake
    You'll see in the pic's that you can retain your flashing key LED if you wish by relocating it with a bit of wire and drilling another hole in the housing behind the front cover.
    You'll want to put a bit of tint between the display and the front lens so you don't see the segments when it is powered off.
    The module needs to have the mounting tabs cut off to fit between the clock and seatbelt LED. I secured it with some clear packing tape from the front and silicone globs at the rear.
  6. Mar 25, 2013 at 1:27 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Looks good I like the idea and the price is right
  7. Mar 25, 2013 at 1:31 PM
    snowrx
    Priest Lake
    Buyincoins has a variety of sizes and colors of these modules. I used blue as I have that undimmable audio display and blue/white dash lights. you can get green, red or yellow as well. You could do this to most any car with the tiny .36" display. You could just double stick tape it to the dash or under the instrument hood-
  8. Mar 26, 2013 at 6:26 PM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Extremely cool mod! Nice work!!!
  9. Mar 26, 2013 at 8:26 PM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    +1 rep for you sir!!!
  10. Mar 26, 2013 at 8:35 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    the other night i saw the pics on another thread and was going to ask to post pics on how you did it...very clean sir :thumbsup:
  11. Mar 26, 2013 at 8:53 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    yup and scangauge too...also my radar detector :cool:
    might add this to the top right infront of the lcd screen for the temp gauge :D
  12. Mar 26, 2013 at 8:59 PM
    offroadwonder
    offroadwonder Well-Known Member
    Jared
    Aurora, CO
    '10 Tacoma DCSB 4x4 TRD Off-Road
    Chopped mud-flaps (yup, I'm hardcore)
    Nice! Does it turn off with the truck or stay on? On second thought, you probably attached it to an accessory power source, so naturally it probably turns off...
  13. Mar 26, 2013 at 9:02 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    from looking at his 4th pic, he got the power directly from the board itself which imo would be the 12v for all the lights on that board (clock, airbag lights passenger seatbelt) so long story short, yup it turns off when the key is out
  14. Mar 27, 2013 at 8:38 AM
    snowrx
    Priest Lake
    If you want the voltmeter to stay on after the truck shut off, you could pull the power from the clock memory pin on the PCB instead.
    I would not suggest it unless you drive every day as it it will drain your battery. I think it was rated at 200mA, although that seems high to me.
    If you want to check the voltage without the key on, you could add a momentary push button switch to connect clock memory power to the voltmeter red wire, but I'd add a diode to avoid backfeeding the Accessory circuit and maybe blowing a fuse from the extra load
    Can anyone tell me if all the 2nd gen Tacomas use this same clock panel?
    Does $2.94 qualify as a cheap/free mod?
    ( I tested the current draw- it's only 7-8mA, ignore the 200 figure )
  15. Mar 27, 2013 at 8:52 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    only difference between the 05-08 and 09-13+ is that the 09+ runs on leds...everything else the same :thumbsup:
    and ya i think so.
  16. Mar 27, 2013 at 8:59 AM
    snowrx
    Priest Lake
    There seems to be some interest in this, here's some missing pic's of removing the tape and masking paint from behind the front lens and what the key LED looks like with power off.
    Be careful cutting away the adhesive tape, you don't want to scratch the front lens from behind!
    I had -just- drilled into the clear plastic a bit from the back to give a little diffuser effect for the relocated LED.
  17. Mar 27, 2013 at 9:06 AM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    So I might be missing it here but what is this for?:confused:
  18. Mar 27, 2013 at 9:28 AM
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Virginia
    It's a voltmeter for a simple way to tell exactly what voltage your battery is sitting at if i'm not mistaken. Someone correct me if i am wrong.
  19. Mar 27, 2013 at 9:29 AM
    CrazyCooter
    Johnathan
    Virginia
    sub'd +1 good sir, never even thought about doing this. I commend you and those with the creative minds like you.
  20. Mar 27, 2013 at 12:53 PM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    That's a pretty unique mod. Good job OP
