$3 Tacoma voltmeter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowrx, Mar 25, 2013.
  1. Mar 27, 2013 at 2:16 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    It used to be pretty standard equipment back in the day, but I really don't know what the benefit is... either your battery works, or you are looking for a jump... right?
  2. Mar 28, 2013 at 11:33 AM
    snowrx
    snowrx [OP] Active Member
    Priest Lake
    '13 Blue Off Road V6 6Spd
    H4 H9 bulbs,Hidden Warn M8000, Bed & hood lights, clock panel voltmeter,
    Either your alternator is charging, or you need to turn off all non-essentials and high tail it for home while the battery lasts, lest you be stuck at a repair facility not of your choice. Also If you're running accessories with the engine off you know when to start up and charge up. Those with a winch can really punish a battery and keep an extra eye of their charging system.
    Mostly I just want to be reassured all is well under the hood.
    WorldWar546 likes this.
  3. Mar 30, 2013 at 10:58 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    At 200 ma, you definitely want to power this voltmeter when the ignition is on to reduce the parasitic load on the battery, while the engine is not running. For temperature compensated battery State-of-Charge voltage measurements by battery type, please see Section 4.4 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org. If there is not an increase in voltage after the engine is running, the charging system should be tested ASAP.
  4. Mar 31, 2013 at 10:22 AM
    snowrx
    Priest Lake
    I checked the current on a spare unit, it's only 7-8 milliamps versus the 200 figure I saw on the website. You can't trust everything you see on the internet!
  5. Apr 1, 2013 at 7:10 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Thanks snowrx for correcting the 200 ma draw. 7-8 ma is much better. The 2% accuracy is not enough for an accurate State-of-Charge measurement, but is better that no measurement at all.
  6. Apr 2, 2013 at 5:52 PM
    snowrx
    Priest Lake
    Well for an accurate state of charge measure based on voltage, you'd have to have the battery at rest, disconnected without load or charging for a while, which is not likely to happen in our vehicular use. And being that most batteries these days are sealed away from prying hydrometers, we're kept mostly in the dark as to state of charge. I just want to know my alternator is doing it's job staying ahead of loads.
  7. Dec 18, 2014 at 3:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Very creative and well executed!
    Water temperature (the real temp, not what an idiot light that looks like a gauge shows) and voltage are two critical operating functions I want to monitor in any vehicle I have!
    I solved that issue by mounting a scan gauge II. That way I get all the stuff available anytime I want it, plus of course code reading/resets should any occur. Obviously my solution is not free/cheap. But it is fast/easy and transferable to another vehicle.
  8. Dec 18, 2014 at 5:01 AM
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    Do you see much voltage change?
    Just curious.
    Very Nice install.
    I rather more gauge info and a smaller tach.
  9. Dec 19, 2014 at 4:23 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Vehicle charging systems are temperature compensating, so the colder it is, the voltages will read slightly higher. When I first start my engine, I typically will read 14.00 to 14.30 VDC depending on the electrical load and ambient temperature. As the battery approaches a full charge, it will drop to 13.70 to 13.80 VDC range.
  10. Dec 19, 2014 at 4:36 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    I keep a voltmeter that plugs into the accessory sockets in the truck. Good alternative for people who dont want to tear apart their dash.
  11. Dec 19, 2014 at 10:36 AM
    snowrx
    Priest Lake
    I see a little wider spread than Shadetree, high 14's on startup and down to maybe 13.5-13.6 once the battery's charged and running the seat heat and headlights.
    I don't remember checking the actual voltage at the battery against this display with my good meter. I would assume some voltage drop through the small wires of the harness, but it's probably less than the accuracy of the voltmeter I used. I've seen some of the lighter socket units as much as a half volt off, so I always check them against a good DVM before use.
    Still, even a rough voltage will let you know whats going on with your charging system, so any meter better than no meter!
  12. Jan 29, 2015 at 1:59 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    Thanks for this, ordered a red one for $1.39
  13. Feb 22, 2015 at 9:19 PM
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
  14. Oct 13, 2016 at 11:11 PM
    WorldWar546
    WorldWar546 Baja Member
    Anthon
    Utah
    TRD Charged '14 Black TX Baja
    TRD Supercharger And a lot of rice n chrome
    Subbing for future reference! Awesome mod! :thumbsup:
