3 throttle position sensors in a month!
Discussion in '1st Gen. Tacomas (1995-2004)' started by JRtacoma99, Sep 24, 2015.
  1. Sep 24, 2015 at 12:15 PM
    JRtacoma99
    JRtacoma99 [OP] Member
    Florida
    99 Tacoma 5spd
    This month has been a weird one with my 1999 tacoma, I have gone through 3 TPS sensors. I have not actually tested any of them after pulling it off the truck but my computer continues to throw the code for it. I have heard some things about the IAC valve and I wasn't sure if that could be related to this problem in anyway. The truck has started to stall at red lights and is very sluggish on acceleration but after putting a new TPS in it stops all the problems. I just put a new PCV in today since it had never been changed and it was cheap, but problems continue. I need advice!!
    1999 toyota tacoma 2.4 2RZ
  2. Sep 24, 2015 at 2:14 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what brand sensors are you buying??
    I have found myself these trucks don`t like china built sensors
  3. Sep 24, 2015 at 2:20 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    happens to me and advance auto MAF sensors... I just stop in, get a new one free.
  4. Sep 25, 2015 at 8:27 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    You should just test them. It's pretty easy, just determine which wires are which and go from there. Should read near 5V, ground and something around .5V. You'll then want to probe the .5V and the ground and slowly phase your throttle from closed to wide open. You should expect to see a smooth increase from around .5V to around 4V (mine reads .5-3.5 on a 3.4L).
    Chances are it's not your TPS that's malfunctioning. I had the same issue recently, went through literally everything and just recently managed to get it sorted out. I would start by cleaning your throttle body and IAC. My guess is it's the TB but you may as well clean the IAC while you've got it off.
