3" vs 3 1/2"
Discussion in 'Suspension' started by LonghornTaco, Oct 15, 2008.
  1. Oct 15, 2008 at 10:13 AM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I'm looking at the adjustable coilovers from ToyTec and the 5100s set on the stock setting. The coilovers will adjust up to 3 1/2".
    I have read on this forum that once you go over 3", you start putting too much pressure on the CV joints (or something like that). But, will 3 1/2" really be that much different than the 3" when it comes to premature wearing on suspension parts?
    It should also be noted that I'm replacing my stock UCAs with the Total Chaos UCAs (if that makes a difference).
    Thanks!
  2. Oct 15, 2008 at 2:10 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    either way, u should be running a diff drop at anything greather than 2.5"
  3. Oct 15, 2008 at 4:26 PM
    LonghornTaco
    Minnesota
    Can you point me in the direction of information refarding dropping the differential on the Tacomas? And is this necessary or recommended?
  4. Oct 15, 2008 at 4:44 PM
    The_Hodge
    SC
    well if u dont want the cv's angle to be too great and cause problems, then i'd say they are necessary. if i were to do any lift to a 4x4 i'd do some amount of diff drop on them. its very cheap and takes 5 minutes to do. definately worth it
  5. Oct 15, 2008 at 4:46 PM
    LonghornTaco
    Minnesota
    I actually just found some information about it with a 3 minute search on the forum... Should have done that first! :)
    how much do I need to drop it? ToyTec offers a 1" diff drop. Is that enough for a 3 1/2" front lift? That's only in the front, right?
  6. Oct 15, 2008 at 4:52 PM
    The_Hodge
    SC
    yeah. i have the 1" diff drop on my 3" lift. should be fine. its unbelieveably simple to install. its basically a longer bolt w/ washers, a nut, and a 1" aluminum spacer on it
  7. Oct 15, 2008 at 4:54 PM
    LonghornTaco
    Minnesota
    Cool. Thanks for the info! I'll call ToyTec and have it added to my order tomorrow morning. Only $30.
  8. Oct 15, 2008 at 5:29 PM
    The_Hodge
    SC
    for sure...they shouldnt charge u shipping for it coming w/ another order either
