3 year old gas
Discussion in 'Boating & Fishing' started by Bryan07sport, Apr 16, 2010.
  1. Apr 16, 2010 at 4:04 PM
    Bryan07sport
    Bryan07sport [OP] Well-Known Member
    Bryan
    Newark, Delaware
    07 TRD Sport Access 6spd
    Hardwire GPS, 110v power outlet in cab, foglights anytime, mudflaps removed, pa-15 ipod interface, rear leaf tsb, URD short shift, integrated third brake/cargo light, ABS disable switch, BHLM, Dynomax super turbo muffler, Nitto Terra Grapplers 265/70/17, Front Bilstein 5100's at 1.75, Weathertech floormats, sockmonkey bedsides, bestop supertop, spidertrax
    Howdy. Just traded in the old 20' bowrider for a 23' chris craft scorpion. pretty cool boat. brand new jasper 350 crate motor, cammed, springs, lifters, high rise headers, thru hall, etc. anyway the boat was in storage for 3 years with half a tank of gas in it (70 gallon tank). It runs really good and strong, starts right up, but has a miss below 2000 rpms and is idling a little rough, which i'm attributing to the old gas. I was wondering if anyone knows of any good additive or anything i could add to the gas? if not do you think it would be better to run this gas out of it before refilling with fresh or just fill the tank with fresh now to dilute the shittyness of the old gas? I was just thinking the TW motorheads out there might think of something I hadn't. thanks everyone.
  2. Apr 16, 2010 at 4:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I would suck out the old gas, and replace with new. Gasoline can start to go bad in 6 months. No idea how much water you may have in that tank. Get it all out, and replace with new stuff.
  3. Apr 16, 2010 at 4:06 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    Gas that has not been treated is usually crap within 6 months or less. I would try to get that stuff out of your boat and put fresh gas in. Sta-bil only works at keeping good gas fresh, it will not freshen old gas.
    edit. Sorry, Chris beat me to it.
  4. Apr 16, 2010 at 4:08 PM
    jrw1965
    jrw1965 Well-Known Member
    Southern Maryland
    '08 dbl cab long bed 4 x 4
    Front tint, Stainless steel nerf bars, Leer tonneau, Rear spring TSB, Michelin LTX A/T2 265 70 16, Pioneer AVIC X910 so far
    Fuel begins to turn to laquer after about 3 months unless something like sta-bal was added. I would drain the old gas and start with new
  5. Apr 16, 2010 at 4:10 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Pump that crap out! Good gravy.
  6. Apr 16, 2010 at 4:10 PM
    Bryan07sport
    Bryan
    Newark, Delaware
    damn. thats like $100 worth of gas. where would i even dump it? besides the chesapeake or my storm drain!
  7. Apr 16, 2010 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A local Boat shop can take it for you, useually for a fee of about $20.00 or so. They charge about 1/2 hour labor to pump it out for ya.
  8. Apr 16, 2010 at 4:35 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    ^^^ looks like it's been covered pretty well, but just another suggestion...after you get the old gas pumped/drained out, running a tank of premium through it with some injector cleaner couldn't hurt....this is asumeing it doesn't already require premium.
  9. Apr 16, 2010 at 5:45 PM
    silver09taco
    silver09taco Member
    Clayton
    Grand Forks ND
    Silver 09 AC TRD Off Road
    Toytec front bilstein/eibach coils cranked to 3.5", AP Rear 3" springs, OME rear shocks, AP front and rear bumpers, AP skids, AP CV boots, K&N CAI, Bestop supertop, 33" BFG KM2's, Dick Cepek wheels, Warn 8000 with synth. line
    i would add a bottle of HEAT water remover and pump about 5 gal of new gas into it. the new gas will clean up any sludge type crap that some of the old gas has created. done this many times with generators for fuel systems and has never failed
  10. Apr 19, 2010 at 8:53 PM
    Bryan07sport
    Bryan
    Newark, Delaware
    alright so i'm going to pump the rest of the gas out tomorrow. Can any of you gurus think of anything else I could do besides just get as much out as possible, adding a full tank of fresh gas, and changing the water seperator/ fuel filter? additives? tricks? carb cleaner? or should the new gas clear everything out? thanks guys.
  11. Apr 19, 2010 at 8:58 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    If the boat sat for three years without being ran, it would be a good idea to pull the float bowls off the carb and clean everything out. Check the needle and seat while you're at it and give it good cleaning. Old gas can really gum up the inside of a carb if it sits there too long. Should be pretty easy and quick too.
