30,000 Major Maintenance?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chopayne, Nov 11, 2015.
  1. Nov 12, 2015 at 8:37 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Yep.. when I had my 2011 the NGK's were worse than the Denso's. I suppose thats why they give you Denso's when you go get new one's at the dealership.
  2. Nov 12, 2015 at 8:40 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I suppose so. The NGK's wear "faster" yet they are more expensive compared to the Denso's.
  3. Nov 12, 2015 at 8:56 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    So purchasing iridium plugs doesn't extend the changing frequency?
  4. Nov 12, 2015 at 8:58 AM
    RearViewMirror
    Craig Christ
    Dunno.... Some people use them but I go by what the manufacture calls for.
  5. Nov 12, 2015 at 9:01 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    In my tacoma manual it states 30k for plugs because of emissions.
    I still replace them at 30k with the recommended plug.
  6. Nov 12, 2015 at 9:15 AM
    ZachPrerunner
    Southeast TN
    Yeah you don't have to change them as often based on the spark plug manufacture's suggestion. However, it doesn't mean they will perform any better compared to the Denso/NGK's. You'll probably still want to check them at the 30k to ensure they are wearing properly. If you ask me, it isn't worth the extra $15-$20 for the iridium plugs.
  7. Nov 12, 2015 at 9:16 AM
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    I've also read here and there that some people have swapped to iriduim/platinum, properly gapped and in the right heat ranges and seen a decrease in mpg. I'm just wondering if it is an overall design of the ignition system - maybe resistance seen by the coil on plug system or something. For $24 a set, I'm going to just do what the manufacturer says.
    I mean, people tout Toyota for the longevity if you just do the basic maintenance, then everyone gets all pissy and want to ignore the recommended maintenance when they are asked to spend an extra 1.5 hours on their truck every 6 oil changes.
  8. Nov 12, 2015 at 9:28 AM
    adrenalnjunky
    FYI - looks like the 3rd gens new motor moves to a 60K plug change interval on Iridum plugs And 10K on the oil/filter. (guessing synthetic is spec fromthe factory).
  9. Nov 12, 2015 at 10:30 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I changed plugs on my 2009 @ 30k and noticed a little more gap on the Denso's but both still looked good. I went longer on the next set and they still looked good without a much gap degradation. The emissions warranty requires that you change them at 30k. Once I hit 60k I go longer because the warranty has expired.
  10. Nov 12, 2015 at 10:33 AM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Grease up that drive shaft as well. It's one of the most overlooked pieces to maintain and its really easy to do besides one zerk on the front shaft next to the transfer case. Your dealer should have greased it for the 15K toyota care maintenance but when I went to grease mine at 30K the factory seals were still on it.
  11. Nov 12, 2015 at 10:38 AM
    adrenalnjunky
    unless you have a prerunner and the u-joints are non-greaseable :mad:, even though the 4wd and 2wd use the same sizes.
    I had to replace all 3 of mine recently and made sure the shop installed greaseable u-joints.
  12. Nov 12, 2015 at 1:03 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I replaced mine with NGK platinum and I swear the truck doesn't start up quite as fast as with the copper plugs. Will go back to copper when these wear out. Engine runs good though, no change in performance or MPG.
  13. Nov 12, 2015 at 1:41 PM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    Maybe in retirement and when our boys are grown and gone from the house I will have a fraction of your free time....thats astonishing
  14. Nov 12, 2015 at 2:50 PM
    RearViewMirror
    Craig Christ
    I don't have a lot of free time I just stay on top of it.
  15. Nov 12, 2015 at 3:04 PM
    #35
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The Iridium plugs are used due to their long life; up to 100K miles. They are used where it is a PITA to get to the plugs. On my Highlander I had to pull the intake manifold to get to the inside plugs. Which means I had to pull the throttle body, a bunch of vacuum lines etc., etc. Toyota wanted $450.00 US. to change the plugs. I did not pay that but a lot of people do.
  16. Nov 12, 2015 at 3:51 PM
    #36
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    True, but PITA is subjective. Some people think pulling the plugs from the 4.0 in the Tacoma is a nightmare. It requires some finesse, but I'm cool with it if I only have to do it every 30K.
  17. Nov 12, 2015 at 3:54 PM
    #37
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    Own or work on a Subaru and you will never think the plugs on a tacoma are difficult to swap. Its just frame of reference.
