30,000 mile service costs $1,100???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4xThad, Oct 4, 2022.
  1. Oct 4, 2022 at 5:19 PM
    4xThad
    4xThad [OP] Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    So I just got done with my 25k service on my 21’ OR. The service writer says to me when I pick the truck up that everything looked great (figures) and that the next one, 30k, is a big one. “All the standard stuff and a full fluid flush: engine oil, both diffs and t case, brake fluid and power steering fluid flush. Oh and it costs $1100 so save up lol”
    Is this true? How the hell can this cost $1100? Is it like retribution payments for all the “free” toyota care service?
    I was gonna go somewhere independent to get it done anyway, but $1100? Sheeesh
  2. Oct 4, 2022 at 5:20 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Great time to learn how to change fluids yourself.
    Plus20DB, Kefka, mic_sierra and 46 others like this.
  3. Oct 4, 2022 at 5:21 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Fuck that.
  4. Oct 4, 2022 at 5:21 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Um, no. Unless you want to pay that much I guess :D
    CygnusX191 likes this.
  5. Oct 4, 2022 at 5:23 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It definitely costs that much if you let them do it.
  6. Oct 4, 2022 at 5:23 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Unless you drive through mud holes for a living, The only fluid you need to change at 30,000 mi is your oil. Tell that service writer to take a hike and find a better dealership. Because that is just criminal.
  7. Oct 4, 2022 at 5:24 PM
    Bishop84
    Bishop84 Well-Known Member
    I’ve always thought 30k driveline is over kill. If you tow or hard off road sure.
    I’m a bigger believer in 60k major service, Toyota diffs aren’t as sensitive as people seem to think.
    power steering flushes are rip off as well.
    grogie, Barsoom, Toyko Joe and 15 others like this.
  8. Oct 4, 2022 at 5:25 PM
    Kosta2009
    Kosta2009 Well-Known Member
    Constantine
    2022 silver Tacoma SR5 4x2 DCLB
    None
    No. Plus I don’t think the brake fluid and PS fluid needs to be flushed that early. All of that and the rest of the fluids you can do yourself pretty easy
  9. Oct 4, 2022 at 5:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  10. Oct 4, 2022 at 5:31 PM
    spp
    spp OC, Kalifornia
    OC California
    Read the service schedule in the owners manual. Only let them do what is required in there. The rest are dealer Recommended and are just up sell revenue source for them
  11. Oct 4, 2022 at 5:34 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Nothing needs flushed at 30K. Maybe diffs and t case changed but not transmission, brakes or cooling.
    60K maybe trans fluid change. 100K maybe brakes and coolant depending on age.
    Don't get took.
  12. Oct 4, 2022 at 5:49 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Do your brakes earlier than that. You can self bleed at home, just make sure you top off the reservoir between each wheel bleed action.
    3JOH22A, MR E30, 69 Jim and 2 others like this.
  13. Oct 4, 2022 at 5:50 PM
    4xThad
    4xThad [OP] Thad
    Thad
    Bend, OR
    How often do you guys get your oil changed? 10K or 5K?
    Barsoom and CygnusX191 like this.
  14. Oct 4, 2022 at 5:51 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Less than $200 in materials and parts - so yep at shop rate plus materials and hazard material disposal costs they will ask for a Grand. Typical stealer tactic. Learn to do your own work or pay up. Absolutely nothing on the service requirements a person with tools and time can't do and do as well as the under paid tech the Stealer rides like a bitch while pocketing all the profits. An independent shop will be a third less. BTW - all your service interval costs will be equally as $$ and the same screw job they just quoted you. Find a dependable independent shop or do your own work.
  15. Oct 4, 2022 at 5:53 PM
    jandrews
    '09 FourDubDee TRD OR
    Brake fluid and power steering fluid need no maintenance whatsoever at that mileage under normal use.
    The rest you can do yourself for 2hr of your time, $100 in fluids, and a few common hand tools.
  16. Oct 4, 2022 at 5:55 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    someone here recommended sucking out the brake fluid with syringe out of the reservoir and then refill, not the ideal way but no need to bleed and easy to do.
    Good points here: the difference between required and recommended...
    kahanabob and 908tacoma like this.
  17. Oct 4, 2022 at 5:55 PM
    BottleShark
    BottleShark Well-Known Member
    TJ
    Bullard, Tx
    2018 White TRD Offroad Long Bed
    2" lift, AAL Rear, Front bumper, 12k Winch
    Here is the list from Toyota
    "Inspect and adjust all fluid levels, Inspect wiper blades, Rotate tires, Inspect brake linings/drums and brake pads/discs, Inspect ball joints and dust covers, Inspect brake lines and hoses, Inspect drive shaft boots, Inspect engine coolant, Inspect exhaust pipes and mountings, Inspect radiator and condenser, Inspect steering gear, Inspect steering linkage and boots, Inspect rear differential oil/transfer case oil (4WD), Replace cabin air filter, Replace engine air filter, Replace engine oil and oil filter, Inspect transmission, Inspect fuel lines."
  18. Oct 4, 2022 at 6:03 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Depends...time or mileage?
    I drove 90K in two years. No way brake fluid had moisture. If it takes 8 years to hit 100K? Replace fluid for sure.
  19. Oct 4, 2022 at 6:06 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Well, they do have to inspect your floor mat…
    look it up: https://www.toyota.com/owners/parts...7wlB3WSHEEp3NfqsvixoCGb0QAvD_BwE&gclsrc=aw.ds
  20. Oct 4, 2022 at 6:12 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    5k. But I use my truck hard.
    Lmao please post a link where you can get all of those fluids at the correct volume for less than $200. I'll wait.
    Do not. Replace it with fresh stuff.
    No, but it also breaks down in heat. And and of course very in conditions will be harsher on your truck than other conditions. I'm just basically on the fact that I drive the hell out of my truck both on and off road, tow constantly and at 80,000, mi. It definitely needs brake fluid.
    Because clowns still stack floor mats. I literally failed a cars inspection yesterday because the dude had three floor mats stacked up under his pedals.
