30,000 mile tune up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pudge151, Apr 29, 2011.
  1. Apr 29, 2011 at 8:14 PM
    pudge151
    pudge151 [OP] Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i found this on here, thank you!!!
    http://sites.google.com/site/tacomamaintenance/
    i have 25k now on my 08 sport
    i am driving from CT to OBX NC this summer including a week on the beach. i dont drive a ton of miles normally and i am not sure if i will reach 30k before i leave. should i do the full 30k maintenance before or after i go? i was leaning towards just an oil change if im short of, or just at 30k
    i plan on doing my own 30k service. oil, filter, spark plugs ,front and rear diff and transfer case, as well as the other stuff recommended.
    a few questions...
    only the rear diff needs the LSD additive right?
    the front and rear diff and transfer case all use 75w-90 right?
    synthetics are ok?
    any tips or advice for me?
  2. Apr 29, 2011 at 8:57 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    If you miss it by a couple thousand or so, no big deal. Just do it when you get back if you don't think you'll hit 30k before you go to NC.
  3. Apr 29, 2011 at 9:04 PM
    DheadTaco
    DheadTaco Pill it till you kill it!
    Gulf Coast, Mississippi
    07 Tacoma PreRunner SR5 Impulse Red Pearl
    -Color Matched Grill & Toyota emblem -Headlights from WOTM -Tinted Fogs with Lamin-x (Tint) -Tinted taillights with Lamin-x (Tint) -6K HIDs in headlights and fogs -20% tint all around -Plasti-dipped badges -Plasti-dipped back bumper -Mud flap mod -'10 running-boards -LEDs all around -AFE drop-in
    do I have to change your diff fluids and transfer case at the 30,000 tune up? I have a 07 V6 SR5.
  4. Apr 29, 2011 at 9:42 PM
    nighthawk87
    nighthawk87 Well-Known Member
    Do not use synthetic on the sport. It will cause the LSD to bind. Trust me. Search if you don't believe me
  5. Apr 29, 2011 at 11:19 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Typically, if your within a couple of thousand miles either way on the 30K stuff, you will be ok, minus the oil and filter change. Its the guy who pushes the limits of the vehicle that should adhere to or perhaps exceed interval recommendations of Toyota. Tow a heavy load regularly, push your vehicle off road and or in dusty conditions often, or anything else considered severe driving in the manual you may want to step up maintenance intervals as needed, depending on conditions. ;)
  6. May 5, 2011 at 1:01 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I have a Off Road and used the synthetic oil. But, I do remember a bunch of sport guys guys complaining about synthetic oil binding with the LSD. I would just use regular oil and make sure you use the LSD additive.
    I am pretty sure you only need the LSD just for the rear, but I would get that clairified before you start as per in my off road it wasnt needed.
    PS.... I am taking my Tacoma to Myrtle Beach this summer from PA. 13 hrs each way.
  7. May 5, 2011 at 3:35 AM
    JimmyBuckets
    JimmyBuckets Well-Known Member
    Access Cab 6 speed V-6 sr-5
    My understanding is that the yes sport has no real LSD it is the same setup as every other Tacoma besides the yes off-road. This being the "auto LSD" . So I don't see how it could binde since my understanding is that there isn't one. Correct me if Im wrong.
  8. May 5, 2011 at 3:48 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    you have a prerunner, so no transfer case and no front diff. you just need to do the rear diff change. make sure you dont have an LSD sticker on the back of the rear diff. if you do, you'll need to use an LSD additive as well.
    correction coming:D what you said is correct...on trucks that are 09+. 05-08 sports and other select SR5s had the mechanical LSD and require a gear oil+LSD additive combo.
    and to the OP, the LSD additive is only in the rear diff. i'd use regular oil, not synthetic for the rear diff.
  9. May 5, 2011 at 7:38 AM
    pudge151
    Sean
    Connecticut
    thanks guys
