30,000 miles Service Cost... $996.00?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by colin_tacoma, Aug 13, 2019.
  1. Aug 13, 2019 at 11:58 AM
    colin_tacoma
    colin_tacoma [OP] New Member
    colin
    2016 Tacoma TRD Sport
    I just got back from my local Toyota Dealer and here's what they recommend:
    - Recommend EFI: $189
    - Recommend Optimizer: $199
    - Recommend Brake Fluid Flush: $189
    - Recommend 4X4 Differential Fluid Service: $230
    - Recommend Power Steering Fluid Exchange: $199
    Is this legit or should I get quotes from a local auto shop?
    Ricardo13x likes this.
  2. Aug 13, 2019 at 11:58 AM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    That’s highway robbery
  3. Aug 13, 2019 at 11:59 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    There’s no reason for them to tell you all of that needs to be done at only 30k miles
  4. Aug 13, 2019 at 11:59 AM
    heavylunch
    heavylunch Well-Known Member
    Not legit. I would go somewhere else.
  5. Aug 13, 2019 at 12:00 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    The only service I'd consider on that list would be the diff. But somewhere else.
    TacoSR523, willee51, Squirt and 6 others like this.
  6. Aug 13, 2019 at 12:00 PM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    There's a reason the call them Stealerships. Run... My opinion at 30K you don't need any of those services.
  7. Aug 13, 2019 at 12:02 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have no idea what the first two are, but the prices for the Brake and PS are BS. I did pay about that much for MT, T case, diff fluids, and other supplies though with plenty of leftovers. I won't touch them again until 60k.
  8. Aug 13, 2019 at 12:02 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Welcome to the forum Colin :hattip:
    X2 on the run.
    Don’t even let them change your oil.
    TacoSR523, Shellshock and TRD-ED like this.
  9. Aug 13, 2019 at 12:02 PM
    TRD-ED
    Lenoir NC.
    Change the oil and the air filter. Consider plugs and diff service at 50K-60K.
    TacoSR523, MSCOFF and Alden like this.
  10. Aug 13, 2019 at 12:02 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Any service before 50k miles is usually just oil change, tire rotation, air filters.
    TacoSR523, Tocamo, BGXtobe and 4 others like this.
  11. Aug 13, 2019 at 12:03 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Not needed.
    Also rediculously high prices.
    Differential oil is only one might not be a bad idea but not critical either. It's an easy DIY under $100 worth of synthetic oil or much less for normal oil.
  12. Aug 13, 2019 at 12:04 PM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    30,000 miles or 36 months Check installation of driver’s floor mat Inspect and adjust all fluid levels1 Inspect wiper blades Lubricate propeller shaft (4WD) Inspect the following: _ Automatic transmission fluid cooler hoses and connections _ Ball joints and dust covers _ Brake lines and hoses _ Brake linings/drums and brake pads/discs5 _ Cabin air filter _ Drive shaft boots (4WD) _ Engine coolant6 _ Exhaust pipes and mountings _ Front differential oil (4WD) Additional Maintenance Items for Special Operating Conditions3 Driving on dirt roads or dusty roads: Replace transfer case oil (4WD) Tighten nuts and bolts on chassis and body Driving while towing, using a car-top carrier, or heavy vehicle loading:7 Replace front differential oil (4WD) Replace manual transmission oil Replace rear differential oil Replace transfer case oil (4WD) Tighten nuts and bolts on chassis and body
  13. Aug 13, 2019 at 12:05 PM
    #NEVERGIVEUP
    #NEVERGIVEUP Well-Known Member
    California
    2017 Quicksand DCSB TRD OR
    TBD
    Not legit
  14. Aug 13, 2019 at 12:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Iridium plugs from the factory. The interval is much longer than that.
    @elduder . I was incorrect. It is 60k for the plugs. I missed it when reading through the Maint Guide. I thought it was 120k.
    photogr4x4 and elduder like this.
  15. Aug 13, 2019 at 12:10 PM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    Why are they recommending it? Are you constantly on 4x4, driving downhill around extremely sharp twisties?
    If not, stick to the oil change and tire rotation.
    It is known that dealerships will recommend services you don't need to make profit. Shouldn't be a surprise to you or anyone.
  16. Aug 13, 2019 at 12:13 PM
    TRD-ED
    Lenoir NC.
    V6's come with Iridium's? Now? Brand? If still NKG and Denso 3 and 3 . NKG says 50K while Denso says 100K.
    TacoSR523 and tonered[QUOTED] like this.
  17. Aug 13, 2019 at 12:14 PM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
  18. Aug 13, 2019 at 12:18 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    my brothers got well over 300k and hasnt done any of that
    TacoSR523, maineah, saltybum and 5 others like this.
  19. Aug 13, 2019 at 12:20 PM
    TRD-ED
    Lenoir NC.
    Ounce of prevention......
  20. Aug 13, 2019 at 12:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Since I am just getting toward 25k, I haven't looked. The engine document is really a good read. The maint guide says 60k.
    Edit: the engine document on Page 114 says Denso FK20HBR8. Three grounds.
    quail_bird likes this.
