30,000 Service for 4 wheel drive
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Husky9000, Jul 5, 2024.
  1. Jul 5, 2024 at 12:47 PM
    Husky9000
    Husky9000 [OP] New Member
    Scott
    2023 Red Tacoma Double Cab SR5 4x4
    Stock...So far
    I have a 2023 Tacoma 4x4...the dealer wants to do a 30,000 mile service for the 4 wheel drive system...is that a real thing?
  2. Jul 5, 2024 at 12:53 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Yes.
    It’s not a difficult DIY job if you’re able/interested.
    02Duck and Gdeyarmond like this.
  3. Jul 5, 2024 at 1:10 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Fluids, front diff, rear diff, and transfer case. DIY, not hard, just do your research, the T-case needs special straight 75w fluid. Ski
  4. Jul 5, 2024 at 1:14 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    It is... Your truck has two differentials - front and rear along with a transfer case. Many including myself have done a 30k mi (or sooner) diff fluid change. Some also do the transfer case but that fluid comes out pretty pristine so waiting till 50k mi if you don't do heavy towing should be ok.
    Pretty easy job overall. Front drain can be a bit of a pain to brake loose.
  5. Jul 5, 2024 at 1:29 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yep, I had mine done at 30K and 60K.
  6. Jul 5, 2024 at 1:53 PM
    Gdeyarmond
    Gdeyarmond Well-Known Member
    San Dimas, CA
    2020 TRD OR 4x4 6MT
    Bilstein 6112/5160
    Bingo. I did mine over 3 different days (including my manual trans fluid). Each step took an hour or two while taking my time. The fluids are expensive, and so is a dealership's labor rate.
  7. Jul 5, 2024 at 2:07 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    skidooboy likes this.
  8. Jul 5, 2024 at 2:09 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    ricco333 and Chew like this.
  9. Jul 5, 2024 at 2:51 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Did this recently .. transfer case and rear are pretty easy . The front can be a bit challenging since it’s tucked away . Fluids u can do 75w 90 for the front and rear diff . The transfer case u can use the redline mt-lv way cheaper than the oem gold fluid which is like 90-110 a quart . Who knows why it’s that expensive .depending on the dealer price will be about the same after purchasing the fluids and tools needed to complete the job . I wanted more of a piece of mind and use the brand fluid I wanted over what dealer was offering I did it myself .
  10. Jul 28, 2024 at 8:06 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    All the dealer will do is inspect the fluid in your t case. If you don’t ride your rig hard, they won’t change your fluid. Earlier 3rd gen models, they will also inspect drive shaft and lube it if has grease zirks.
  11. Jul 28, 2024 at 8:24 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    One piece of advice I keep in mind for when I self-service ... FIRST verify you can remove the "fill" port BEFORE opening the "drain" port. There is no guarantee that the "fill" port opens at all.
