30,000 service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08Tacoma, Aug 26, 2009.
  1. Aug 26, 2009 at 2:33 PM
    08Tacoma
    08Tacoma [OP] Well-Known Member
    Arizona
    2008 Tacoma, DblCab, 4x4, TrdSport, BlackSandPearl, 2.5" Toytec, TubeSteps, WindowTinting
    hello all,
    I have a 2008 tacoma tdr sport, I'm about to take it to have the 30000 miles service, does anyone knows if I need the following:
    Spark Plugs replaced?
    Fuel injection service?
    Does the limited slip diff. oil needs and additive?
    Any help will be appreciate it, I know I need to do the oil changes (motor, transmission, differentials), replace filters.
    Is there anything else that needs to get done?
    Thank you
  2. Aug 26, 2009 at 2:41 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What does your owner's manual say?
  3. Aug 26, 2009 at 2:41 PM
    BlancoTaco08
    BlancoTaco08 Well-Known Member
  4. Aug 26, 2009 at 2:47 PM
    08Tacoma
    Arizona
    I'm asking about the plugs, because a mechanic told me that I didnt need to replace the plugs yet. And he told me that limited slip differential needs and additive.
    Does anyone knows about this.
    Thanks
  5. Aug 26, 2009 at 2:49 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    It'll all be in your owner/service manual. Most cars these days come with iridium spark plugs, which are good for 90k-100k miles.
  6. Aug 26, 2009 at 2:53 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    You don't have to change the spark plugs, but it would be a good idea to take them out and clean them, and check the gap. I would just change them and not worry about it.
  7. Aug 26, 2009 at 3:54 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    bleh 2k more miles and im there
  8. Aug 26, 2009 at 3:59 PM
    08Tacoma
    Arizona
    what about the additive for the limited slip diff.?
    is there one?
  9. Aug 26, 2009 at 4:06 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I never did the 30k mile service. My truck is still going strong with 126k miles. Actually I never did any of the stealership's services. They are such a rip off. If you want to do these items do them yourself & save a ton of cash. This website will have all the instructions you need to do the job right.
    I just cleaned my throttle body for the first time. It was a piece of cake. Spark plugs @ 80k miles, easy. Coolant(pink stuff) @ 100k, easy. Of course I do all my oil changes. Differential is easy if you can get the top plug off first, then the bottom plug. I couldn't remove my top plug, So I had to have it done professionally.
  10. Aug 26, 2009 at 4:13 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
  11. Aug 26, 2009 at 4:19 PM
    08Tacoma
    Arizona
    thanks...
    and my last question...do I need fuel injection service @ 30 k?
  12. Aug 26, 2009 at 4:23 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Not really, but you can run some injector cleaner like sea foam through just to make sure, it should not hurt anything. I run a cleaner every other oil change or every 8 k miles, but a lot of people say they use sea foam and swear by it. So I think I'll start using sea foam.
  13. Aug 26, 2009 at 9:25 PM
    stormyday
    stormyday Well-Known Member
    Morganton, NC
    14 Taco Double Cab Pre-Runner
    How do you use sea foam? I got confuse reading the bottle one day. It seams like it can be added to anything. I was going to add some to my fuel to try to clean it out but didn't know how much to use, add it to a full tank or empty tank, etc.
  14. Aug 27, 2009 at 6:50 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    When your tank is about empty, dump in 1 can of SeaFoam right there at the pump (take a little funnel with you or get a disposible one) and immediately fill the tank with gas. It'll mix nicely as you pump in the gas. don't re-fill the gas until the tank is almost empty.
    If you suspect the injectors are really dirty, just use one can and only fill the tank half-way. Don't re-fill it until almost empty.
  15. Aug 27, 2009 at 7:11 AM
    08Tacoma
    Arizona
    so I just like and gasoline additive?
    all you need to do is to put it in before you put gas???
  16. Aug 27, 2009 at 9:19 AM
    stormyday
    Morganton, NC
    Thanks! My truck is a 09 with 27K on it. I drive it like an old granny, baby the throttle, and I am in and out of it like the UPS man.
    I am also thinking about doing it to my wife's 06 CRV with 37K on it. I cannot stand to drive it.
  17. Aug 27, 2009 at 9:37 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I would stay away from SeaFoam unless it is absolutely needed, which it is by no means warranted at 30k. 100k maybe, 30k no way.
    Chevron Techron fuel injector cleaner is the best off the shelf injector cleaner there is. You can pick it up at most wal-marts, autozone, advance autoparts, etc.
    Here is a picture of what the bottle looks like.
    http://www.amazon.com/Chevron-Techron-Fuel-System-Cleaner/dp/B00092893E/ref=cm_cr_pr_product_top
  18. Aug 27, 2009 at 9:41 AM
    jonny
    jonny Betty White Edition Heep ZJ
    :rolleyes:
    :D:D:D:D:D
  19. Aug 27, 2009 at 9:44 AM
    08Tacoma
    Arizona
    Thanks...So how do I put it in?
    Just before I put gas or how?
    How often is recommended?
  20. Aug 27, 2009 at 9:54 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    I use Techron myself, and it's not as harsh as SeaFoam, which contains some acids that help etch away corrosion. I don't think it hurts to use SeaFoam once a year, but i certainly wouldn't use it once a month.
    Techron you can use frequently, and frequent use keeps things cleaner in the long run, but for real tough cases nothing beats SeaFoam IMHO.
