30,000m service, what did you pay?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sgscholla, May 27, 2014.
  1. May 27, 2014 at 10:20 AM
    sgscholla
    sgscholla [OP] Well-Known Member
    Reston VA
    13 Sport 4x4 DCSB.
    Pyrite on Bronze
    just got quoted $480 for the 30k service.. seems a bit high?
    I would do it myself, but i was told that it could void my warranty. that all services need to be "tracked"
    shed any light on this? this true?
    How much did you pay at the dealer for it??
    thanks
  2. May 27, 2014 at 10:26 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    it wont void your warranty. just keep your receipts and write down the mileage and whatnot. that actually seems like not a bad price for th e30k service. I did mine myself for a couple hundred in parts.
  3. May 27, 2014 at 10:49 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    What's the service entail? Plugs??
  4. May 27, 2014 at 10:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Whoever told you that doing your own service would void your warranty is full of shit. Tracking and keeping records of doing your own service is perfectly acceptable and can absolutely NOT void your warranty unless they prove that you screwed something up and it caused a warrantable part to fail (like say you forgot to put the drain plug in and your engine blew, that would be an example where they would not cover your engine because you screwed something up.
    I would ask what the $480 entails because different dealers quote doing different things even though your owner's manual states what should be done. Either way, $480 is outrageous.
    Front/rear diff and x-fer case fluid change $100 and not a lot of your time.
    Oil/filter change $40 depending on what oil you're using
    Spark plugs $30-40 and takes some basic tools but not difficult
    Air filter check/change might be free depending on what your filter looks like
    Rotate tires free
    Grease the driveline basically free if you already have a grease gun and a tube of grease
  5. May 27, 2014 at 11:01 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    +1, $480 is a ripoff. I do not run in 4x4 like people up north so I will not do the transfer case and front diff. I might have 100 miles on mine in 4x4 mode. I take my air filters out and clean them with compressed air at each oil change.
  6. May 27, 2014 at 11:16 AM
    sgscholla
    Reston VA
    13 Sport 4x4 DCSB.
    Pyrite on Bronze
    Good to know, i appreciate the info.. ill plan on tackling this myself. just cant justify 500 for a service..
  7. May 27, 2014 at 11:28 AM
    Pugga
    Massachusetts
    Even if you're not running in 4x4, things are still spinning and the oils are heating up. If you aren't going to change the front diff and x-fer case fluid, I'd at least pull the fill plugs and make sure you have the proper oil levels in each.
  8. May 27, 2014 at 11:40 AM
    tomwopat
    tomwopat Well-Known Member
    Memphis, TN
    2012 DCSB Prerunner
  9. May 27, 2014 at 12:47 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    That is high. I paid $301.53 back in November.
  10. May 27, 2014 at 1:39 PM
    stump jumper
    Bill
    Texas
    clarify, what is spinning? Something in transfer case? Diff is not because it is not locked up. Changing these fluids at 30k is WAY over kill if not running in 4x4.
  11. May 27, 2014 at 2:03 PM
    Pugga
    Massachusetts
    The diff is disconnected on one side, the other side is still a solid connection to the passenger side wheel. It will still spin since the Tacoma doesn't have hubs that you can unlock. Granted, it's not spinning under power from the transfer case but the spinning will still generate heat.
  12. May 27, 2014 at 2:18 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Just looked at my receipt from the dealership. $240 included the following:
    Oil & Filter Change (I provided the oil)
    Tire Rotation
    Replace Spark Plugs
    Front & Rear Diff fluid change (I provided gear oil)
    Transfer Case fluid change (I provided gear oil)
    Lube Drive Shaft
    I replaced the Air & Cabin filters myself
