30,000mile brake flush
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe23, Jan 15, 2019.
  1. Jan 15, 2019 at 2:02 PM
    #61
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have a compressor bleeder too, works awesome, sometimes I will even press the brake pedal a time or too while it's going if there is a little stubborn trapped air.
  2. Jan 15, 2019 at 2:03 PM
    #62
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    What does Toyota recommend for brake flushing on the third gen Tacoma?
  3. Jan 15, 2019 at 2:07 PM
    #63
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    http://valvolinechemicals.com/products/valvoline-dot-3-and-4-brake-fluid
    I have used this brake Fluid for probably 20+ years. It has a really high boiling point. I’ve had vehicles in the past that boiled the stock brake fluid and then almost couldn't stop. This fluid will solve that problem. Also if you are tired of warped rotors this fluid will solve that problem. I have given every vehicle a chance when new to perform with the stock fluid and it has let me down with guaranteed warped rotors after about 30k miles. Mostly Hondas and Acura’s. Then it happened on my 350z at 16k miles and I told myself that I should have swapped out the brake fluid a lot sooner. After replacing the rotors and using this brake fluid I had Zero issues for the next 135k miles on the same rotors just slapping on new pads as they wore down. I have already done this on my truck as I got BIT on our 2013 Camry UGH! Swapped out rotors and brake fluid on that car and went another 90k miles with Zero issues. NEVER AGAIN will I trust factory brake Fluid. After 5k miles I swap it out with the better fluid. Don't go out and do this unless you are experiencing these issues as everyone's driving style is different. I live in California where it is HELL during the summer. If you live in Alaska you need not worry.
  4. Jan 15, 2019 at 2:12 PM
    #64
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    They recommend inspecting the level and color every 5k miles. Fill when the level is low and change when the color is dark.
  5. Jan 15, 2019 at 2:19 PM
    #65
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    https://www.lelandwest.com/brake-fluid-comparison-chart.cfm
    str8-shooter likes this.
  6. Jan 15, 2019 at 2:32 PM
    #66
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    This.... the water will basically destroy the innards of your brake system.
    Rick111, shakerhood and Joe23[OP] like this.
  7. Jan 15, 2019 at 2:33 PM
    #67
    DansSr5
    Thanks!
    This helps. I would stick with Stuff you could easily get at auto zone or Walmart so that it can be easily sourced and has a DOT rating. Looks like Bosch and Champion have a DOT 5.1 Rating but I would make sure they could be easily sourced. I do know that some are worried about synthetic fluid getting moisture? I can only report on the Valvoline that this is not true for the past 20 years
  8. Jan 15, 2019 at 2:41 PM
    #68
    DansSr5
    Valvoline synthetic dot 3 and 4 and have never any moisture issues in 20 years. I would always flush when it started to get cloudy. Maybe Staying on top of the Flushing of the fluid is the key. I'll try a 5.1 when i find a vehicle that still manages to get warped rotors or boiled brake fluid using the Valvoline. The 350z I abused for 10 years never flinched
  9. Jan 15, 2019 at 2:49 PM
    #69
    Joe23
    Joe23 [OP] Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    30 000 miles... Hence the thread
  10. Jan 15, 2019 at 2:53 PM
    #70
    BillsSR5
    bill
    2014 SR5
    according to that list Lucas DOT 3 is a very good fluid that easy to get locally over the counter
    Joe23[OP] likes this.
  11. Jan 15, 2019 at 3:36 PM
    #71
    Lt. Dangle
    Ohio
    I don't see it listed in the recommended maintenance schedule in the manual. Did the dealer tell you this, or is it listed somewhere else?
    shakerhood likes this.
  12. Jan 15, 2019 at 3:58 PM
    #72
    Joe23
    Toyota website.
    If you go to service schedule and put in my mileage (46,800km) at 48k km roughly 30 000 miles is when it says lube prop shaft, tighten prop shaft and brake fluid change
  13. Jan 15, 2019 at 4:07 PM
    #73
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  14. Jan 15, 2019 at 4:09 PM
    #74
    Lt. Dangle
    Ohio
    I wonder why that's not in the manual. I'll have to log on and check mine since I'm at 34k miles.
    Joe23[QUOTED][OP] likes this.
  15. Jan 15, 2019 at 4:22 PM
    #75
    Lt. Dangle
    Ohio
    Yeah I got nothing. I don't even see brake fluid explicitly mentioned at all other than generically "check all fluids".
  16. Jan 15, 2019 at 5:01 PM
    #76
    Dragracer_Art
    Dragracer_Art Tundra for the win
    GA
    2020 Tundra Crewmax 4x4
    These fucking dealers will stop at nothing to drag your ass in for frivilous, unnecessary and expensive service work.
    "flushing your brake system"
    What a crock of shit.
    Unless water is physically put into your master cylinder reservior, there is NO need to fuck with your brake fluid... usually for the lifetime of the vehicle unless other components are replaced. (calipers/wheel cylinders/etc)
    Lt. Dangle likes this.
  17. Jan 15, 2019 at 5:23 PM
    #77
    BillsSR5
    bill
    2014 SR5
    https://media.giphy.com/media/QN6iXenvdhkas/giphy.gif
    AxisCab and Joe23[OP] like this.
  18. Jan 16, 2019 at 9:28 AM
    #78
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    and owned my 96 T100 for 14 years and not one bit of problems with it...
  19. Jan 16, 2019 at 11:08 AM
    #79
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Inside brake calipers you'll find (see attached) stuff that you can't flush out with new brake fluid.
    It is therefore good practice to physically clean, scrub hone rebuild or replace the calipers when the pads are worn out and replaced. This happens as normal byproduct of use and I have found no exceptions.
    It does not seem to matter how much or often you flush, it has to be physically removed, therefore to me, flushing or replace the fluid is just pissing in the wind.
    We have a bigger job to worry about, and we've got to get physical.
    Hope that helps
    Cheers!
    golfindia likes this.
  20. Jan 16, 2019 at 11:13 AM
    #80
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I had a red '95. Can you post pics of yours? Almost forgot what they look like.
