30-06 ammo
Discussion in 'Guns & Hunting' started by vtragweed, Jan 17, 2009.
  1. Jan 17, 2009 at 2:21 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    my father bought me a remington 7400 30-06 semi auto about 25 years ago and its never been fired and ive been thinking for the past few months i wanna shoot that thing. this morning i went to the local gun shop only to find out theres about 500 different loads and a wide range of grains to go with. is there anyone out there that has a particular load they like?
  2. Jan 17, 2009 at 2:25 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I couldn't recommend any weights to go with since I don't shoot the 30-06 BUT if it's a semi-automatic rifle I would be sure to stay away from any "light-mag" loads. These are hot loads and can cause damage to your rifle. Not to mention expensive.
  3. Jan 17, 2009 at 2:27 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    i read something about that where they are doing some kinda damage
  4. Jan 17, 2009 at 2:30 PM
    SC4333
    Grant
    San Antonio, TX
    Yes sir. They create too much pressure in the chamber. Someone around here is bound to point you in the right direction. The 30-06 has to be one of the most popular rounds around.
  5. Jan 17, 2009 at 2:32 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    god yeah, i thought it was a law not to own a 30-06
  6. Jan 17, 2009 at 2:39 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
  7. Jan 17, 2009 at 2:44 PM
    tex
    tex Well-Known Member
    Aaron
    Arlington, TX
    2015 4 Runner Trail
    If you are just going to shoot pick up some Remington Core Locks in 150 grain.
    I like the Federal Premium 150 grain boattail soft points for hunting deer and pigs.
    If you are target shooting and accuracy is a big deal pick up some premium ammo in 168 grain. From what I have herd a .30 caliber bullet in 168 grain has the least amount of drag in flight. I am not that big of an accuracy nut so the 150 grain group just fine out of my Savage.
  8. Jan 17, 2009 at 2:58 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    AIMSurplus usually has some good deals on 30.06
  9. Jan 17, 2009 at 7:38 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Glendale, CA
    =p
    Does the CMP still have that korean surp 30-06. O bought a boat load of that stuff. It stunk like doggy poo poo when you shot it and it is corrosive but it was cheap.
  10. Jan 20, 2009 at 11:12 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    i like 165gr. for my 06
  11. Jan 20, 2009 at 11:26 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    My two cents worth, put good ammo through it. I know my Kimber is very pickie on what ammo will feed. That is why I started reloading for it.
  12. Jan 22, 2009 at 6:39 PM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    The 30-06 will be less picky than your Kimber, The Remington Core-lokt is a relatively cheap round that is fairly consistent (i use the term fairly loosely here). 165 gr. would probably be a good place to start, buy 20 rounds only, see how the rifle handles a particular round before you go buying 1000 rd lots. Make sure to clean and lubricate your rifle before taking it to the range since it's been sitting so long. I shoot a 103 year old 1903 - proof that proper care (and in my case, a properly heat treated receiver) can give you many years with the same rifle (except the barrels do wear out).
    now to submit the paper work for my pistol permit. and set up a reloading bench I have a mountain of 30-06 brass under my bed.
  13. Jan 22, 2009 at 6:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ^^^^^^ remington corelokt is good ammo.
    i,myself, have a remington 7400 .270...............and i use either the corelokt ammo, or i use winchester silvertips.....150 grain. pretty consistent, but you gotta clean the hell outta them semi auto's and keep them clean........even take the action apart and clean it thoroughly.
  14. Jan 24, 2009 at 10:31 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    Stay away from the high dollar winchester ballistic tips. You can buy 2 boxes of anything else for the price of one box of them.
    My dad shoots a 7400 30-06 with Remington Corelok express 150 grain. It groups within a 3/4" at 100 yards
  15. Jan 27, 2009 at 10:17 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I find if it says "Federal" on the box it tends to shoot true. Other stuff, doesn't.
  16. Jan 27, 2009 at 10:27 AM
    MacTaco
    MacTaco Mustache May
    Pensacola, Florida
    06 Indigo, Lifted, Flowmaster
    Skyjacker 3" Lift, 285/75/R16 Toyo M/T tires/ Eagle Alloy Wheels, Flowmaster 50 Series, Pioneer Din Head Unit, Viper Alarm/Remote Start System, Debadged, DT Headers, True Flow Intake
    Federal is great ammo.
    But you are just wanting to see how the thing fires, and waste a few rounds then the cheapest ammo(with decent quality) is the Remington UMC ammo. Preferably in 150 grain.
    That what I shoot in my .308 when I go to the range. If I'm shooting anywhere else, then I'm shooting either Hornady, Federal or Winchester Ballistic.
  17. Jan 27, 2009 at 7:10 PM
    ZonKs
    Glendale, CA
    =p
    Why not reload?
  18. Feb 17, 2009 at 7:21 PM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    i find the best round to use is the 180 grain winchester fail safe. very accurate, strong. the best but expensive. you get what you pay for
