30-35K mile transmission service. Not neccessary?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RealCoolHand67, Oct 15, 2019.
  1. Oct 15, 2019 at 11:13 AM
    RealCoolHand67
    RealCoolHand67 [OP] Member
    East Central Ohio
    1999 Tacoma XtraCab V6 Auto SR5 TRD 4x4
    Icon 2.5 Front Coilovers OME Dakar Rear Packs & Shocks 33x10.5R15 BFG All Terrain T/A KO1
    Bought my 99 3.4 Auto from the original owner who always had the tranny serviced between 30-50k miles at the dealership. Currently its been roughly 35K since it was last done and I contacted a local dealer who said that they wanted roughly $400 for the service. They stated it was not recommended to do unless the truck is towing a lot and even then only around 80-100,000 mile intervals. I've seen many people here servicing or having their tranny serviced lot more regularly than this and certainly closer to the 30-50K interval I had in mind. Am i correct in thinking that its better to do so or is the service department at this dealership more in line. They wanted $400 and obviously didn't feel i needed to spend the money which is a good thing I suppose. The previous services that were done along with a power steering flush came out out to around $333, albeit at a different dealer in a different state. Truck has 196,000 and has always had great maintenance done. Are the 30-50K service guys just being overly anal and/or cautious? What is the majority doing with this service?
  2. Oct 15, 2019 at 11:18 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I did just pan drains every 30k miles, real easy to do
  3. Oct 15, 2019 at 11:20 AM
    RealCoolHand67
    East Central Ohio
    Is there a filter/screen inside that needs replaced when dropping the pan? How many quarts do you usually get out of the system?
  4. Oct 15, 2019 at 11:21 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Check the fluid via dipstick.
    If the fluid is questionable, just drain, turn on, cycle through gears, drain more while you add new stuff, etc. Repeat until all fluid is new.
    If it's been awhile, I'd recommend replacing the filter as well.
    Easy to do as all you have to do is drain the fluid, undo some bolts, and drop the pan.
  5. Oct 16, 2019 at 7:04 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    its been almost 30 years since i did something like that as a lubeTech, thanks for the blast from the past
    and that service then cost iirc about $40, for a tech making a generous $5.50 an hour + sales commisssions (i got all giddy when i saw a 4x4 coming in the lot)
  6. Oct 16, 2019 at 9:11 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    The factory doesn't recommend "servicing" the trany (fluid change) at any interval, let alone every 30k miles.
    They only say to "inspect" it, but no need to change it, unless it needs it.
    RealCoolHand67[OP] likes this.
  7. Oct 16, 2019 at 9:42 AM
    paetersen
    paetersen Well-Known Member
    There's the old way, service (fluid and filter) every 60-80,000 (give or take, depending on driving style).
    There's the new way, lifetime fill. When they say 'lifetime fill' they are not talking about the lifetime of the vehicle. They are talking about the lifetime of the transmission, which, if never serviced, can be as short as 100,000 miles.
    For vehicles that you are planning on keeping for more than 100,000 miles we recommend a regular service interval, regardless of what the manufacturer of the vehicle says. If you purchased a used vehicle that has north of 100k and has never had a trans service, let it ride. Putting fresh fluid in a high miles transmission *that has never been serviced* can actually lead to failure. In this scenario you are in for the 'lifetime fill'.
    RealCoolHand67[OP] and GQ7227 like this.
  8. Oct 16, 2019 at 4:41 PM
    RealCoolHand67
    East Central Ohio
    Thanks everyone. Like I said the tranny had been serviced since new roughly every 50,000 miles and when pouring through lots of posts here you come across some that service their trucks at what seems like extreme levels like the 30K interval. With the transmission being serviced roughly 35,000 miles ago, I will wait another 50-70K to service provided I still own the truck at that point.
