30 and younger thread
Discussion in 'Off-Topic Discussion' started by TacoMaster44, Feb 22, 2013.
  1. Oct 14, 2013 at 5:53 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I thought the plate had a shock eyelet on top of it.
    If not...whoops oh well
  2. Oct 14, 2013 at 5:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That's it?! :eek: so you pretty much maxing them out just sitting???
    Yea..not good haha same boat as I was with 8.5" 5150s.
    Nope. The new plates are just flat. You don't reuse the stock ones.
  3. Oct 14, 2013 at 6:02 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    So I have stock 16" wheels and 1.5" wheel spacers. Realistically what trimming would need done for 285/75? I want 255/85 but I might be stuck with another set of goodyears if they warranty pro-rate mine for a good amount plus the $160 rebate.
  4. Oct 14, 2013 at 6:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Pinch weld and you should be good.
  5. Oct 14, 2013 at 6:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I can't find the shocks with the PN you showed...or maybe I'm not looking right..gotta get on my computer.
    Sheesh 500?? Damn. For that I'd want 12" stroke for sure haha that's a lot of money for shocks.
    Pinch weld. Some hammering. Possibly a tiny bit outa the lower section of fender.
  6. Oct 14, 2013 at 6:07 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    And remove the front mud flaps?
  7. Oct 14, 2013 at 6:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea probably.
  8. Oct 14, 2013 at 6:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    god Icon is bitch..i can't find anywhere on their site even a catalog to show different shocks and sizes..not lengths anywhere..
    and they will work to be stuffed..just no droop..the shock would be hanging the axle and your not gonna droop a wheel much lower then you see it now..
    Id bet some compressed and extended lengths and go from there. Even if you have to get some 5125s for now be better in the long run.
  9. Oct 14, 2013 at 6:17 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I know you don't use the stock ones. Welp, seems like a good time for some triangulated shocks?
  10. Oct 14, 2013 at 6:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea you could add an upper cross memeber and mount em however you wanted. /\ more for crawling, || for high speed.
  11. Oct 14, 2013 at 6:21 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  12. Oct 14, 2013 at 6:24 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  13. Oct 14, 2013 at 6:26 PM
    Monster Coma
    Corey
  14. Oct 14, 2013 at 6:30 PM
    PcBuilder14
    Brent
    Nor Cal
    You can drive the truck without shocks if needed. It'll just perform different but won't hurt anything.
  15. Oct 14, 2013 at 6:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    can't do that on 1st gens. not on a stock axle. That shock is out side the frame. Out axles aren't wide enough for that. You can do that with a tundra axle though, but is 6'' wider. What im gonna do for my rear LT setup.
    you have to keep the shocks inside the frame on ours and sadly the bed floor is right there..
  16. Oct 14, 2013 at 6:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    just take the shocks off and keep some weight back there and don't drive like a mad man. I did it for a week like that.
  17. Oct 14, 2013 at 6:34 PM
    PcBuilder14
    Brent
    Nor Cal
  18. Oct 14, 2013 at 6:35 PM
    PcBuilder14
    Brent
    Nor Cal
    You can and people have, such as Monte. It can be done no problem as long as you don't push it.
  19. Oct 14, 2013 at 6:39 PM
    PcBuilder14
    Brent
    Nor Cal
    No I have not, but if I do have to do it one day I will and not worry about it. Why shouldn't you do it? Yes the vehicle will handle differently but other than that? Think I hit a nerve :rolleyes:
  20. Oct 14, 2013 at 6:41 PM
    PcBuilder14
    Brent
    Nor Cal
    I knew there was a kit out there somewhere that had it all in one! Haha That will be what I get as well.
