30 and younger thread
Discussion in 'Off-Topic Discussion' started by TacoMaster44, Feb 22, 2013.
  1. Oct 25, 2013 at 8:12 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    best part of the sentence.
    haha cute girls are a +
  2. Oct 25, 2013 at 8:16 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    i haz 2wd and bald tires this is me in light rain LOL
  3. Oct 25, 2013 at 8:21 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    In a rear wheel drive like a truck your theory is probably fine. Leave it in gear with the brake tight and it probably will only buck a bit and die. A front wheel drive car will take off even with the e brake set.
    What you're about to try won't work because a remote start uses a rpm sensor to know what the engine is up to. It will start the engine using a clutch cancel. Basically the same as dropping the clutch if you are in gear. It knows to kill the starter when the rpm reaches a certain point. It will keep producing power indefinitely for 10 seconds until the starter kill is activated if the engine doesn't reach rpm.
  4. Oct 25, 2013 at 8:24 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Yeah I just wanted to test if even the engine at idle could overcome the brake. And I don't know the specifics on how a remote starter works but I assumed it didn't just keep cranking if it didn't start the engine and had some kind of safety to save the starter
  5. Oct 25, 2013 at 8:26 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i wouldnt mind if someone totaled my car this winter. then i could get a tacoma (getting shunned now for not having one yet)
  6. Oct 25, 2013 at 8:28 AM
    MowTaco
    Kansas
    I don't have that button. And I know dropping the clutch would kill it so I just wanna see if the engine at idle could overcome the e brake
  7. Oct 25, 2013 at 8:29 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    You would have to test it right when your engine starts where it spikes to like 1500 rpm or something.
    1. Set brake tight
    2. Start engine
    3. Drop clutch immediately while giving it enough gas to hold that spiked rpm that the engine does when cold
  8. Oct 25, 2013 at 8:30 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    The guy I posted before has remote start on his truck. He used to let it drive up obstacles by itself and just reach in the window occasionally to steer it. Lol
    I have remote start too and it's awesome.
  9. Oct 25, 2013 at 8:31 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Nope.. who cares.. this site has people with almost every make and model..
  10. Oct 25, 2013 at 8:31 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Ghost riding is retarded but at least he could kill it with the remote if it went south.
  11. Oct 25, 2013 at 8:33 AM
    Ice Horse
    Lauren
    Florida
    Ghost riding in combination with a slow race when you have crawl boxes/dual cases. Win. We used to do that too
  12. Oct 25, 2013 at 8:34 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    anyone got plans this weekend?
  13. Oct 25, 2013 at 8:34 AM
    MowTaco
    Kansas
    This isn't really an accurate test anyway, cause the starter also has to break the engine loose at the same time it's trying to turn the whole driveline. We're getting way too into this haha, it's a hypothetical situation that in reality would never happen
    He let the starter drive it up the obstacles?
  14. Oct 25, 2013 at 8:35 AM
    Monster Coma
    Corey
    Toyota Scion show in VA :)
  15. Oct 25, 2013 at 8:37 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    ghost riding still retarded i dont see a purpose except for looking cool or if you haz no spotter
    i wants ta go :/
  16. Oct 25, 2013 at 8:37 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Matt you are missing the concept of remote start. The starter only engages until the engine is running. Once the engine is running the starter is done. Remote start uses a clutch kill. Leave the truck in drive without setting the brake and the engine WILL drive the truck.
  17. Oct 25, 2013 at 8:43 AM
    Ice Horse
    Lauren
    Florida
    x2. The starter only stays on long enough to crank the engine. So
    Sometimes it's not long enough when it's cold so it restarts itself. And sometimes mine spazzes and stays on extra long and turns off the engine lol
  18. Oct 25, 2013 at 8:46 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    My truck sometimes does that vapor buildup thing in the intake if I restart it after about 20 minutes and the remote starter freaks out and keeps starting for 10 seconds. If it happens without using remote start I just have to stop turning the key and it will be fine the next key turn.
  19. Oct 25, 2013 at 8:48 AM
    MowTaco
    Kansas
    I know, it would act essentially like the clutch start cancel switch. So if you leave it in gear with the e brake on (like I do when I park currently) and hit that button, the starter is trying to turn the engine and driveline with the e brake engaged. I don't think it would get the engine to turn enough revolutions to fire. I also don't know how much protection is built into the remote start either, would it keep sending voltage to the starter if it wasn't physically turning?
  20. Oct 25, 2013 at 8:49 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    thats pretty big isnt it? wish ks was more entertaining
