30 and younger thread
Discussion in 'Off-Topic Discussion' started by TacoMaster44, Feb 22, 2013.
  1. Nov 26, 2013 at 4:27 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Think they have heavier springs or some shit
  2. Nov 26, 2013 at 4:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Look the same just maybe a custom larger shaft..but shock itself I bet is the same.
    For the money. Better off with saws or saving up a tad more and getting foxes or kings or icons.
  3. Nov 26, 2013 at 4:34 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the boss setup has a larger shaft and piston IIRC
    might just be the shaft
  4. Nov 26, 2013 at 6:18 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I was thinking of going with the toytec boss coilovers since I want 3.5" of lift up front. If they are a piece of shit I would rather pay for icons or fox 2.5s.
    Actually the SAWs might do.
  5. Nov 26, 2013 at 6:32 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Below the belt :p
    Pamela Handerson
  6. Nov 26, 2013 at 6:34 PM
    Ice Horse
    Lauren
    Florida
    And Toytec has great customer service. Replaced one of my shocks, no questioned asked, and even put it in for me.
  7. Nov 26, 2013 at 6:37 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Awesome. When I bust a coilover I'm gonna drive out there so they can replace it. :p
  8. Nov 26, 2013 at 6:57 PM
    Ice Horse
    Lauren
    Florida
    I should clarify, they took the shock in and out of the coil, not off the truck lol
  9. Nov 26, 2013 at 7:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    First off...yes..id go for a different coil over as you can valve it to your truck and rebuild it later down the road and basically never have to get another whole front coil over again. Plus you can make them extended travel for when you get UCAs and bam. Mid travel front.
    Second off...you can't do 3.5'' up front. period. So get that out of your head right now. You'll bind your CVs even just mall crawling around like you do and blow boots as the fins will be touching all the time. use the adjustablity to your advantage and find the perfect amount of lift to where the fins barellllyyy touch at all and save your CVs. Plus, that'll mean less preload on the coils and that mean overall a much smoother ride.
  10. Nov 26, 2013 at 7:11 PM
    Ice Horse
    Lauren
    Florida
    I have a ripped boot I've been running for ages. I used to blow them all the time so I gave up lol. One of them has been surviving for a while though. I need to do the boot slide mod.
  11. Nov 26, 2013 at 7:12 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    BEER. someone give me an idea for my inactive giftee. :rage:
  12. Nov 26, 2013 at 7:13 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I have LR UCAs so I will go mid travel. What do I need to do to the SAWs for that? Icon sells a mid travel.
    Toyotec and Sonoran steel both say their 4runner kit gives 3.5" of lift up front. Lots of guys are running it. I will have weight up front though so it won't be 3.5" after weight.
  13. Nov 26, 2013 at 7:14 PM
    Bennett707
    Oregon
    How about I'm on the streets not posting on TW about my truck.
  14. Nov 26, 2013 at 7:17 PM
    Ice Horse
    Lauren
    Florida
    You already got a gift, you have a manlover now.
  15. Nov 26, 2013 at 7:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmmm..i don't..might be able to find one though.
    I have the Eibachs which in all relaitly..over lift the truck to 3.25'' or so. Making the boots rub right off the bat. Why i have blown two..
    SAWs, Foxes, Kings, and Icons can all be made mid travel. AKA extended travel. Only difference between a non extended and estended coil over is a small internal spacer. All you do is remove it and fit it with a smaller one and boom. Extended travel for about 1'' more droop..aka..mid travel. From there, its all about custom valving which..you can do on any of those COs.
    Yes the toytechs give up to 3.5'' lift...so do all the others. If you compress the coils enough with the adjustable colars, they will all go that high.
    Doesn't mean you should though. And i can almost promise most those guys aren't at 3.5''. Ever.
    Yes the weight is all part of the pros of adjusting them. Adding a winch or skids or second battery? no problem, just crank em back up to gain the .5'' you lost form the 50-100lbs or whatever.
    But that doesn't mean you should go 3.5'' every time. You need to watch the boots. An again, the more you compress the coils...the stiffer they are gonna ride. And then you'll want to change the valving. but valving can't fix everything.
  16. Nov 26, 2013 at 7:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Go out and feel the boots that are touching. I bet you can feel grooves being wore out. If they are super bad, id back off the CO a bit.
    Yea..haha i remember how grooved out mine where after just a month..
    did the boot slide mod but didn't help that much..
  17. Nov 26, 2013 at 7:28 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Thanks Monte. Pretty much figured out my lift then. I will do about 3" up front and 3.5" out back.
  18. Nov 26, 2013 at 7:43 PM
    Bennett707
    Oregon
    Tits or gtfo
  19. Nov 26, 2013 at 7:45 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  20. Nov 26, 2013 at 7:45 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i replaced the inners...no blown boots yet:D
