30 and younger thread
Discussion in 'Off-Topic Discussion' started by TacoMaster44, Feb 22, 2013.
  1. Jan 2, 2014 at 5:48 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Nope still no armor. I want to supercharge it first. But I needed a lot of work done, head gasket, a new front axel, rear axel seals, a new radiator, spark plugs, wires, and the 90k service. Plus what ever else was on the list I forget everything. But either way motor wise it should be a new motor. :D
  2. Jan 2, 2014 at 5:53 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Gotta prevent that strawberry milkshake!
  3. Jan 2, 2014 at 5:55 PM
    Hoyal
    Devin
    2013 Tundra
    Yes I do, hopefully the Desmond get worked out. Me and 4runner have bad luck:eek:
  4. Jan 2, 2014 at 5:55 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    What I don't understand is why 4Runners have that happen often but you rarely ever see it happen on a Tacoma even though they're the same.
  5. Jan 2, 2014 at 5:58 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    The 5 speeds don't have that problem. :)
  6. Jan 2, 2014 at 5:58 PM
    Hoyal
    Devin
    2013 Tundra
    I see more supercharged runners than I do tacomas.
    I bought this one because it had low miles but the previous owner did zero maintainance so I was stuck doing it all. But I knew I was going to have to drop te money. But it's better than another car payment at this time.
  7. Jan 2, 2014 at 6:02 PM
    PcBuilder14
    Brent
    Nor Cal
    It's not caused my superchargers, it's just amplified.
  8. Jan 2, 2014 at 6:05 PM
    Hoyal
    Devin
    2013 Tundra
    That's what I was getting at. Which is why I did all of it pre supercharger.
  9. Jan 2, 2014 at 6:07 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Pcbuilder is wondering why the 4runners get the strawberry milkshake, but not Tacomas.
  10. Jan 2, 2014 at 6:09 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Strawberry milkshake means?
  11. Jan 2, 2014 at 6:15 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    The transmission cooler section inside the radiator breaks and mixes ATF with coolant. Wrecks your engine and trans.
  12. Jan 2, 2014 at 6:19 PM
    Hoyal
    Devin
    2013 Tundra
    Yes. Not a good day for anyone.
  13. Jan 2, 2014 at 6:21 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Good for people looking for parts since they all end up in the salvage yard. There are a few around here.
  14. Jan 2, 2014 at 6:23 PM
    PcBuilder14
    Brent
    Nor Cal
    I remember the look that a friend with a 4runner gave me when I said I had no clue what he was talking about. I should probably do it though, can't hurt that's for sure
  15. Jan 2, 2014 at 6:27 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    There's really no way to know when it's going to break. It just goes and you are done for.
  16. Jan 2, 2014 at 6:29 PM
    PcBuilder14
    Brent
    Nor Cal
    Yup, I've got a bunch of maintenance to do so I might throw that in there.
  17. Jan 2, 2014 at 6:37 PM
    Hoyal
    Devin
    2013 Tundra
    Ouch!!
  18. Jan 2, 2014 at 6:43 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Sweet suspension mod bro
  19. Jan 2, 2014 at 7:24 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    so why does it only happen to 4Rs? my buddy put in an aux trans cooler to prevent just that. ive never even been warned about it with the truck, untill he told me
  20. Jan 2, 2014 at 7:41 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I'm not really sure. Tacomas and 4runners have different part numbers for radiators, so maybe there's a difference.
