30 and younger thread
Discussion in 'Off-Topic Discussion' started by TacoMaster44, Feb 22, 2013.
  1. Jan 19, 2014 at 1:56 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    could always settle for the 4" spindle right?
    37s on a 2wd...undeniable mall crawler lol
  2. Jan 19, 2014 at 1:57 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    As far as I know they only make 3" spindles for our years in prerunner.
  3. Jan 19, 2014 at 1:57 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I didn't want eibachs, as with no plate bumper i figured they'd be to stiff, and i didn't want 3'' in the front with a stock rear.
    If it was 2'' i'd jump on it, but a 3.5'' does kinda make me hesitate
    ok, and you have 3'' of lift in the rear (roughly)?
    I'm looking at shocks from oreily in case i do my springs before you get your shocks and found some ranchos with a 21.5'' extended length.
    3'' on top?
    more like 3'' from CO's+ x'' from the spindles+6'' from the DB
  4. Jan 19, 2014 at 1:59 AM
    95 taco
    95 taco Battle Born
    I thought i'd read that the crossmember cutting was optional.
    35.5's and bigger go on 4x4's,not 4x2's
  5. Jan 19, 2014 at 2:00 AM
    PcBuilder14
    Brent
    Nor Cal
  6. Jan 19, 2014 at 2:01 AM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Well I was gonna do the 3 inch spindles and do coilovers to get about 5-.6. Just enough to clear 35s. But yall think it might put too much force on the lower ball joint?
  7. Jan 19, 2014 at 2:02 AM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Tell that to my dad. His first truck was 2wd and he had 15 38s on it lol
  8. Jan 19, 2014 at 2:02 AM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, the eibachs gave a large amount of lift haha
    I did have about 2.75" of lift in the rear. Now it's only about 1" haha
    No, you have to remember that 6" drop bracket lifts comes with longer spindles ;)
  9. Jan 19, 2014 at 2:02 AM
    95 taco
    95 taco Battle Born
    No, it'd be like having 3'' of lift with 35's, so you'd basically be monte, but spayed and neutered.
  10. Jan 19, 2014 at 2:03 AM
    PcBuilder14
    Brent
    Nor Cal
    Probably will... that's 6" of lift on stock location lower ball joints haha that's why they have to do a drop bracket for 6" lifts. To bring the LCA down...
  11. Jan 19, 2014 at 2:05 AM
    PcBuilder14
    Brent
    Nor Cal
    Uhm no? The spindles theirselves would provide 3" of lift. Then you can get 6" lift coilovers and have 3" added on top of having the 3" spindles. But you can't do that because that's just the same as a 6" lift without the drop bracket, so it would put too much stress on the LCAs
  12. Jan 19, 2014 at 2:05 AM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Never seen that DB lift for us before...and it said the spindles had to be mated with long travel UCAs with 1" uniballs
  13. Jan 19, 2014 at 2:06 AM
    95 taco
    95 taco Battle Born
    What kinda truck?
    from everything i've read i'd be over 3'' and that no good on CV's, so i'm a 1.25-1.5''
    OK
    They do? i thought that the DB moved all the mount points down, so you used the stock spindle.
  14. Jan 19, 2014 at 2:06 AM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, just like when we need uniballs for extended travel coilovers.
  15. Jan 19, 2014 at 2:08 AM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    So I'd be good with just getting uniball ucas with the spindles?
  16. Jan 19, 2014 at 2:08 AM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    77 f150. No 6" spindles are fucking huge
  17. Jan 19, 2014 at 2:09 AM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, my cv's ripped at the clip haha
    No they come with lift spindles
  18. Jan 19, 2014 at 2:10 AM
    PcBuilder14
    Brent
    Nor Cal
    And you have to get longer shocks to accompany the extra lift between the uca and lca.
  19. Jan 19, 2014 at 2:10 AM
    95 taco
    95 taco Battle Born
    Hmm, on my 5 lug all the spindles did was drop where the hub mounted, the UBJ and LBJ stayed the same distance apart, which is what caused the tired to be pushed out.
  20. Jan 19, 2014 at 2:12 AM
    PcBuilder14
    Brent
    Nor Cal
    On 6-lugs the hub is already at the bottom right on top of the lbj, so they just make longer spindles that push the uca and lca farther apart.
