30 and younger thread
Discussion in 'Off-Topic Discussion' started by TacoMaster44, Feb 22, 2013.
  1. Mar 27, 2014 at 8:22 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    The manufacturer recommended oil for my truck is 5w-30, so using 10w-30 on an engine with 134,000 miles on it sounds reasonable to me. :notsure:
  2. Mar 27, 2014 at 8:22 PM
    cjacob
    cjacob Well-Known Member
    Lafayette, La
    '05 PreRunner SR5 TRD
    the gobi mounts pretty low right?
  3. Mar 27, 2014 at 8:23 PM
    PcBuilder14
    Brent
    Nor Cal
    They don't make one for my Tacoma.
  4. Mar 27, 2014 at 8:24 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Think of it this way. Your could weight is the first #. So you just made your oil thicker while cold. But while warm they are the same (second #).
    A heavier cold weight causes more wear where as lighter warm weight can leak more due to faulty seals at old age.
  5. Mar 27, 2014 at 8:26 PM
    PcBuilder14
    Brent
    Nor Cal
    I know this. Thicker oil also has better sealing abilities. This could go either way. It really just comes down to preference and the temps the vehicle will see.
  6. Mar 27, 2014 at 8:28 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    That's my point. Why make it thicker while it is already cold where it's less likely to leak but not increase the warm weight where most engines spend their time.
    So you only decreased the "leak" while the engine was cold
  7. Mar 27, 2014 at 8:30 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Like I said initially to each their own. I'm not trying to argue my point, just trying to share my knowledge. I'm going to do what I want, as I hope you do.
  8. Mar 27, 2014 at 8:31 PM
    PcBuilder14
    Brent
    Nor Cal
    True, but if the the vehicle doesn't experience cold temps then it's pointless.
    For our area I can see how a 5w-20 would be best (since it's the smallest range)
    But at the same time my vehicle has been from -5 to 118 degrees. So like I said, it all comes down to area.
  9. Mar 27, 2014 at 8:33 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I'm going to run 0w20 or 0w30 in my truck. Just to put that out there
  10. Mar 27, 2014 at 8:33 PM
    PcBuilder14
    Brent
    Nor Cal
    Would 0 winter weight not be too thin?
  11. Mar 27, 2014 at 8:35 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Also I have to say ambient temp is not the same as oil running temp. There's a huge difference until you start running huge coolers (which are meant to keep temps down from turbos)
  12. Mar 27, 2014 at 8:35 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    No it won't.
  13. Mar 27, 2014 at 8:36 PM
    PcBuilder14
    Brent
    Nor Cal
    Then why doesn't everybody run 0w-20?
  14. Mar 27, 2014 at 8:38 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Couldn't honestly tell you. I don't design everything, ha. I wish I knew the knowledge behind that.
  15. Mar 27, 2014 at 8:39 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I've ran zero in every car I've owned and lived here my entire life with no issues
  16. Mar 27, 2014 at 8:40 PM
    PcBuilder14
    Brent
    Nor Cal
    Haha okay, not trying to sound rude. Genuinely interested. Might switch to 5w-20 next oil change. Too bad I didn't get to test this in the really cold temps. My motor did like to hard start in those temps compared to other vehicles. Even with a high amp battery.
  17. Mar 27, 2014 at 8:40 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    To thin of a oil in a warm/hot environment would break down faster than a slightly heavier oil.
    And real thin oil doesn't lube as good as heavier oil (to a point)
  18. Mar 27, 2014 at 8:40 PM
    cjacob
    Lafayette, La
    all 7 years since you got your license
  19. Mar 27, 2014 at 8:41 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    :rofl:
  20. Mar 27, 2014 at 8:42 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I wasn't taking it as rude :cheers:
    I'm as interested in it as you. Each engine along with its pump had its own flow characteristics they design for a certain weight I believe but a lighter weight (from my experience has never done any harm)
