30' LED single row bar install behind grill
Discussion in 'Lighting' started by bassfish319, Jul 26, 2015.
  1. Jul 26, 2015 at 10:31 PM
    bassfish319
    bassfish319 [OP] Well-Known Member
    2014 Tacoma 4x4 TRD
    Seen a few installs for this same type of thing on TW so figured why not..I got a light bar off Amazon for cheap along with a wiring harness and relay to get things started. I dont have any formal training with electronics i.e. any kind of tech job, I have re wired speakers in a few old mercedes though and done basic things around the house. When everything showed up from amazon I went to Home Depot an picked up a 48' length of 1' square bar to mount the light bar onto an then stopped at Ace for a few xtra machine screws and went home
    1. I removed the grill and measured from one end just infront of the headlight on the driver side to the same spot on the passenger side, came out to 34'
    2. Cut the bar down to size, drilled and bolted it on the truck and then the 30' light bar went on with the wiring end heading toward the battery
    3. Hooked up the wiring harness and drilled a spot for the relay close by the battery
    Relay/Fuse
    4. After watching a few youtube videos on disassembling the panels to expose the wiring I got a coat hanger to guide the wires through to the inside cabin
    5. Popped out one of the two spots for an auxiliary switch and put the toggle in
    Its set just hi enough...but theres still some light being cut off on the bottom but thats alright its a little incognito addition for under 100$ and it does work as a decent light!
    This is on top of a parking structure in the city so its already pretty bright out but you can see a difference (bout 100/150 ft)
    Thanks for looking
    JimboAnz, 02Duck, 3milecreek and 2 others like this.
  2. Sep 10, 2015 at 9:08 AM
    Missouriprerunner
    Missouriprerunner Well-Known Member
    Adam
    STL MO
    2018 dbl cab sr5
    Saw this link in another thread, love it man
  3. Sep 11, 2015 at 7:22 AM
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    That's sweet. Got a link to the light? I'd like to check out the measurements
  4. Sep 13, 2015 at 7:32 PM
    KennyA
    KennyA New Member
    Jacksonville
    13 Tacoma dc PreRunner
    Speaker upgrade, blacked out badges,leather, window and lens tint
    Nikita L likes this.
  5. Oct 5, 2015 at 11:04 AM
    bassfish319
    2014 Tacoma 4x4 TRD
  6. Dec 11, 2015 at 8:50 AM
    Nikita L
    Nikita L Well-Known Member
    2015 Metallic Grey TRD Sport
    3 inch lift, 18 inch XD wheels, 33 inch MTs, LED headlights, Grillcraft mesh grill, LED interior
    @KennyA How big is your light bar behind your grill?
  7. Dec 11, 2015 at 10:22 AM
    Nikita L
  8. Dec 15, 2015 at 8:02 PM
    KennyA
    KennyA New Member
    Jacksonville
    30 inches. It was a pretty tight fit
  9. Jan 5, 2016 at 11:08 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
