30" Light Bar Install - Easier Than You Might Think
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rysingsun, Dec 16, 2015.
  1. Mar 18, 2016 at 10:15 PM
    #221
    sdguyman
    sdguyman Member
  2. Mar 26, 2016 at 11:57 AM
    #222
    3X0088
    3X0088 Well-Known Member
    Eric
    Indiana
    2017 TRD Sport dcsb 4x4
    Grill bar light, Pop N Lock, Bed Mat, G4 Fold A Cover Bed lights from mattgecko
    Well got the light bar centered vertically and then horizontally used 6" brackets, had to drill one hole each side , bolted it down. Got back and looked and it was still vertically correct but shifted 1/2 inch to the right so now it's not centered. My OCD is pissed. Dropped one screw on the skid plated and had to take it off to get to it and dropped a Allen wrench somewhere down there but just can't find it. In my humbled opinion the title of the thread "easier than you might think" is not correct. To some it might be easy , but for me it was a bitch. Now just need to wait for Amazon to deliver the switch I ordered and I can run the wiring, can't wait. But I do want to thank everyone that contributed to this thread, it did help.
  3. Mar 28, 2016 at 10:44 PM
    #223
    Faheygf87
    Faheygf87 Well-Known Member
    2016 Blue TRD Off Road MT
    How many of you are running your bar right off of the high beam? Thats were I have mine and it works like a charm, I have not tried leaving it on for extended periods of time yet either however. So far only a few minutes at a time(like you would with your high beams), no need for an extra switch, and a ton less wiring.
    Tacoma2GR likes this.
  4. Mar 28, 2016 at 10:47 PM
    #224
    Faheygf87
    I it possible(the way I did mine(very similarly)) to not cut the air dams and still have them fit, its just a PITA to get them back on.
  5. Mar 29, 2016 at 4:48 AM
    #225
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    Where did you tap in to the high beams? What color wire is it? Do you have any pictures?
  6. Mar 29, 2016 at 10:09 PM
    #226
    Faheygf87
    There are two wires going to each headlight bulb, a solid white, and a white with a black stripe. I forget which one is + but that's the one I tapped, then just used the chassis ground next to the battery.
  7. Mar 30, 2016 at 10:23 AM
    #227
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Nice, did you still use the led wire harness? When you get the chance I'd like to see some pictures
  8. Mar 30, 2016 at 12:09 PM
    #228
    gadawgs29
    gadawgs29 Active Member
    2016 Black Tacoma TRD Sport Crew Cab
    Touneau cover
  9. Mar 30, 2016 at 7:42 PM
    #229
    Faheygf87
  10. Mar 30, 2016 at 9:33 PM
    #230
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
  11. Mar 31, 2016 at 6:48 AM
    #231
    Faheygf87
    Nope. I was originally intending to use one, but apparently the one I bought was faulty. After a couple hours of trial and error with the relay we just said screw it and plugged it directly in.
    If I had to do it again id just buy a Y-type splitter for whatever kind of socket the high beam is and put the same type end on the led bar, that way no cutting splicing.
  12. Mar 31, 2016 at 9:17 AM
    #232
    gadawgs29
    Touneau cover
    is it yellow or cool white?
  13. Mar 31, 2016 at 1:16 PM
    #233
    Faheygf87
    White
  14. Mar 31, 2016 at 5:25 PM
    #234
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Finished the last mile of wiring and opted to back out of the the dash switch installation. I decided there were some advantages of a remote switch and installed the item below from Amazon for $38, coupled with a real inexpensive but bright 30" 180w light bar.
    I used 6 inch L brackets with self tapping screws into the aluminum bumper. Did not cut any of the grill off so it is not 100% flush, but did have to trim about 4" of air dam on each side of the radiator.
    Overall 2 hours install time and somewhat pleased. If I did it again I would trust my instinct and go for the flush mount by trimming that 2-3" space on the bottom of the front grill. Not that I cant go back and do it the way I wanted to initially but is open if I decide in the future.
    This harness had a second lead for what can I may use for engine compartment lighting toggled by a hood latch switch and an isolator switch for the light bar, as the controller turns on-off both end device leads.
    This remote switch had a lot of bad reviews due to what I suspect was 2.4ghz RF interference but I have not seen that.
    Amazon: OPT7
    [380w HD-Remote] LED Light Bar Wiring Harness Off Road [2 Lead 9ft] • Dimmer • Strobe • Keychain Remote • 80ft Range • Plug and Play • Waterproof
    Thanks to the OP and contributors for all the details and making this one of simplest mods on any Tacoma.
  15. Apr 4, 2016 at 3:46 AM
    #235
    Ledpipes
    Ledpipes Active Member
    Dave
    British Columbia
    2016 Tacoma TRD Sport
    Has anyone needed to clean the glass yet? Access issues with the grill in front?
  16. Apr 6, 2016 at 5:36 PM
    #236
    Faheygf87
    Haven't cleaned it yet, but it shouldn't be too tricky unless you're super ocd and have to get it like new.
  17. Apr 7, 2016 at 4:44 AM
    #237
    arkywally
    David
    2016 DCSB TRDOR
    My install was not a flush mount, but I am going back to my initial plan and get out the dremel or sawzall and do the flush mount...one reason is just that, cleaning, visibility. You get a fair amount of blockage with the recess mount and besides the flush mount does look better.
  18. Apr 7, 2016 at 2:52 PM
    #238
    TonyWhats
    TonyWhats Well-Known Member
    Anthony
    NYC
    2021 Powerwagon 75A
    Installed a Cali Raised 4D light bar yesterday. Stealth mounted, everything was straight forward, not sure if it was mentioned, but you should definitely attach one side of the bar to the mount first. Installing both mounts and then trying to attach the bar was nearly impossible. Gonna wire it up over the weekend.
  19. Apr 7, 2016 at 2:53 PM
    #239
    TonyWhats
    Anthony
    NYC
    2021 Powerwagon 75A
    And like everyone has said, it looks great behind the grill. Does not attract unwanted attention.
  20. Apr 7, 2016 at 6:50 PM
    #240
    TonyWhats
    Anthony
    NYC
    2021 Powerwagon 75A
    Yes the brackets are from Caliraised. No drilling at all. You put them in place over 2 existing bumper bolts. They fit perfect, bar looks great like it was meant to be stock.
