30" Light Bar Install - Easier Than You Might Think
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rysingsun, Dec 16, 2015.
  1. Apr 19, 2017 at 6:03 PM
    #401
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    For anyone who bought the Rough Country Flush Mount Light Bar, they are shipping free light bar covers if you want one. Contact their customer service on facebook, email, or phone and they will ship you one so you can drive legally in California or other states where it's needed for road driving.
  2. Apr 20, 2017 at 8:12 AM
    #402
    waydago
    waydago Well-Known Member
    Jack
    Jensen Beach, FL
    '16 Taco, TRD-OR, DCSB, SSM
    TRD Pro Exhaust, aFe Filter, Hard Tonneau, Predator steps, Pro Grille, Pro Fogs, Pro Badges, Pro Skid, Decal Inserts, H9 headlight swap, tailgate light bar, !7 in 4-Runner Pro wheels, 265/65-17 Falken Wildpeaks, AVS Bug shield and window shades, WeatherTechs, Sill protectors, pistol holster, Home Link mirror, Power tailgate lock, Redline Tuning hood struts, Caliper covers, Rigid Radiance light bar.
    Waiting on a Rigid Radiance 30 inch light bar with amber backlight from "sidetracked". Will post process and pics in the near future. Planning on a custom install attaching to crash bar behind the grille & a separate SPDT (on-off-on) switch for each function; the main LEDs and the backlight. I plan to have the LEDs switch on with the high beams. Or it will be independent and can activate with switch in opposite direction or be off. The backlight will work with headlights in the same way. At least that is my plan. We all know the old saying," the best laid plans....."
    EDIT: 4-21-17
    Rigid Radiance light bar and cable arrived last night very quickly from "sidetracked". I decided to do the hard part first and that to me was running the cable into the cab from the engine bay. And in order to have a few extra wires for future use and my planned operation of the LED section and the backlight I parallel ran an old four-wire cable I had laying around. After some pondering and contemplating the method used by others I opted for a different plan. Others have cut off the nipple on the driver's side grommet and proceeded through that small hole. Wasn't going to work for me what with the size of the Radiance cable and associated connectors and the extra four wires; pretty fat. So after removing the driver's side sill protector and the kick plate I crawled in with a flashlight and a pair of diagonal cutters. Pushed aside a piece of the carpet underlayment and I snipped part of the grommet just below and to the side of the hood release cable. I snipped until I thought it was large enough for my fat cables to get through. I pushed a large gauge bare wire through it and taped it and the cables together with heavy duty electrical tape. The whole package came through rather easily this way. After completion I will throw some silicone onto this entry point. I tucked the wires aside and buttoned up the kick plate and sill protector to wait for the switches to come. Inside the cab I routed the Radiance cable and my spare cable so as not to interfere with anything else. I mounted the relay under the nut holding the relay and fuse panel. It is grounded. Attached the main ground to an existing ground connection on the fender wall. Headed to the hardware store to get some threaded inserts to be installed on the crash bar. Into the inserts will go mounting screws through the Radiance brackets. Hope to be well-prepared before removing the grille assembly.
    UPDATE to follow when installing the light bar.
  3. Apr 21, 2017 at 11:43 PM
    #403
    Metonymy
    Metonymy Well-Known Member
    2017 White Tacoma TRD PRO
    None (yet)
    Rigid 30" bars... Will the E-series dual row fit, or do I have to go with the SR-series single row?
  4. Apr 22, 2017 at 12:38 AM
    #404
    80sforlife
    80sforlife Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    Correct me if I'm wrong, don't you have to trim the two air dam panels that are behind the grill to make room for the brackets? At least, that's what I saw in the Caliraisedled installation video.
  5. Apr 22, 2017 at 3:15 AM
    #405
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    Yes you do or remove them entirely.
  6. Apr 22, 2017 at 6:07 AM
    #406
    waydago
    Jack
    Jensen Beach, FL
    I think it depends on how you want to mount it. If you go behind the lower grille without cutting out the lower section of your grille the dual row should fit. Only the single row will fit in the cut out slot beneath the surround. I have not mounted my Radiance yet and I am hoping to attach it to the crash bar, behind the grille, with the brackets provided by Rigid. Fingers crossed on that. Hoping not to cut the air dams. They are flexible enough to push sideways to accommodate the bracket mounting. Might even reverse the position of the brackets facing them inwards. The Radiance, while being only single row, is pretty tall. Check Rigid's web site. They have an excellent catalog which gives every one of their product's exact dimensions and specs.
    If my crash bar mounting reaches a snag I would be interested to know if the Cali Raised mounts will mate to the Rigid bar.
  7. Apr 22, 2017 at 10:38 AM
    #407
    Metonymy
    None (yet)
    Ok. I will not be cutting the grill out, so if it mounts just behind, that's fine by me.
  8. Apr 22, 2017 at 11:31 AM
    #408
    waydago
    Jack
    Jensen Beach, FL
    My crash bar mounting effort met the proverbial snafu. After a couple hours of cussing and drilling and cussing some more I decided to leave it the pros. If they will tackle it that is. I got the bar into place behind the grille after removing the air dams and moving the lower oil cooler out of the way. That is standard procedure for a behind the grille install. I had the holes drilled in the short crash bar sections on the left and right side. These are the perpendicular ones to the crash bar across the front. They lined up nicely with the Radiance brackets installed on the light bar. So far so good. I knew spacers would be needed to get the bar raised and centered up behind the grille opening. Careful measuring told me how many nylon spacers I would need. I had 5 inch 1/4-20 bolts that reached through the 3 1/2 crash bar section. Oh what good planning I did--NOT! I got everything ready to bolt in place and realized it still was not high enough be centered. Ok, put some more spacers in. Well, that ain't gonna fly. The light bar was touching the bottom of the center hood release bracket. Won't go any higher in this position. I removed all the mounting hardware and moved the bar on top of the long crash bar. This was my original plan but getting the bolt holes drilled through would have entailed removed the entire lower bumper assembly to be able to get at the screws to attach the nuts. So I tried the rearward position knowing I would need spacers to raise it. Even on the front bar some spacers would be required and the bar would have to go as far forward as possible to avoid hitting the hood release bracket. So my initial conclusion is that the Radiance bar is not a good fit for the Tacoma because of its height. The dimension from the center of the bar's mounting stud to the bottom of the supplied bracket is 2.95 inches. Even on the front of the crash bar this 2.95 inches in not enough to get it centered. Fits perfectly lengthwise, but....Conversely this same dimension on the single row SR series is 1.125 inches.
    I buttoned everything up minus the air dams for the time being. I secured the light bar on top of the crash bar and will drive around like that until a better idea comes up. I think the only solution may turn out to be Cali Raised type brackets that "might" get it into a better forward and higher position. For "metonyme" be very careful about your selection of a light bar. Check the dimensions carefully. Compare the two-row Rigid you are considering to the Radiance as to size/dimensions in the Rigid catalog. If they are close, the same problem may come up unless a different mounting is designed. I once considered threaded inserts to go into the crash bar. But I backed off when the hardware guy said the ones I looked at were for concrete. There must be some for aluminum.
    To be continued...
    Any and all suggestions are welcome. :help: Going for a beer!
  9. Apr 22, 2017 at 7:41 PM
    #409
    Blue16TSS
    Blue16TSS Well-Known Member
    CORPUS CHRISTI,TX
    BBP 2016 TACOMA SR5/TSS 4x4
    Door seal covers, front window tint,,fox 2.0 front & rear shocks,TRD grill emblem,vent visors.
    Just installed a 32 inch light bar using this same setup and worked perfectly.hope you don't mind.Still need to wire it up,the Cali Raised ditch lights and brackets should be here Monday :pout: what switch did you guys use the one that came with the wire harness doesn't fit the blank in the dash?
    waydago likes this.
  10. Apr 22, 2017 at 8:41 PM
    #410
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I installed my own switch bank.
    choupick, waydago and obz like this.
  11. Apr 22, 2017 at 10:01 PM
    #411
    Blue16TSS
    CORPUS CHRISTI,TX
    I like #4:cheers:
    nevadabugle likes this.
  12. Apr 23, 2017 at 4:36 AM
    #412
    waydago
    Jack
    Jensen Beach, FL
    "nevadabugle"--great job. I looked at those L brackets at Lowes yesterday after I was unable to get mine high enough. Nice fabrication. I'm thinking of the L brackets mounted forward to the main crash bar with stainless screw inserts. Back to my original plan but with taller brackets. What size were your brackets? How tall is the Cali light bar? My Rigid Radiance is pretty tall even though it's only one row of lights. Either way will succeed come hell or high water.
  13. Apr 23, 2017 at 5:06 AM
    #413
    nevadabugle
    Elko, NV
    6" I think.
  14. Apr 23, 2017 at 1:13 PM
    #414
    waydago
    Jack
    Jensen Beach, FL
    New
    SUCCESS! Don't know why I didn't think of it before--duh! Instead of trying to mount it on crash bar I hung it on the cross member with the Radiance brackets pointed inward and attached to mending bars. Attached it from top. Light bar just touched the lower piece attached to that cross piece. Don't know what any of them are called. Anyway it's on and secure. Can't say I have seen any light bars mounted this way. In my excitement I forgot to put the air dams back on. Another day. Wiring when I get switches. It'll be ready for smoke test. Skill and science win out over ignorance force and brutality some wise man once said.
    SAND$$$, SilverII and Blue16TSS like this.
  15. Apr 23, 2017 at 1:19 PM
    #415
    Blue16TSS
    CORPUS CHRISTI,TX
    Nice good job:thumbsup:
  16. Apr 24, 2017 at 2:35 PM
    #416
    Blue16TSS
    CORPUS CHRISTI,TX
    The cali raised ditch lights and brackets came in,now waiting on the switches
  17. Apr 25, 2017 at 1:04 PM
    #417
    waydago
    Jack
    Jensen Beach, FL
    Here is the final synopsis (minus the switch choices) of my Rigid Radiance light bar with backlight. The grille has to come off and there are plenty of videos and descriptions of that process. It literally takes about a minute with a 10mm socket to remove two bolts and a small blade screwdriver to remove two plastic clips. I mounted the light bar unconventionally by hanging it. Very simple in the final analysis. Every light bar potentially could be mounted this way without the need for additional brackets except for two six-inch mending bars from the hardware store. Of course it does depend on the kind of brackets supplied with your light. My Rigid brackets, 3 inches tall, were faced up and mounted reversed to point them inwards and the mending bars attached. I used the existing slots in the support cross piece which allow for some left-right adjustability. I drilled an extra hole in each mending bar so there are 4 total bolts attaching it. I pulled out the plastic clips on either side and used those holes. IMG_1540.jpg IMG_1541.jpg IMG_1542.jpg IMG_1543.jpg
    The cable run was done from the inside by snipping the rubber grommet beneath and just to right of the hood release cable. I ran an extra four wires along with the Rigid cable for future use. The sill protector and kick plate come off for this procedure.
    IMG_1540.jpg IMG_1541.jpg IMG_1542.jpg IMG_1543.jpg IMG_1517.jpg IMG_1518.jpg IMG_1519.jpg IMG_1520.jpg IMG_1521.jpg
    I only temporarily wired up the supplied round rocker switches until I decide on the on-off-on type I want to use. At first the lights came on without the ignition or accessory on and were controlled only by the switches. Did not want that. I looked for a switched source to take the wire off the battery and tap it into. I settled under the fuse relay compartment and used a T-Tap to attach the red lead once going to battery to blue wire shown. Drilled a small hole and ran wire up into fuse-relay compartment.
    IMG_1540.jpg IMG_1541.jpg IMG_1542.jpg IMG_1543.jpg IMG_1517.jpg IMG_1518.jpg IMG_1519.jpg IMG_1520.jpg IMG_1521.jpg IMG_1548.jpg IMG_1549.jpg IMG_1550.jpg IMG_1551.jpg IMG_1554.jpg
    The Rigid radiance is a pretty cool light bar. The two switches operate the LED main section and the backlight independently. I'm hoping to replace those with SPDT (on-off-on) switches and control the light bar from the high beams (for the LED) and the headlights (for the backlight) when so desired. Backlight is not much visible during the day.
    Apologize for multiple pictures of the same thing. Was not intending that.
    SilverII and gargamel05 like this.
  18. Apr 26, 2017 at 5:48 AM
    #418
    waydago
    Jack
    Jensen Beach, FL
    When installing my Rigid Radiance light bar with the hanging method I used, i.e. reversing the brackets and using mending bars to hang light bar from cross support, I cut nothing. The air dams are flexible enough to reinstall without cutting them. I know the Cali Raised brackets do require some cutting of the lower section of the air dams to get them back in after brackets and light bar are installed. I was happy not to cut. Light bar fits neatly behind the lower section of the grille. And some light bars and associated brackets even require this section to be cut out. Was not about to do that for aesthetics and for security reasons.
  19. Apr 26, 2017 at 5:54 AM
    #419
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    Sweet. I just ordered same light bar. Now i have an idea of how it looks like behind the bumper. Good job buddy!!!
  20. Apr 26, 2017 at 5:56 AM
    #420
    waydago
    Jack
    Jensen Beach, FL
    Thank you! I'm very happy with it. You will be too.
    gargamel05[QUOTED] likes this.
