30" Light Bar Install - Easier Than You Might Think
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rysingsun, Dec 16, 2015.
  1. Feb 26, 2018 at 9:23 PM
    #581
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
    They did for me.
  2. Feb 27, 2018 at 4:42 AM
    #582
    JonPaula
    JonPaula Well-Known Member
    Jonathan
    Was it hard to mount ? Just asking because i saw a review on Amazon and someone said it didn't work at all..
  3. Feb 27, 2018 at 5:48 AM
    #583
    TSmoove
    Trevor
    Atlanta, GA
    2017 Tacoma
    Brackets weren’t hard to mount. Depends on the light bar
    rlx02 likes this.
  4. Feb 27, 2018 at 6:09 PM
    #584
    JonPaula
    Jonathan
    Looks great ! Thanks for the help
  5. Mar 6, 2018 at 5:48 AM
    #585
    metsfan6734
    metsfan6734 Well-Known Member
    Eric
    Upstate NY
    2017 MGM TRD Off-Road DCSB
    Heres the final install!
    Here is how I wired the button, I was concerned about voiding the warranty, so I didn't tie into any lights on the dash. The button lights up when the led is turned on and is not lit normally (not a big deal to me)
    light bar off
    light bar on
    KnoxTac0713 and yub like this.
  6. Mar 6, 2018 at 7:44 AM
    #586
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I have been reading this thread with interest, but have a few questions. I'm one of those "leave no mark" folks who like to direct add, remove/replace, make harnesses, etc. so that anything can reversed. Most of what I have read seems to indicated that any of these kits require trimming/cutting of some sort. Are there any options that "just fit" as bolt on without physical modifications?
  7. Mar 6, 2018 at 7:59 AM
    #587
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
  8. Mar 6, 2018 at 8:19 AM
    #588
    metsfan6734
    Eric
    Upstate NY
    The install I did, didn't require any trimming. I even left the air dams in, even though the brackets do push against them. I am the same way I didn't want to install the light bar in a way that couldn't be reverted back to stock. This was more difficult however, as the air dams allow very little room to tighten everything onto the brackets.
  9. Mar 6, 2018 at 10:02 AM
    #589
    Looney
    Looney Well-Known Member
    What brackets did you use? Also, was that harness pretty much plug and play?
  10. Mar 6, 2018 at 10:28 AM
    #590
    Sullivan0930
    Sullivan0930 Well-Known Member
    Daniel
    2024 TRD Offroad. iforce max. Bronze oxide.
  11. Mar 6, 2018 at 10:34 AM
    #591
    metsfan6734
    Eric
    Upstate NY
    https://www.amazon.com/gp/product/B06ZY3J8BK/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B076FCS1X2/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    yeah, the wire harness was easy to install. the hardest part was getting the light bar to fit. There isn't a lot of spare room to work with.
    The brackets are easier to get the light bar on, since they have a slot which most other designs don't have. And they are 30$ about half the price of most other brands of brackets.
  12. Mar 6, 2018 at 10:37 AM
    #592
    metsfan6734
    Eric
    Upstate NY
    I also bought a 35$ LED bar, and to be honest it seems to be pretty good quality to me and is more than bright enough for what I will be using it for.
    https://www.amazon.com/gp/product/B01DNYCJQW/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
    and here is the link to the switch I used for anyone who wants it
    https://www.amazon.com/gp/product/B01M3VX73R/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    So the whole install was just over 100$, which is about a 3rd of what I see a lot of other people paying. Though I can't speak to the quality of their setups, this setup seems pretty rugged, is very bright and looks super clean in the end.
  13. Mar 6, 2018 at 10:54 AM
    #593
    VTSR516
    VTSR516 Well-Known Member
    Vermont
    2016 SR5
    NEW: LT265 75 R16 General Grabber AT2's Hood and window deflectors ARE cab high color matched CX series cap weathertech floor mats Rough country 30" 15,000 lumen light bar in front grill
  14. Mar 6, 2018 at 10:54 AM
    #594
    VTSR516
    Vermont
    2016 SR5
    Rough Country 30"
  15. Mar 6, 2018 at 10:59 AM
    #595
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Thank you for the info and details of your install. I appreciate the feedback before I made stupid mistakes.
  16. Mar 6, 2018 at 11:01 AM
    #596
    smugly
    Doug
    Just keep an eye out for any seal leakages, so it doesn't get away on you. The seals have been known to fail on those.
  17. Mar 6, 2018 at 11:59 AM
    #597
    metsfan6734
    Eric
    Upstate NY
    already keeping an eye on it. Purposely soaked it with the hose to make sure it was waterproof like they claimed. staying dry inside so far! not bad for the price!
    Not too concerned, it came with a 2 year warranty and is garaunteed IP67 waterproof
  18. Mar 6, 2018 at 1:10 PM
    #598
    smugly
    Doug
    And I wasn’t trying to be a negative Nancy, was just giving you a heads up to watch for it , after doing the massive research that I had done before buying my lightbar, I do remember that was one of the main complaints from those lights.
  19. Mar 6, 2018 at 1:24 PM
    #599
    gilcrestk
    gilcrestk Well-Known Member
    2016 Tacoma TRD O/R DCSB
    Did you connect the wires with just electrical tape or did you solder them together?
  20. Mar 6, 2018 at 6:26 PM
    #600
    metsfan6734
    Eric
    Upstate NY
    I stripped both wires back about an inch or so and twisted them into each other and then used electrical taped to protect them for shorting out or coming disconnected
