30" Light Bar Install - Easier Than You Might Think
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rysingsun, Dec 16, 2015.
  1. Aug 10, 2018 at 6:11 AM
    #661
    craven_morhead
    craven_morhead Active Member
    I'm no expert, but my understanding is that splicing into the bed light wire is taking the place of the add a fuse, since that wire is only energized when your headlights/dash lights are on
    Forge likes this.
  2. Aug 10, 2018 at 6:19 AM
    #662
    Forge
    Forge Well-Known Member
    Rick
    You think the bed light could handle two switches spliced into it?
  3. Aug 10, 2018 at 6:25 AM
    #663
    craven_morhead
    Yep
    Forge likes this.
  4. Mar 1, 2019 at 4:53 PM
    #664
    Batman!
    Batman! Well-Known Member
    Juan
    IG: moddedtacomas
    If I leave the grille air ducts off what are the affects? or do it matter at all whether they're on or off
    FloridaSon likes this.
  5. Mar 1, 2019 at 5:16 PM
    #665
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Anyone know how to wire a CH 4x4 or mictuning switch to a Baja Designs S8 light bar and harness? Most instructions I see mention 3 wires coming from the harness, but mine only has 2 - a red and a black.
  6. Apr 10, 2019 at 6:30 PM
    #666
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Installed mine today. Went with the Randy Ellis Design brackets. Removed one air dam for install then put it right back. No trimming needed. I did discover that you can remove the lower trim panel to get better access to the bolts that go from the bracket to the light bar.
    Made making adjustments a whole lot easier. 2 bolts and a bunch of clips. Just pull, ha.
    I also went with the Caliraisedled switch bracket. I agree with craven_morhead, the switches protrude further than expected. On the plus side, it was only $15 instead of $35. I'll see how my OCD likes it, ha.
    How high are you guys aiming your light bars?
    Forge likes this.
  7. Apr 10, 2019 at 9:13 PM
    #667
    shaggy135
    Actually the bolts didn't hold it on at all. It was 2 blue clips. Found those on the ground when I was cleaning up.
  8. Apr 24, 2019 at 4:22 PM
    #668
    El_Jefe
    El_Jefe Well-Known Member
    Jefe
    San Diego
    2019 Taco TRD OR DC Cavalry Blue
  9. Oct 19, 2019 at 3:22 PM
    #669
    DJKham
    DJKham Member
    Just got the Rigid Radiance Plus (2nd generation) bar installed and will do wiring next, using (provided) harness and Mictuning switches w/3D printed mounting plate.
    Used the Caliraised brackets for the Rigid 30” bar and they worked great. Couple tips for anyone attempting this exact install:
    1) you can’t get this specific light bar in without unbolting the transmission oil cooler (2 x 12mm bolts)
    2) You need to cut the left and right air baffles when using the Caliraised brackets but this really isn’t a big deal (2 min with Dremel- looks stock once you clean it up) and the brackets will somewhat deflect the airflow that the lower baffles would have in the first place. I was on the fence as I didn’t want to cut anything but now having done it, can definitely say it’s a good solution
    3) leave all the mounting hardware loose until you get the light bar leveled, then tighten up the brackets last as they allow you to adjust for height.
    BangosTaco and crackils like this.
  10. Apr 13, 2021 at 1:09 PM
    #670
    DannyD
    DannyD Well-Known Member
    Dan
    BC Canada
    2021 DCLB
    Anybody ever cut the plastic grill with a double row setup. Think it will look like a dog chewed it up?
    Thinking about getting this thing but the double rows position light would be right in the middle. They have a single row aswell but less light output.
  11. Apr 13, 2021 at 1:16 PM
    #671
    shaggy135
    Didn't cut mine when I had one.
    smugly likes this.
  12. Apr 13, 2021 at 2:00 PM
    #672
    DannyD
    Dan
    BC Canada
    2021 DCLB
    Yah looks great. But this bar I'm looking to buy has a second amber light running down the center used like a day time running light. Looks sick! My truck is still on order so trying to gauge from pictures how noticeable it would be thst I cut the plastic out in front of a double row. Vs getting a flush bracket and getting a single row, which hides the cutting
    Screenshot_20210413-140336.jpg [
  13. Apr 13, 2021 at 2:30 PM
    #673
    shaggy135
    Now I get it. That is a cool light. Middle bar would probably cover most of that middle LED. Could get even crazier and just get a low pro bumper and put a bar in that, ha. That's what I did. And I do see that your company offers a 22" in the same flavor.
    https://brightsource.ca/product/siberia-22-double-row/
    smugly likes this.
  14. Apr 13, 2021 at 2:54 PM
    #674
    DannyD
    Dan
    BC Canada
    2021 DCLB
    Saving the new bumper for the 5 year old truck mid life crisis lol. I'll probably end up going with the single row flush mount bracket. Atleast that way I know it works
    smugly likes this.
  15. Mar 21, 2024 at 11:57 AM
    #675
    bojangles93
    bojangles93 Member
    Black Tacoma TRD Pro MT
    I know this is an older thread, but hoping I may be able to get an answer.
    About to add light bar to my '23 Taco and am curious about switch wiring.
    I have this to simplify the wiring and aoid cutting/splicing...
    Does this mean I will only need to use the add a fuse to an interior fuse for the green and then connect the remaining RED to the blue wire on the relay harness? Essentially, I would end up capping off the white and black wires coming from the harness...
    Am I missing something?
    smugly likes this.
