30" Light Bar Install - Easier Than You Might Think
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rysingsun, Dec 16, 2015.
  1. Dec 31, 2015 at 2:28 PM
    #81
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Please don't quote a huge post like that
  2. Dec 31, 2015 at 3:13 PM
    #82
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
    fshams likes this.
  3. Dec 31, 2015 at 4:20 PM
    #83
    Z50king
    Eric
    Southern California
    Stock and loving it
  4. Dec 31, 2015 at 4:29 PM
    #84
    Elmo
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    I went back and made them thumbnails for that exact reason. Maybe it didn't change them. Maybe I can delete and repost.
  5. Dec 31, 2015 at 4:48 PM
    #85
    Elmo
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
  6. Jan 2, 2016 at 1:48 PM
    #86
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    Have you figured out if you want to add any other switches anywhere else where you would put them since there are no pop out plates??? This is my current dilemma. Thanks. Looks great.
  7. Jan 2, 2016 at 5:11 PM
    #87
    Elmo
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    What switch source did you use ?
  8. Jan 2, 2016 at 7:14 PM
    #88
    proven21
    Im not sure if I understand the question? forgive my ignorance.
  9. Jan 3, 2016 at 6:31 AM
    #89
    Elmo
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    I'm sorry, I am trying to purchase a switch and the one you used is what I need also. Do you have a company and part number that you purchased the switch from?
  10. Jan 3, 2016 at 2:45 PM
    #90
    proven21
    mr_jrock likes this.
  11. Jan 14, 2016 at 11:24 AM
    #91
    jadoiron
    jadoiron Well-Known Member
    2016 Tacoma 2x4 Access Cab Barcelona Red Metallic
    AWESOME tutorial. I just ordered the parts mentioned and can't wait to get going. Hopefully the light bar will arrive before 2018.
  12. Jan 14, 2016 at 11:36 AM
    #92
    proven21
    so red 1 goes into relay and then red 2 goes into the dimmer switch you spliced into ?
    TRULIFE likes this.
  13. Jan 15, 2016 at 11:06 AM
    #93
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    I have no garage, I order all the parts just sit in my basement wait for the spring time to do it.... I can't wait to put it on
  14. Jan 16, 2016 at 1:35 PM
    #94
    proven21
    so since yours is wired so that it can turn on when the truck is off your switch is constantly lit up drawing power from the battery correct? isnt that not a good idea?
  15. Jan 20, 2016 at 5:01 PM
    #95
    W00ds3oo
    W00ds3oo Well-Known Member
    Northern California
    16 TRD sport
    I ordered a cali raised 31.5 bar that comes with a wiring harness. I also bought the Mictuning switch, that came without any sort of wiring diagram. I would prefer that there is not any light on when the car if off and the switch diming with headlights would be nice but not crucial. How do I wire this thing? 4 wires on the plug are the following: Black - Red/White - Red/White - Green/Yellow
  16. Jan 20, 2016 at 7:12 PM
    #96
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    It just depends on the switch type he used. The Contra V swithces that I used have two leds. One is independent of the switch being on. So I wire the independent led (words) into a circuit that is only hot when the parking light's are on. That way when the parking lights are on the independent led comes on. However the switch will still turn on the led bar and illuminate the upper led (pictograph) weather the parking lights are on or not. Hope that makes sense.
  17. Jan 20, 2016 at 7:30 PM
    #97
    GrisMunkyNinja
    GrisMunkyNinja Well-Known Member
    '16 3.5 AC 4x4 SR5 MGM
  18. Jan 21, 2016 at 5:54 AM
    #98
    proven21
    Yeah it definetely does, this is my first time messing with switches at all in a vehicle, and upon my first attempt I wired the sasquatch push button switch in wrong with a constant power. So even when the car was off the switch was still lit. I had to reverse my wiring and then that worked so now the switch functions as designed.
    nevadabugle[QUOTED] likes this.
  19. Jan 21, 2016 at 12:07 PM
    #99
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    Quick question.... In step 8 you mention using pale green wire from the exterior cab light switch. Where is this switch?
  20. Jan 23, 2016 at 1:06 PM
    #100
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    Just finished up the install.. very easy. I had to unmount both the brake and tranny cooler to shoe horn the bar in from the bottom. I did both installs... right to the plastic which didn't feel too secure and then opted for the corner braces. I had to go 5" braces and trim about an inch off the bottom to get it to fit on the aluminum sections. Then a couple washers underneath to get it to the right height. Ended up really secure and really clean. Took the time to derp the grill insert while I was at it. Quick question on the above...does the wiring only apply to the lit up switch or will that also limit the light bar to power only with accessories on. As I have it, the light bar is operable at all times, which I'm not keen on.
    4lo likes this.
