30" Light Bar Install - Easier Than You Might Think
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rysingsun, Dec 16, 2015.
  1. Jan 23, 2016 at 1:18 PM
    #101
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    My switch will turn on the bar at anytime (key off/on, lights off/on, etc.). Basically the wiring is Batter to auxillary fuse block, fuse block to relay, Ground to relay, relay to switch, 12V power to switch, relay power to bar, ground to bar. Then to power the lower led in the switch, I tapped into a wire that was only hot when the parking lights are on. Of course this is oversimplified. If you wanted to only have the switch send power to the bar when the key is on you would need to run your power from somewhere other than directly from the battery.
  2. Jan 23, 2016 at 1:20 PM
    #102
    nevadabugle
    Elko, NV
    or.....you could also find a 12v power source for the switch that is only hot when the key is on.
  3. Jan 23, 2016 at 1:23 PM
    #103
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    I have one of the mictuning switches and a wiring harness with a switch that I want to replace, which wires go to which?
  4. Jan 23, 2016 at 1:39 PM
    #104
    nevadabugle
    Elko, NV
    If your microtunung switch has an independent led (words or symbol that work separate from the actual switch) then I assume your new switch has:
    1. A wire that goes to the relay
    2. A wire that powers the switch
    3. A wire that powers the independent led
    4. A ground wire.
    I am not familiar with the mucrotuning switch so this is a guess.
    Also, your existing switch on the harness I assume has three wires.
    1. Ground
    2. Power
    3. Wire going to the relay.
    Remember all the switch does is make the relay switch on and off.
  5. Jan 23, 2016 at 1:44 PM
    #105
    nevadabugle
    Elko, NV
    6174696f6e2d6361722d776972696e672d6469616772616d2e676966.gif To figure out witch wire is witch on your harness trace them back to the relay.
  6. Jan 23, 2016 at 2:02 PM
    #106
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    exactly, but was hoping someone already had before I start looking at everything and working my way back.
  7. Jan 23, 2016 at 2:06 PM
    #107
    nevadabugle
    Elko, NV
    20151125_174001.jpg Here is where I tapped into for switch power. I think it's for the trailer brake. One is always hot. Used it for switch power. One is only hot with the parking lights on. Used it for Lower led power.
  8. Jan 23, 2016 at 2:21 PM
    #108
    TheTacoma
    Birmingham, AL
    So I connect the ground to the ground correct? not separately grounded?
  9. Jan 23, 2016 at 2:36 PM
    #109
    nevadabugle
    Elko, NV
    Either way would work. But if you remove the switch you have and put in the switch you bought. Yes, ground to ground, power to power, relay lead to relay lead.
  10. Jan 23, 2016 at 2:38 PM
    #110
    nevadabugle
    Elko, NV
    Depending on how your switch works you could probably leave the fourth wire disconnected in the short term. My guess is it only powers the light for the wording on the switch.
  11. Jan 23, 2016 at 3:35 PM
    #111
    TheTacoma
    Birmingham, AL
    Thank you so much!!:bowdown: I got it wired up. I did leave the 4th wire unconnected for now. I was thinking I could run it to the fuse panel right below the switches and use a jumper fuse.
    (I do not have one yet for the pods, the light bar one is hooked up to the pods temporally)
    DubfromGA and nevadabugle like this.
  12. Jan 23, 2016 at 4:32 PM
    #112
    nevadabugle
    Elko, NV
    Great job. Disregard the picture of the trailer brake harness. That is on my third generation. It is not possible to tap into the fuse block on the 3rd Gen but luckily for you you have a second gen. Should be plenty of places under there on yours. Search this forum and I guarantee there is a picture of your fuse panel showing what is hot and when.
  13. Jan 23, 2016 at 5:28 PM
    #113
    mlm682577
    mlm682577 Well-Known Member
    Mark
    DFW, TX
    2016 Blazing Blue Tacoma TRD OR DCSB
    60+ mods and counting (mod-aholic)
    Installed my light bar today. I still need to run the harness and put the switch in...but mounting it is complete. Many thanks to the OP (rysingsun) and MJBuscg. I still need to run the harness and install the switch but the bar is installed.
  14. Jan 23, 2016 at 5:56 PM
    #114
    ale214
    ale214 Well-Known Member
    Chatham, IL
    2016 OR 4x4 White
    Looks good. What light is that?
  15. Jan 23, 2016 at 6:10 PM
    #115
    mlm682577
    Mark
    DFW, TX
  16. Jan 23, 2016 at 8:05 PM
    #116
    texanhoyt
    texanhoyt Well-Known Member
    Seth
    2016 Silver Tacoma TRD off road
    Nice work tagged for later
  17. Jan 24, 2016 at 8:16 AM
    #117
    mlm682577
    Mark
    DFW, TX
    I took pictures of the install process, but they really are not much different from other postings. I used the 90-degree brackets idea that MJBuscg used and I will be using the wiring instructions that rysingsun posted. The toughest part of installing the light bar was getting the height right so the bulbs were centered inside the lower grill.
    Elmo likes this.
  18. Jan 25, 2016 at 1:43 PM
    #118
    Woody79
    Woody79 Well-Known Member
    Kevin
    Utah
    2016 DCSBOR 4x4 Quicksand
    Icon Stage 2 TRD Pro Wheels 285/70/17 BFG KO2's Header Rail Extang Solid Fold 2.0 Tonneau Cover
    This is a good thread on home-made mounts and wiring.
    For those looking for a no drill mounting solution I've been following another member on here whose been fab-ing one up that's for sale. I'm not affiliated with him in anyway but have been impressed with his workmanship so thought I'd post it here. He just got it done and posted in the marketplace today. Here's the link for those who are interested: https://www.tacomaworld.com/threads/32-led-light-bar-mounts-stealth-and-flush-styles.412396/
  19. Jan 26, 2016 at 11:41 AM
    #119
    nbzero
    nbzero Member
    2015 TRD Sport Magnetic Gray
    none (yet)
    I have a very similar issue trying to figure out how to connect my switch. I bought the OPT7 wiring harness which came with a dashboard switch already wired in, similar to the pictures posted above. The harness came without any instructions whatsoever, but I was able to establish continuity as follows from the wires on the back of the switch:
    Blue - connects to pin 85 on the relay
    White - connects to pin 87 on the relay
    Black - connects to pin 86 on the relay
    That being said, my switch that I want to use came with the following diagram:
    For the life of me I can't make sense of this. The blue/yellow wire from the switch obviously goes to the dimming circuit. There's a switch adjacent to the spot I want to use that contains the fog light switch, so I assume I can just splice into the dimmer circuit there.
    As for the other 3 wires, I'm totally at a loss. All I want is to be able to turn on my light bar regardless of the vehicle headlights, when the ignition is on. Can anyone help?
    Edit: my dash switch that I want to use is from AirOnBoard, which supplied the wiring diagram in the photo above.
  20. Jan 26, 2016 at 11:48 AM
    #120
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    Sub'd for the great info!
