30" Light Bar Install - Easier Than You Might Think
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rysingsun, Dec 16, 2015.
  1. Feb 5, 2016 at 4:19 PM
    #141
    Ray1749
    Ray1749 Ray J
    Ray
    NY
    16 tacoma sport blazing blue
    3" lift tint tailgate inserts LED bed lights LED brake light strip Bed cover
    Thanks everyone for the posts. It's looks very easy to install. Then the next is the switch i am getting a push switch for a clean look. Thanks again.
  2. Feb 10, 2016 at 7:51 AM
    #142
    helimech09
    helimech09 Well-Known Member
    Nick
    South Alabama....or South Louisiana if I'm working
    Black 2016 DCSB and White 1989 Mazda B2600i 4x4
    Gunmetal metallic Tacoma side badges, debadged tailgate, blacked out chrome grill surround, customcargrills.com grill with Toyota badge color matched to other badges, color matched rear bumper covers, Black headlight mod, 30" light bar stealth mounted in front bumper, Bilstein 5100's all around, OME 887's, Icon uniballs UCA's, Wheelers AAL, Spidertrax 1.25" spacers, 17" Gunmetal SCS SR8 wheels, Cooper STT Pro 285/70/17 Tires
    How are you guys getting the bar behind the bumper without taking it off. I took the grill off and I'm not even close to being able to get the light bar back there
  3. Feb 10, 2016 at 7:58 AM
    #143
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    What light bar do you have? How long is it? 30" or 32" ?
  4. Feb 10, 2016 at 8:00 AM
    #144
    helimech09
    Nick
    30 inch
  5. Feb 10, 2016 at 8:34 AM
    #145
    fshams
    Columbus, OH
    You shouldn't have any issues sliding it in there if you took the entire front grille out... Did you see the pictures OP posted here on this thread? By the way, what brand name is your LED light? Do you have a link?
  6. Feb 10, 2016 at 8:39 AM
    #146
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
  7. Feb 10, 2016 at 8:46 AM
    #147
    helimech09
    Nick
    My light bar was a gift. It's an eBay light bar. There is a small metal piece in the center that connects to the hood latching mechanism. Not far below that are the rounded cooling fins in front of the condenser/radiator. It's not even close to happening. Taking the bumper off isn't a big deal, but I was hoping I wouldn't have to
  8. Feb 10, 2016 at 9:27 AM
    #148
    Woody79
    Woody79 Well-Known Member
    Kevin
    Utah
    2016 DCSBOR 4x4 Quicksand
    Icon Stage 2 TRD Pro Wheels 285/70/17 BFG KO2's Header Rail Extang Solid Fold 2.0 Tonneau Cover
    You should have lots of room without removing the bumper. You have to remove the grille first and then the plastic air dams on each side of the radiator. Here is a screenshot of a write up I was working on that shows pics and explains more:
    DubfromGA and helimech09[QUOTED] like this.
  9. Feb 10, 2016 at 10:44 AM
    #149
    ridez
    ridez Well-Known Member
    vancouver bc
    2016 white DCLB TRD sport with upgrade package
    OME 887s, 5100s, deaver AAL, light racing UCAs
    I had to remove the middle support where the hood latches to. It's a few bolts. Just mark it where it is from the factory so you can put it back in same spot. Then it's easy peasy
  10. Feb 10, 2016 at 12:03 PM
    #150
    Ray1749
    Ray1749 Ray J
    Ray
    NY
    I also had to take out the two plastic pieces one on left and one on right then you can slide it in to the fender well and then in. I couldn't get the plastic back in so i left them out no big deal. Hope this helps you.
    helimech09 likes this.
  11. Feb 10, 2016 at 1:38 PM
    #151
    helimech09
    Nick
    I took out the two air ducts on the side and got it. It's done now. My only other problem was that when I tried to splice into the dimmer wire mentioned in the write up, my switch light did not do as I wanted. It actually was illuminated when the headlights were off and turned off when I turned the headlights on. That's bassakwards. I tried all of the wires in that bed light switch. Nothing worked so I just rolled with it and there is no switch light
  12. Feb 10, 2016 at 1:59 PM
    #152
    Ray1749
    Ray1749 Ray J
    Ray
    NY
    Glad it worked out for you. As for the switch i am using the one that came with my haness right now till the OME one comes. Then i have to figure it out. The one i have now has 3 wires the OME has 4.
  13. Feb 10, 2016 at 2:11 PM
    #153
    helimech09
    Nick
    I had the mictuning switch with 4 wires. I think maybe since it is on a relay that is why it's running backwards. I'm not the greatest electrician and I was just tired of thinking about it. I can figure it out some other time
  14. Feb 10, 2016 at 4:39 PM
    #154
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
    I had to snake my 20" in
  15. Feb 10, 2016 at 5:12 PM
    #155
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    cant speak for the 3rd gen but I went in from the bottom.
  16. Feb 10, 2016 at 6:44 PM
    #156
    helimech09
    Nick
  17. Feb 11, 2016 at 2:41 PM
    #157
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    made it in from the bottom, too. just had to remove ducts and unmounts extra tranny and oil coolers....worked fine
  18. Feb 12, 2016 at 8:44 AM
    #158
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    NICE!
    nevadabugle[QUOTED] likes this.
  19. Feb 12, 2016 at 2:19 PM
    #159
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Has anyone used the cali raised brackets with other brand light bars? like the eyourlife led bar?
    I am close to pulling the trigger on this Philips LED light bar
    http://www.ebay.com/itm/181410457147
  20. Feb 12, 2016 at 4:25 PM
    #160
    fshams
    Columbus, OH
    Are you sure this light would fit?
