$30 PCV !!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maser, Jan 27, 2012.
  1. Jan 27, 2012 at 4:59 PM
    maser
    maser [OP] Hello, my name is Maser... and I'm an alcoholic
    Fort Worth, TX
    06 PreRunner Dbl Cab
    fog light mod,DTRL mod,alternating turn signal mod, BHLM, pioneer pt 3200dvd, fosgate speakers all 4 doors,AFE CAI, Magnaflow turndown exhaust, satoshi'd grill, Procomp 6 in lift, 2 Diamond audio 10's w/ 600w amp..........
    Long story short....I go to my local O'reilly's to pick up some TB cleaner and a new PCV, the guy tells me " oh, that one is $28.99 ", I say "wtf?, it should be like $4"....he looks up a picture of it and says " hmmm, it must be because it is the screw type". Suffice it to say, I did not buy a $30 PCV. I think I'm going to just try to clean the old one with the TB cleaner.
    Has anyone else had this experience? and what kind of results should I expect in cleaning and replacing PCV? I personally have always replaced with new.
  2. Jan 27, 2012 at 7:43 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
  3. Jan 27, 2012 at 7:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Clean it with the tb spray....youll be fine.
  4. Jan 27, 2012 at 7:57 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Where is the pcv on these trucks? My Chilton's manual doesn't even mention it. :confused:
  5. Jan 27, 2012 at 8:09 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.03CUPID
    1.03. Kbro2s. ICONS.
    Clean it till it rattles. No need to change.
  6. Jan 27, 2012 at 8:56 PM
    OffroadToy
    4X4 Offroad
  7. Jan 27, 2012 at 8:58 PM
    undermoneyed
    undermoneyed aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Haynes Repair Manual Tacoma 2005 - 2009 shows the PCV valve. HTH
    Mark
  8. Jan 27, 2012 at 9:30 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    That part is less than $10 bucks at any decent OEM Toyota Parts shop.
  9. Jan 30, 2012 at 5:13 AM
    maser
    Fort Worth, TX
    Thanks for all the advice guys...turns out PCV wasn't in bad shape, cleaned and replaced. :thumbsup:
  10. Jun 25, 2012 at 9:58 PM
    DR Da_da
    DR Da_da Infrequent Member
    Northeast FL
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I just pulled my PCV valve tonight to clean it in conjunction with a throttle body cleaning, air filter clean/re-oil, and MAF sensor clean. When I reinstalled the PCV valve I torqued it to 20 ft-lbs per the link above. I noticed, however, that it wasn't fully seated up against the engine / all the way to the base of the threads. Is this normal? Prior to removing it I didn't notice whether or not it was seated all the way in. Thanks!
  11. Jun 26, 2012 at 11:12 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It has tapered threads and doesn't need to be seated against the engine.
    Local Autozone lists it for $12.99.
    Part Number: PCV1014DL
    Alternate Part Number: PCV1014
  12. Jun 26, 2012 at 12:18 PM
    oldstick
    oldstick Middle Age Member
    GA
    Keyword....
  13. Jan 29, 2016 at 5:03 PM
    thewarriordinghy
    thewarriordinghy Kyle Busch Truck
    Ben
    Georgia
    2007 Kyle Busch Tacoma
    plastidipped rims, Toyota trucks emblem, jesus fish, strictly street spoiler, NASCAR cat-back, URD cold air intake, Aftermarket TRD offroad stickers, Kyle Busch license plate bracket, URD Ypipe, custom manifold spacer, URD headers Tundra racing drop kit
    so is this a unbolt the old, bolt the new on to 20ft-lbs and call it a day type ordeal???
  14. Jan 29, 2016 at 5:06 PM
    thewarriordinghy
    Ben
    Georgia
    so just a turn past hand tight should suffice?
  15. Jan 29, 2016 at 5:13 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    I paid 7 bucks at the dealer. Thirty dollars is robbery!
  16. Jan 29, 2016 at 5:16 PM
    thewarriordinghy
    Ben
    Georgia
    and it is literally just the one bolt right? like that's all there is to it? just seems to easy...
  17. Jan 29, 2016 at 5:50 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    So where exactly is this pcv valve?
  18. Jan 29, 2016 at 5:52 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Driver's side valve cover near the back.
  19. Jan 29, 2016 at 5:55 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
