30 second headlight foggy fix
Discussion in 'General Automotive' started by ruler1, Jan 26, 2012.
  1. Feb 5, 2012 at 4:25 AM
    ruler1
    ruler1 [OP] stump thumper
    palmetto fl
    97 2.7 4x4 5speed
    header, k&n intake, ome coils, springs and struts,diff drop, Urd simulator, dynomax exhaust, slotted roters, bpv relocater
    The one in the video still looks good. Mech says "the trick is to keep rubbing." I said, "thats what she said".
  2. Feb 5, 2012 at 4:32 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    :popcorn: waiting on chris4x2. the lights on dads tundra are starting to haze want to take care of them before they get to bad. they are not bad for a 12 year old truck. and in till ’08 it was parked under the car port like 75% of the time.
  3. Feb 5, 2012 at 4:44 AM
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    subbed !! been wanting to try something like this lol. got a BLHM set sitting on the side with some major clouds. :)
  4. Feb 5, 2012 at 5:25 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Tomorrow I'll do it, if chris doesn't do it today.
  5. Feb 5, 2012 at 7:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Superbowl today, so Im not sure if I'll have the time.
  6. Feb 5, 2012 at 10:17 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    Yeah me either. I'm out class tomorrow at 1:30. I'll try to get it done. IF I EVEN HAVE BRAKE CLEANER! I'll stop on my way home I guess.
  7. Feb 5, 2012 at 10:22 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    I believe its what he said to her.. keep rubbing
  8. Feb 5, 2012 at 10:30 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  9. Feb 5, 2012 at 11:02 AM
    tinker_troy
    T R O Y
    WY/SD
    alright, I went out and tried it.
    My headlights aren't that bad but there is a little hazing at the top so I sprayed a little (much less than what the guy was using in the video) on a rag and it instantly stuck to the headlight and just fogged it up more as I moved it around. Also it has fine little cracks in the surface like what TRDchris experianced on his brake light.
    I used non-chlorinated brake cleaner, don't know if that makes a difference.
    Maybe it's a difference in the plastic or maybe I just suck at this (that would be a first :cool:) but I would say just stick to the little headlight restore kits or polishing compound.
  10. Feb 5, 2012 at 11:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Interesting....I wonder what kind the guy in the video used?
  11. Feb 5, 2012 at 11:50 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    Used the 3m kit on my maxima a few years ago. Best results.
  12. Feb 5, 2012 at 2:44 PM
    TRDChris
    TRDChris Well-Known Member
    La Puente
    5 lugger
    H.I.D 6000K, 5% tint all around, black on blacked out rims(sprayed stock rims), fog light mod, deckplate mod, plastidipped bumper and interior, self made eyelids, window visors, clear corners, Billet grille, trd grill emblem
    Brake fluid works better and isn't as harsh as brake cleaner......I would definately recommend brake fluid
  13. Feb 5, 2012 at 2:44 PM
    TRDChris
    La Puente
    5 lugger
    Toothpaste gets the job done :thumbsup:
  14. Feb 5, 2012 at 3:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    But if you get teh brake fluid on paint, the paint is a gonner.
  15. Feb 5, 2012 at 5:23 PM
    #35
    TRDChris
    La Puente
    5 lugger
    Very true!!!! Avoid the paint!!!!!
  16. Feb 7, 2012 at 12:33 PM
    #36
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    I used a kit a few years ago that had a clear coat like spray that you used after then polished again. worked wonders and the clear coat kept it from yellowing again.
  17. Feb 7, 2012 at 6:28 PM
    #37
    Psycho2
    Psycho2 Well-Known Member
    AZ
    '16 DC TRD Sport Barcelona
    Another thread recommended scratch remover. Found some in the garage, figured it couldn't be a waste.
    Here's a before and after:
  18. Feb 7, 2012 at 6:49 PM
    #38
    TRDChris
    La Puente
    5 lugger
    I have but you have to use very little brake cleaner because It can crack your headlights and you will only get results if your lights are a little hazy....wont work if there too hazy
  19. Feb 29, 2012 at 6:22 PM
    #39
    ohhhgeee
    ohhhgeee Member
    Oscar
    Sacramento
    Line-X, Tool Box, Remote Start
    For those looking for a cheap alternative to expensive repair kits, Harbor Freight has one. It comes with drill mounted micro abrasive pads, foam polisher, polish. It costs $10 and takes about 10 min from start to finish. It worked pretty good on my headlights. If you do buy it, i recommend mask taping around the headlights so you dont sand your paint/chrome. Time will tell wether its a good product or not. I wish I would have known about the toothpaste method, I would have tried that first:facepalm:
