300,000 mile club GEN2.....am I the only one?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chiloquin_Car_Care, Feb 22, 2019.
  1. Feb 25, 2019 at 11:10 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Flip your phone sideways.
    cgs2k2, Lawfarin and rmorse[QUOTED] like this.
  2. Feb 25, 2019 at 11:11 AM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Cool trick. I keep mine locked though, but that’s cool.
  3. Feb 25, 2019 at 2:25 PM
    Markcal
    Markcal Well-Known Member
    This is what I see when I'm looking at your posting on this thread:
    Edit: Just curious how long your clutch lasted if you are driving a manual?
    kidthatsirish and drewskie like this.
  4. Feb 25, 2019 at 5:36 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Wtf, you own all of those vehicles?
    tuttle161 likes this.
  5. Feb 25, 2019 at 7:07 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
  6. Feb 26, 2019 at 8:23 PM
    Chiloquin_Car_Care
    Chiloquin_Car_Care [OP] homie dont play that
    Oregona
    2021 voodooblue DCSB 4x4 3.5l v6
    nada....maybe a license plate one day & BA bumpers
  7. Feb 26, 2019 at 9:53 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    How did you know the water pump was bad? Did you also change your timing chain?
  8. Feb 26, 2019 at 10:06 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I'll be at 300k before the end of the year.
  9. Feb 26, 2019 at 10:09 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    @smcgill had a 2008 with 336K, still ran fine but just needed work. He also had a small plow on it for personal use.
  10. Feb 27, 2019 at 5:49 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Huh, sorry about that, it's an automatic. I've had this signature (see below as to what shows on my screen) since joining TW many years ago, interesting that it does not appear to others.
  11. Feb 27, 2019 at 5:50 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I could debate this all night with enough cold beverages and fire wood.
  12. Feb 27, 2019 at 5:51 AM
    Jaypown
    Justin
    NE Ohio
    I'll debate anything with enough cold beverages and fire wood :thumbsup::cheers:
  13. Feb 27, 2019 at 5:58 AM
    glk21c
    MD
    each time it started leaking from the weep hole located on the bottom of it.
    Still the original timing chain. Checked it's tension about 100,000K ago through a small access port on the top/frt passenger side of the motor, the tension was fine. Although changing the timing chain would still require a ton of work as the water pump is on top of the timing chain cover, not a part of it.
    jross20[QUOTED] likes this.
  14. Feb 27, 2019 at 6:58 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    No you won't. *sound of bottle opening, another log gets thrown on the fire*
  15. Feb 27, 2019 at 8:08 AM
    #35
    Pigpen
    Dan
    Northwest Montana
    There are a couple 400K 2nd gens on here. I'm sure there are a few 300Ks. Good work keeping her going strong that long. I bought mine in Feb 2012 with 30 miles on it. I'm a tank or two from 120K. Planning to run it for a long time. :cheers:
  16. Feb 27, 2019 at 8:49 AM
    #36
    KingTacoRey
    KingTacoRey Well-Known Member
    Rey
    DFW, TX
    2018 DCLB TRD-OR QS
    Bed Mat Black Out: Emblems & Wheels Pro-Grille
    *Pulls up chair and beer*
    I concur
    :popcorn:
  17. Feb 27, 2019 at 8:54 AM
    #37
    Jaypown
    Justin
    NE Ohio
    Challenge accepted
  18. Feb 27, 2019 at 10:21 AM
    #38
    pleetrd
    pleetrd Active Member
    Sacramento, CA
    05 DCLB
    Any 200-300k still running on original alternator?
  19. Feb 27, 2019 at 10:26 AM
    #39
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Will turn 280k this week or next.
  20. Feb 27, 2019 at 10:26 AM
    #40
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Yup
    Skyway and pleetrd[QUOTED] like this.
