300,000 Miles Today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by qnyla, Oct 19, 2012.
  1. Oct 19, 2012 at 10:24 PM
    qnyla
    qnyla [OP] Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    300,000 Miles Today
    My 2006 Tacoma Doublecab TRD Off Road hit 300k miles this evening just west of the Continental Divide near Thoreau, NM en-route to Flagstaff. The truck is running great, and does not look or feel like it has that many miles on it. It seems to finally be broken in.
    I think this is currently one of the 2nd Gen V6 Tacomas with the most miles on Tacoma World. I posted here last year when I hit 250k miles:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/175926-250-000-miles-today.html
    I thought I would share some information for those that might be interested.
    The truck was purchased new on July 27, 2006. I do a lot of exploring across the southwest. LOTS of blasting down rough gravel desert roads and forest roads. LOTS of off-roading, driving up washes, etc. LOTS of snow. Thousands and thousands of miles of 4x4 on snow covered highways. I live at 6500 ft elevation. LOTS of cold starts. LOTS of desert heat. A rough life for a truck. I drive about 10 miles each way to work and do not use the truck for work, so most mileage has been recreational.
    The Tacoma is awesome. The best vehicle I have ever owned. I just bought a new 2012 4Runner TE because of the positive experience with this Tacoma and its impressive reliability. I will continue to heavily use the Tacoma.
    This is the complete repair history:
    293,810 Replace LH and RH front wheel bearings
    293,810 Replace LH needle bearing in front differential (with ECGS bushing)
    268,410 Replace Transfer Case Actuator
    240,866 Replace front brake pads and resurface rotors
    226,735 Replace idler pulley
    212,186 Replace U-Joint spider
    149,612 Electrical short, replace fuse block
    105,041 Replace front brake pads and resurface rotors
    62,659 Replace front brake pads and resurface rotors
    62,659 Replace RH and LH rear wheel bearings
    62,659 Replace RH and LH rear axle seals (Second Repair!)
    29,013 Replace RH and LH rear axle seals
    10 Purchased 7/27/06
    Notes:
    Original clutch !
    Original throw-out bearing
    Original starter
    Original alternator
    Original engine
    Original transmission
    Original CV shafts
    Original stock exhaust
    Original catalytic convertors
    Original oxygen sonsors
    Original fuel pump and filter
    on 6th set of tires (3 sets of Michelin LTX MS, 2 sets of LTX MS2, and now LTX AT2)
    on 4th winshield
    on 2nd battery
    on 3rd compass/temp readout
    on 4th set of OEM all weather floor mats (the good thick ones - drivers heel wear)
    on 3rd OEM shift knob
    44 oil changes
    300k miles at 18 mpg = 16666 gallons of gas = $58333 at $3.50/gal
    Gas was on average much cheaper than $3.50 over the last 6 years, but still it is a LOT of money.
    Motor Oil and Filters
    I use Mobil 1 Extended Protection 5W30 motor oil. I have always used Mobil 1 EP in this truck. I changed the oil to Mobil 1 the day I bought it new. So other than the first 60 miles, it has all been Mobil 1 EP 5W30.
    You can see I use the oversize Mobil 1 M1-209 filter when I run over 5-6k miles between drains. Longest interval between oil changes was 14,542 miles.
    Here is part of my mainanance history (from 200k to 300k miles) to give you an idea of what oil changes I do and how often:
    293,751 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-209 filter
    284,390 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-209 filter
    278,625 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-209 filter
    272,855 Man Trans Gear Oil Change Redline MT-90 75W90 1.9 Quarts
    272,855 Transfer Case Oil Change Redline MT-90 75W90 1.1 Quarts
    272,855 Rear Differential Oil Change Redline 75W85 3 Quarts
    272,855 Front Differential Oil Change Redline 75W85 1.6 Quarts
    272,855 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-209 filter
    258,313 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-209 filter
    248,610 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-209 filter
    237,169 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-209 filter
    231,563 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-209 filter
    231,563 Rear Differential Oil Change Redline 75W85 3 Quarts
    231,563 Front Differential Oil Change Redline 75W85 1.6 Quarts
    229,390 Man Trans Gear Oil Change Redline MT-90 75W90 1.9 Quarts
    229,390 Transfer Case Oil Change Redline MT-90 75W90 1.1 Quarts
    227,605 Oil Change Mobil 1 EP 5W30, Mobil 1 M1-102 filter
    225,424 Rear Differential Oil Change Toyota 75W85 (Dealer)
    225,424 Front Fifferential Oil Change Toyota 75W85 (Dealer)
    225,424 Transfer Case Oil Change Toyota 75W90 (Dealer)
    223,230 Oil change Mobil 1 EP 5W30, Toyota 90915-YZZD3 filter
    220,011 Oil change Mobil 1 EP 5W30, Toyota 90915-YZZD3 filter
    213,254 Man Trans Gear Oil Change Toyota 75W90 (Dealer)
    208,316 Oil change Mobil 1 EP 5W30, Mobil 1 M1-102 filter
    UPDATE 10/26/12 Used Oil Analysis Report
    I received the oil analysis that I did at 300,841 miles which was 7090 miles on the oil. Less than my typical 10k change interval because I was leaving on a long trip and wanted it changed before I left and also I wanted it done near 300k miles.
    Looks good!
    A few photos from recent weeks:
    Drew599 and SOSHeloPilot like this.
  2. Oct 19, 2012 at 10:28 PM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Thought you had to be gettin close! Congrats man, I hope my auto tranny holds up that long
  3. Oct 19, 2012 at 10:29 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
  4. Oct 19, 2012 at 10:30 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    original throw out bearing! :woot:
    06 for the win!
    thanks for the report!
  5. Oct 19, 2012 at 10:31 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Hell yes! That's awesome!
  6. Oct 19, 2012 at 10:32 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2013 TRD O/R
    that is sick! jelly of the 4RTE
  7. Oct 19, 2012 at 10:35 PM
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
    Thats awesome, and your record keeping is phenominal!....I only hope i get 300,000.....right now on 4200 so it ani't happening too soon!
  8. Oct 19, 2012 at 10:35 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    Wow :bowdown: congrats sir
  9. Oct 19, 2012 at 10:38 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Congrats
    That's a ton of fun miles! That's what a truck was built for!
    The southwest is some rugged rough country, perfect for a Tacoma.
    Az
  10. Oct 19, 2012 at 10:39 PM
    qnyla
    NM
    Oh yea, forgot to mention I will be doing an oil analysis when I change the oil this week. I have never had one done, so it should be interesting.
  11. Oct 19, 2012 at 10:48 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Dam that's awesome
  12. Oct 19, 2012 at 10:51 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Congrats... Proper maintenance will get you far!!!
  13. Oct 19, 2012 at 10:53 PM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    Thats impressive! How is it that ur still on the original TOB?
    On my '06, TOB lasted 5 1/2 years @ 50,000KMs.
  14. Oct 19, 2012 at 10:59 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    :drool:
    Toyota FTMFW!
    Take care of something and it'll take care of you is a true statement!
    Keep on trucking bud! :thumbsup:
  15. Oct 19, 2012 at 11:11 PM
    overactor
    overactor Well-Known Member
    robbie
    Columbus Ohio
    2012 MGM Tacoma TRD
    I pick up my new truck on monday 2013 trd off road and I hope that she will live as long as yours has. Your service record keeping is out standing!
  16. Oct 19, 2012 at 11:12 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Looking great!
  17. Oct 20, 2012 at 12:23 AM
    Beast Mode
    Beast Mode Well-Known Member
    PDX
    12 DCSB Sport 4x4
    RCD lift, Pro Comp, 285/70/17 Destination AT, LR UCA, magnaflow muffler, LEER 180, Flyzeye, Clazzio covers, N-Fab steps
    Hell yeah! Congratulations to you and you truck.
  18. Oct 20, 2012 at 12:33 AM
    NWTacoGuy
    NWTacoGuy Well-Known Member
    James
    Pacific North West
    2010 TRD Off Road DCSB
    Fabtech 6", xd addicts/35x11.50 Nitto Terra Grapplers, Black badges, Pioneer HU, 11' grille, ect ect ect....
    Absolutely amazing 300K and original clutch/TOB! :yay:
  19. Oct 20, 2012 at 12:55 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Taco666 likes this.
  20. Oct 20, 2012 at 3:31 AM
    northern1
    northern1 Member
    This is why I bought a taco
