303Shocks
Discussion in 'Colorado' started by TMFF, May 12, 2015.
  1. Jul 9, 2015 at 8:04 PM
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    I live in Elizabeth so it was bout an hour drive for me but worth it. Tim is a good dude and had my Icons knocked out in a couple hours.
  2. Jul 19, 2015 at 12:16 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  3. Nov 25, 2015 at 6:42 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Hey @TimF
    Is it possible to take regular travel rear Icons and make them into extended travel?? My regular Icon vs2.0 seem a little short with my Dakars... I know wheelers sells ext.. Icons same part number as regular....Would that be something you could do?
    Thanks
    Rebecca
  4. Nov 25, 2015 at 9:05 AM
    TMFF
    TMFF [OP] Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I do not know for sure. If I can open one I can see if there is a spacer I can take out or shorten to lengthen the shocks.
  5. Nov 25, 2015 at 9:14 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I doubt it has a spacer in it. The shock bodies themselves looked really short. Can you find the exact ones you bought to get a travel figure? Or did you unbolt the bottom mount and see how far below the axle it sits at full extension?
  6. Nov 25, 2015 at 9:16 AM
    303tacoma
    Rebecca
    yeah I think maybe that's what Wheelers does but since you don't know for sure maybe I'll just buy the ext length.. Just thought if you knew if that's what they did then I could save my cash...Thanks Tim
  7. Nov 25, 2015 at 9:19 AM
    303tacoma
    Rebecca
    I have 14.22 col 23.25 ext Icon vs20
    The extended from Wheelers same part number as mine but 15.9col
    26.8 ext
    You got me thinking @Squeaky Penguin
  8. Nov 25, 2015 at 9:22 AM
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    Sometimes it's not even the travel that makes a shock considered extended/long travel. On a set of shocks I was looking at, they had a normal travel version and an extended/lt version. The only difference in the two were the bottom mounts. One had a 3" extended eyelet mount, the other was normal.
  9. Nov 25, 2015 at 9:26 AM
    303tacoma
    Rebecca
    Ok thanks for the heads up before I buy
  10. Nov 27, 2015 at 8:50 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    As a rebuilder, any shocks you would stay away from or recommend? I'm looking at going Mid travel after the 1st of the year?
  11. Nov 29, 2015 at 9:34 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Imo, Fox, King, Icon, Sway a way/aFe are all good products and all have the same corrosion issues in our environment if the mag chloride isn't washed off regularly.
    The only shocks I would stay away from are the walker Evans. Their seal head design will weld its self to the body in no time up here. I have yet been able to get one apart.
    thefatkid[QUOTED] likes this.
  12. Dec 3, 2015 at 6:38 PM
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Why do you think your rears are too short? Just curious cause we have the same rear components.
  13. Dec 4, 2015 at 4:26 AM
    303tacoma
    Rebecca
    No droop so I bought extended Icons and bump stops....the shocks are my limiting factor
  14. Dec 4, 2015 at 11:46 AM
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    @303tacoma I don't know if Icon does this but Sway Away does it to where you can change out the bottom eyelet mount and they make standard size ones up to 3" extended ones. Like how I mentioned above.
    BTW, See you saturday around noon Tim :D
  15. Dec 4, 2015 at 1:14 PM
    #35
    303tacoma
    Rebecca
    yeah I already ordered the extended icons. Talked to Wheelers and they said they are custom built no extended mount.. 10.9" travel vs 9"We'll see I get them today. Hopefully I'm understanding right cuz I really don't have a clue...:D Haha
  16. Dec 5, 2015 at 6:18 AM
    #36
    303tacoma
    Rebecca
    Just an update on the extended 2.0 vs Icons the shock body is close to 3" longer than the non extended so I'm pretty sure @Squeaky Penguin was right about not being able to convert reg to extended....
    :D
    CO MTN Steve and SilverGhost like this.
  17. Dec 7, 2015 at 7:02 AM
    #37
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    Thanks to @TimF for rebuilding my coilovers over the weekend. They were definitely in need of some maintenance. You were right about the settings, they were set for WAY to much preload with those new coils lol. It was stiffer than a morning woody when I put them on. I ended up dropping the preload by around 1-1/4 inches!
    Blacktacoma23 likes this.
  18. Dec 7, 2015 at 7:28 AM
    #38
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    That sounds about right with the longer coil and higher spring rate.
    Poly or SAW direct should be able to get the new misalignments.
  19. May 6, 2016 at 6:29 PM
    #39
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    I may have to hit you up soon @TimF to rebuild my front Icons. I've been looking for someone local since I moved to CO and I'm going on almost 3 years now without them being touched. What's your normal turn around time?
  20. May 6, 2016 at 6:53 PM
    #40
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    24-48 hours
    CharlieCafe likes this.
