305/65/17
Discussion in 'Wheels & Tires' started by solus, May 10, 2010.
  1. May 10, 2010 at 12:59 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    other than prerunnerseth who has 305/65/17 tires...
    if so does anyone have any problems with rubbing ... more than with 285/70/17?
  2. May 11, 2010 at 11:35 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    bump
  3. May 12, 2010 at 10:33 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Not sure who else has them, but I think Secretsquirrel has 305/70/16's which should be basically the same. I dont see it being much of a problem to run them as its basically a 33x12.50.
  4. May 12, 2010 at 5:56 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I run that size and they only rub a little when turned to full lock, a little trimming will cure that
  5. May 12, 2010 at 5:57 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    what about when you wheel? ^
  6. May 12, 2010 at 6:17 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    Boulder Creek, CA (Nor-Cal)
    2010 SSM DCLB
  7. May 12, 2010 at 6:28 PM
    kingtaco
    kingtaco Well-Known Member
    San Gabriel Valley
    I'm running 305-65-17. I just had to trim a little bit of the black plastic under the wheel well. No grinding of body mounts. As far as wheeling, I haven't done anything crazy but what I have done there hasn't been any issues.
  8. May 12, 2010 at 7:50 PM
    thelittledoos
    thelittledoos Active Member
    Mark
    North Carolina
    08 Tacoma DC Sport 4 x 4
    Old Man Emu 3"
    I have them too. No rubbing except on the front plastic in the wheel well. Clears the cab mounts and controls arms. Mine are on Moto Metal 17x9'S.
  9. May 12, 2010 at 7:52 PM
    Cwhitt09taco
    Cwhitt09taco Well-Known Member
    Cody
    Mississippi
    09 Double Cab Tacoma TRD Offroad 4wd
    Stock for now. Bfg at's, aries bull bar, aries nerf bars, uws tool box.
    Do you have to have a lift to run that size tire, if so what size and which one is recommened
  10. May 12, 2010 at 8:05 PM
    thelittledoos
    Mark
    North Carolina
    Old Man Emu 3"
    Must have a lift. I have a three inch OME.
  11. May 12, 2010 at 8:15 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    check MxPatriot he has but then again he has the allpro long travel kit... they look bad ass...
  12. May 12, 2010 at 10:05 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yeah I saw that... but I'm not LT
  13. May 12, 2010 at 10:46 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    are u running any wheel spacers... cuz i know Chris (its_taco_time) has some wide tires...
  14. May 12, 2010 at 10:52 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
  15. May 12, 2010 at 11:27 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    then u might rub... but take my word with a grain of salt lol....
  16. May 21, 2010 at 10:19 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Yea man they're gonna rub a little. You'll need to do a lot of trimming on the fender flares and maybe take a grinder to your body mount depending on what lift and wheels you have.
    I'm having the problem of really smashing my fender flares when the suspension cycles all the way to the top. I'm going to need to go to fiberglass soon. My fender flares are zip tied on...
  17. May 22, 2010 at 1:20 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^good to know... I don't know PRS runs them but say he doesn't rub and he has a spacer 3" lift
    I'm gonna go look into a cab mount chop...
  18. May 22, 2010 at 2:03 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    They will most likely rub on your body mount at full turn or offroading.
  19. May 22, 2010 at 2:07 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    i got my cab mounts chopped a few months ago...only set me back 90 bucks. I'M GONNA RUN 295/75/16S...I probably didn't have to have them chopped but i figured wth.
  20. May 22, 2010 at 2:15 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    did you box them in?
