305/70r17
Discussion in 'Wheels & Tires' started by jr114, Dec 13, 2010.
  1. Dec 13, 2010 at 11:56 AM
    jr114
    jr114 [OP] Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Besides minor trimming, do you guys forsee any issues running a 305/70r17 on a 17x9 4.5 backspacing with -12mm offset? Thanks
  2. Dec 13, 2010 at 1:08 PM
    jr114
    Jon
    SoCal
    Truck
    anyone
  3. Dec 13, 2010 at 1:19 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    I have 33/12.5/70. no probs. tubs a little sometimes. you should be good 2 go.
  4. Dec 13, 2010 at 1:19 PM
    jr114
    Jon
    SoCal
    Truck
    thanks. what tire are you running
  5. Dec 13, 2010 at 3:32 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    305/70/17's are 34's....that's going to require a lot of cutting and grinding with a 3" lift.
  6. Dec 13, 2010 at 3:33 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    More than likely will require the body mount chop to allow full compression with steering.
  7. Dec 13, 2010 at 11:52 PM
    jr114
    Jon
    SoCal
    Truck
    ya ill make em fit. its actually cheaper by a few hundred to buy 305's than a 295. Its the terra grappler at. im running them now as a 285. i have no complaints with them. so just get a bigger version. dam i need to make up my mind and stop looking on here so i dont get any more ideas. haha
  8. Dec 14, 2010 at 12:31 AM
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    my 305s never rubbed. i had the king replacement c/o's at the time.
  9. Dec 14, 2010 at 12:36 AM
    jr114
    Jon
    SoCal
    Truck
    what tires were you running?
  10. Dec 14, 2010 at 12:46 AM
    in2nite
    James
    SoCal.
    blk 07 prerunner
    i had pro comps xterrains.
  11. Dec 14, 2010 at 1:58 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    The 305/70/17 will necessitate cutting the body mount, a decent amount of fender liner, and a bit of fender flare, as well as pounding the pinch weld down in the front fenders. If you use all your suspension travel, some different bump stops might be necessary to no tear up fenders as well. If you dont run an aftermarket front bumper with added clearance, there will be some bottom front bumper and fender liner trimming for sure.
    Running the 34's is very much doable, but not a slap em on and run them ordeal. There's some work involved. The outcome will be :thumbsup::thumbsup: IMO. :)
    Good luck with it and post pics.
  12. Dec 14, 2010 at 9:00 AM
    jr114
    Jon
    SoCal
    Truck
    ya im ok with doing the work. i just need to make up my mind and stop looking on here. haha. too many ideas. i hope theyll look sick. ill search the pinch weld mod right now and see...
  13. Dec 14, 2010 at 9:05 AM
    jr114
    Jon
    SoCal
    Truck
    probably a stupid question, but i just wanted to confirm that the pinch weld mod for first gens is the same as 2nd gens. cant get out to look at the truck right now. also can the body mount chop be done with a good grinder and cutting wheel? ive read that it does not need to be sealed because there are holes in the frame right there to allow stuff to run out?
  14. Dec 14, 2010 at 9:17 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    You have a second gen though? :confused:
    Yea, just use a grinder to cut the cab mount. The pinch weld is a vertical line right above the cab mount that sticks out a bout an inch. It's hard to miss.
  15. Dec 14, 2010 at 2:55 PM
    jr114
    Jon
    SoCal
    Truck
    ya i have a 2nd gen. the only link that i could find on the pinch weld was one for a 1st gen. just wanted to confirm that its the same process.
  16. Dec 14, 2010 at 3:00 PM
    jr114
    Jon
    SoCal
    Truck
    i figured as much. im sure when i actually visualize it on the truck itll make more sense
  17. Dec 14, 2010 at 4:30 PM
    Jason'sLawnCare
    I'm sure a grinder will work. You just may have to cut out chunks to access the top part easier. Ideal would be a sawzall but an angle grinder will certainly do. Most recommend welding a plate over what you cut off to gain the strength back but many have not and haven't had trouble.
  18. Dec 14, 2010 at 7:47 PM
    jr114
    Jon
    SoCal
    Truck
    thanks. i just happen to have both. sawzall and several grinders sitting in the garage. just to get the tires and well see.
  19. Dec 14, 2010 at 7:55 PM
    Jason'sLawnCare
    Well then, you are pretty much set.
    Very funny! My noobie ass at the time didn't know just how fucking strong that thing is.
  20. Dec 14, 2010 at 8:02 PM
    jr114
    Jon
    SoCal
    Truck
    haha..happen to have one of those as well. gonna try to finesse it at first. if that doesnt work...well like you said. gonna grab a big mofo of a hammer:D
