308 vs 300 WSM
Discussion in 'Guns & Hunting' started by bowhunter11199, Mar 4, 2011.
  1. Mar 4, 2011 at 5:35 PM
    bowhunter11199
    bowhunter11199 [OP] Well-Known Member
    so what do you guys think. im setting up a long range rifle package. the farest range im thinking is about 800. These shots will be on many elk,muleys and possibly one day a moose. so far in the last 2 years i've shot 2 cows over 600 yards. 2x2 muley(my first deer) at 250 and a moster 5x5 muley (on public ground... scored 170) at 580yards.
    current setup
    (used it for 2 years)
    weatherby vanguard 300 wsm
    nikon monarch 4x-16x BDC recticle
    awesome setup but the BDC only has circles out to 600 yards
    so past that 600 mark was pretty sketching
    scope ideas?
    i've been looking at getting another monarch or buckmaster( both made by nikon) but in mil-dot. i've read alot about how (once mastered) is can be very efficent at ranging and killing. but is there anyother recticles out there that do is better:confused:
  2. Mar 4, 2011 at 8:04 PM
    Vandy
    Vandy Well-Known Member
    Jake
    Pasadena, MD
    2008 DC-LB, 4x4 SR5, Indigo Ink
    Redline Hood Struts, Blacked out Badges, Blacked out SR5 Wheels, BFG All-Terrains, aFe Pro Dry Air Filter, Wicked Flow Muffler
    That's a long way to be shooting at game - but maybe that's because I hunt the eastern woods. For what you are looking for, out of the two, the 300 WSM is the better choice. At 500 yards with the 308 you are around 1200 ft-lbs whereas some 300WSM loads will still be carrying more than 1700 ft-lbs.
  3. Mar 4, 2011 at 8:12 PM
    whiskey101
    whiskey101 Well-Known Member
    Clarksville, TN
    '17 Super White 4WD TRD Off-Road
    Leer 100XQ
    personally, I would go with the full sized 300 WIN MAG if I planned to shoot at game over 500 yards.
  4. Mar 4, 2011 at 8:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2.
  5. Mar 4, 2011 at 9:55 PM
    showmeballer
    showmeballer Well-Known Member
    st. louis
    08 trd off-road
    None yet
    x3
    or even take it up a notch and go .300 RUM. :)
  6. Mar 4, 2011 at 10:26 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    at that distance, you dont even need camo!!
    that is some fine shooting. i havent shot a rifle in 5 years. i bet i would miss at 300.
  7. Mar 4, 2011 at 11:12 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    why on earth would you even think about changing your set up if you're getting the results you're claiming from your 300 wsm? but damn, those are long distances to be shooting at an animal.
  8. Mar 4, 2011 at 11:24 PM
    jigger1976
    jigger1976 Well-Known Member
    ontairo
    06 tacoma 4x4 ddbl cab
    3" lift, GRILL VENT VISIORS,CAP WEATHERTECH MATS
    i have been doing long distance shooting for 20+ yrs. it dosent mader what type of gun you use. figuar out all the bullistic and fps alone with other thing and you can setup any gun to shot that dist. there is alot of good reading out there on how to do this.there also is companys that do it for you. for cheap. you give them your info and they make you a scope. for under $2000 mostly under1000. do ur research hopefully that helps you practise practise
  9. Mar 5, 2011 at 1:07 PM
    bowhunter11199
    thanks guys i thought about it and i think im going with the 300 because i can get a lot more ftp out at those ranges.
    but now what do you guys think about scopes. i've been really thinking about mil-dot but its really hard to get measurements( in mills).
    like .1,.2,.4,.8,.9,1 mills are easy and fast to get but what about .3,.5,.7:confused: and when im shooting 800 yards and im off by .1 or .2 mills that means miss.like for example with a deer that has a 24" deep chest and i measure it at .8mill i think its 833 yards. If in reality it really measures .7mill then it is really 952 yards so a HUGE MISS.
    Heres the formaula... depth of deer's chest in yardsX1000/ measurement of deer's chest in mills
    ( when i say depth i mean verticle measuremeant of deer's chest when its broadside)
    any ideas on scopes???
  10. Mar 5, 2011 at 10:05 PM
    bowhunter11199
  11. Mar 6, 2011 at 11:50 AM
    burnt_tiger
    burnt_tiger Well-Known Member
    Bakersfield CA
    08 dbl cab 4x4 longbed
    viper 5900 automatic start/alarm, pioneer avic-d3 indash gps UWS black truck box black tube steps, blue sea fuse block wet okoles console vault AFE oil free drop in air filter. hose clamp mod 5% tint Cobra 75 CB
    check the horus reticle. no bdc or windage, its all done by holds. much faster to adjust to changing ranges/speeds. provided you know your holds of course
    http://www.horusvision.com/falcon.php
    they have a simulation on it that teaches you how the reticule works, check it out its awesome
  12. Mar 9, 2011 at 4:35 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I prefer to use a short action bolt rifle. Most of my mid-long range shooting has been with a 308. My extra long range shooting is done with my 338 Lapua Mag. For a do everything hunting rifle I would definately go with the 300wsm, its flat shooting and has plenty of puch to it.
  13. Mar 9, 2011 at 4:40 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    As far as optics go I always have my scopes custom made by U.S. Optics (Jeff is a great guy) I like the canadian mil retical the best along with the TPal configuration. the only exception to this is on my AR, I use an ACOG.
  14. Mar 9, 2011 at 4:44 AM
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    x4 on the .300 win mag. Nightforce makes excellent glass, and if you have the cash, check out David Tubb's DTAC system.
  15. Mar 9, 2011 at 6:54 PM
    bowhunter11199
    ya i really dont want to spend more than $650 on a scope so mabey ill just get a better rangefinder.
