30a power fuse location
Discussion in '1st Gen. Tacomas (1995-2004)' started by pistolsnipe, Nov 23, 2013.
  1. Nov 23, 2013 at 7:48 AM
    pistolsnipe
    pistolsnipe [OP] Member
    hello, i shorted out the power supply to my radio today, and for the life of me i can't find the fuse for it. i know there is a fuse block on the drivers side above the left foot, and on the panel you take off, where it shows the fuse diagram, there is a 30 amp fuse shown on it, separate from the rest, but i can't find it anywhere. i am wondering if the previous owner relocated it during an alarm install or something?
    can someone snap a pic of where it is supposed to be located? or provide a more detailed description?
    thanks
  2. Nov 23, 2013 at 8:07 AM
    02coma
    02coma Well-Known Member
    la puente
    02 dc
    I think 15amp
  3. Nov 23, 2013 at 8:09 AM
    02coma
    la puente
    02 dc
    Underhood
  4. Nov 23, 2013 at 8:44 AM
    pistolsnipe
    it is possible that model years are different for 1st gen, here is what i am talking about
    you can see that i have marked the fuse i am looking for
    whereas that fuse is not present in the fuse block
    the only 30a fuse in the engine fuse block is am2, which disables a ton more stuff when i unplug it.
    the 7.5a fuse marked radio seems to be what provides the acc power when the ignition key is turned, i am looking for the fuse that provides power to the clock, and wiring harness for constant 12v
  5. Nov 23, 2013 at 8:59 AM
    02coma
    la puente
    02 dc
    What yr truck
  6. Nov 23, 2013 at 9:05 AM
    pistolsnipe
    1997 (later half, no distributor) extra cab 4wd 2.7
  7. Nov 23, 2013 at 9:18 AM
    02coma
    la puente
    02 dc
    u was missing that fuse. Some 1 relocated it.
  8. Nov 23, 2013 at 9:22 AM
    02coma
    la puente
    02 dc
    On top of 10amp middle, did u see bracket. That's for 30amp u looking
  9. Nov 23, 2013 at 9:30 AM
    pistolsnipe
    thanks, time to go fishing again i guess
  10. Nov 23, 2013 at 9:44 AM
    02coma
    la puente
    02 dc
    I found this, may help . It in engine compartment. ( pencil point)
  11. Nov 23, 2013 at 9:53 AM
    BamaToy1997
    Bill
    Navarre, FL
    For a 97 Tacoma, the power comes from both the 7.5 amp radio fuse, and the 15 amp dome fuse. I have never seen a radio powered off a 30 amp fuse before, especially on a 97. My 97 runs off the radio fuse and the dome fuse.
  12. Nov 23, 2013 at 10:58 AM
    pistolsnipe
    thanks bamatoy, that was right on the money. i looked at the interior fuse panel, and it looks like there isn't even enough room to put an extra fuse box between the existing one, and the ducting for the drivers side vent
