30K and general maintenace questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kzibjj, Jun 3, 2011.
  1. Jun 3, 2011 at 6:43 PM
    kzibjj
    kzibjj [OP] Member
    Dave
    upstate NY
    2010 double cab L/B 4WD
    I'm brand new to the forum and didn't see any other threads about this stuff. I've got a 2010 double cab, L/B, with V-6 eng. In looking at my "wty and maintenance guide" and asking two different dealership service mngrs, I'm getting different answers to the following questions.
    ---manual says replace plugs at 30K due to emission wty. issues. One dealer says yes, one says do at 90K
    ---manual says to replace rear differential oil in vehicles with "optional limited slip differential". What are they talking about as "optional". This is a standard item. Is there some other type of LSD that is optional? Both dealers say there's no such thing as "optional", yet manual mentions it.
    ---manual says inspect front diff. and transfer case oil, unless towing, which I don't. Dealers want to replace all. Is this overkill and just extra $ for dealer?
    ---I see nothing about automatic transmission maintenance. Any suggestions?
    ---Lubricating propeller shaft??? Are they talking grease fittings on u-joints because I don't see any/
    Thanks for taking the time to answer so many questions
    Dave
  2. Jun 3, 2011 at 6:44 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I dont have an LSD.
  3. Jun 3, 2011 at 6:46 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
  4. Jun 3, 2011 at 6:46 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    The TRD sport has the LSD, the OR has a locking diff, non LS.
  5. Jun 3, 2011 at 6:49 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Change plugs.
  6. Jun 23, 2011 at 9:23 PM
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    So if I have a locking diff, then there is no need to get the "special" kind of oil for the differential? Front and rear can use the same?
  7. Jun 23, 2011 at 9:50 PM
    Eurosport
    Eurosport Well-Known Member
    around the world
    actually you can use the same for rear and front and transfer case (75w90) they speced different for the front in the manual just to squeeze another 0.5mpg out for epa ratings.
    here's a good thread
    http://www.tacomaworld.com/forum/2n...ront-diff-transfer-case-oil-change-howto.html
    easy diy specially with so much clearance under these trucks
  8. Jun 23, 2011 at 10:32 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    1. replace plugs
    2. replace rear diff fluid, no lsd additive necessary. replace transfer case and front diff fluid too (all use same fluid)
    3. no tranny service till 60k (replace fluid at 60)
    4. yes, there are fittings on u-joints on driveshafts
  9. Jun 23, 2011 at 10:36 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Damn, I only did oil change at 30K
