30k fluid changes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrGooch, Oct 17, 2023.
  1. Oct 19, 2023 at 5:51 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    not really, but you want to stick with the same weight and rating as Toyota calls for. I generally ran synthetics whenever possible.
    the only thing, lubricant or fluid wise I will not stray from is the WS automatic transmission fluid from Toyota. I absolutely will not use anything else in a Toyota that came with WS
  2. Oct 19, 2023 at 6:43 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Sorry, but I absolutely disagree with that. I've yet to see anyone regret doing too much/a little more than recommended/at least the recommended maintenance. But I have seen a lot of regret for doing not enough or none.
    22Coma6MT likes this.
  3. Jan 2, 2024 at 9:45 AM
    W1JCW
    W1JCW 2016 TRD Sport 4x4
    Bryan, Texas
    Tacoma TRD Sport 4x4
    I don't tow or off road.
    What is the schedule mileage to change the differential fluid in the front and rear ??
  4. Jan 2, 2024 at 10:47 AM
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Trd intake stuff More intake stuff Kdmax pro 10.0 yayayaya
    Hey there? I’m coming up in 12k miles 2022 DCLB 4x4. What and when should I dump out these oils, f/r diff and/or trans flush? What’s your advice much appreciated, J
    HondaGM[QUOTED] likes this.
  5. Jan 3, 2024 at 10:08 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I would change all the diff fluids by 15...I always just drain and fill the trans every 15k..stays clean that way
    Dfpftw[QUOTED] likes this.
  6. Jan 3, 2024 at 10:15 AM
    TacoTuesday1
    SD CA
    Don't know. Labor is up to $230/hr when you pay an organization to do a task for you, multiplied by the amount of time that task takes. Do the math.
    If you are in doubt of book time, look up book time. Generally, the book is looked at for time, and then told to you.
    Neither was I. Did it in a parking lot.
    You would know what they're using
